bios repair FL490/FL590 NM-B931
Re: bios repair FL490/FL590 NM-B931
Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23↵
https://www.badcaps.net/donateComment
Ok thanks youPost your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23Comment
There are 2 models 20Q5 and 20Q6, you have to post the corrupted original bios file and serial number.↵
1. How to dump and flash
https://www.badcaps.net/forum/showpo...40&postcount=2Comment
Hi Everyone. I have a Thinkpad L590 with a Winbond 25Q256JVEQ bios chip. The serial is PF-1YGGLK. Machine: 20Q700ALUK. Bios installed prior to issues was ROZET53W (1.31). The issues started happening when I was trying to make it into hackintosh and one of the steps required reset of nvram. After that it was blank. I was able to get the chip off motherboard and save the attached corrupt bios.
Hope this info helps.Attached Filesif you find these attachements useful please consider making a small donation to the site
tryHi Everyone. I have a Thinkpad L590 with a Winbond 25Q256JVEQ bios chip. The serial is PF-1YGGLK. Machine: 20Q700ALUK. Bios installed prior to issues was ROZET53W (1.31). The issues started happening when I was trying to make it into hackintosh and one of the steps required reset of nvram. After that it was blank. I was able to get the chip off motherboard and save the attached corrupt bios.
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello everyone, could someone help me to clean these files from password?Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
The model of the machine is L490 type 20Q6 the serials were erased by a scratch
These files are my backup
i found serial Number PF29G0QGComment
Hello, i had the same issue, tried making a hackintosh, resetted the nvram and the screen went blank, i've flashed this bios, the laptop started working but it is booting very slow and audio doesn't work (in windows, Intel smart sound OED, code 10 FW did not sent FW Ready notification).
Lenovo ThinkPad L590 with i5-8365u vPro
Serial number: PF1W2L93
Machine number: 20Q8-S20E00
Bios version before issues: R0ZET57W 1.35
Bios chip: Macronix MX25L25673G
Here's my original bios after resetting nvramAttached Filesif you find these attachements useful please consider making a small donation to the site
read again bios chipset, it can't be that corrupt after resetting nvram.
Here's my original bios after resetting nvram----------------------------------------------------------------------------------------------------------------------------------------------------------------------
i've read it 2 times and i got the same readings, right now i flashed the bios "L590_NVRAM" and it turns on but is booting very slowly and the sound doesn't work like i described in my last message.Comment
yep, that's because ME. i'll try rebuild and clean ME for your bios but you have to use LMU to write back DMI----------------------------------------------------------------------------------------------------------------------------------------------------------------------
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
by bschwandHi all,
as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
