Macbook Pro A1990 (820-01814) no backlight display
  • XVLZ
    • Nov 2022
    • 45
    • Great Britain
    Re: Macbook Pro A1990 (820-01814) no backlight display
    Originally posted by mon2
    In diode mode testing, the RED lead, yes red meter probe to ground.
    Black meter probe to point to test.
    in diode mode ~545 on both testpoints J0200
    and continuity on VLED J0803
    • mon2
      • Dec 2019
      • 14012
      If the EN of u8400 (backlight) IC is 3v3 then this is good. The logic is wanting to enable the backlight.
      Confirm the voltage of each side of R8402 which is the resistor on the gate of the mosfet for the backlight.
      • XVLZ
        • Nov 2022
        • 45
        • Great Britain
        R8400 has 12.5V on all four pins
        UPD
        my bad, I thought you were talking about R8400
        now I see that you are talking about R8402
        UPD 2
        R8402 have 11.8 V on 1 pin and 10.9 on 2 pin
        • mon2
          • Dec 2019
          • 14012
          No, I did update the post. It is correct as you have just posted.
          Is the EN pin at 0v or 3v3 (earlier post)?
          If 3v3 then backlight is enabled else disabled.
          • XVLZ
            • Nov 2022
            • 45
            • Great Britain
            EN is 0
            my webcam and key backlight also do not work. maybe this info will help
            • mon2
              • Dec 2019
              • 14012
              Do you still see an image with a flashlight on the display?
              • XVLZ
                • Nov 2022
                • 45
                • Great Britain
                #27
                yes
                • mon2
                  • Dec 2019
                  • 14012
                  What is the voltage to ground for the 'S' pin on the mux (multiplexer)?
                  You can measure at the resistor pads.
                  Update - also check the voltage to ground of the i2C lines as per new attachment.
                  PS: It is very late for you there - best to do this when you are rested. Can continue this tomorrow. My excuse is that my wife is watching a movie in a dialogue that I am unable to understand and there are no sub-titles to follow along. She has hijacked my netflix viewing time.
                  • XVLZ
                    • Nov 2022
                    • 45
                    • Great Britain
                    #29
                    the 'S' pin is 1.7 V (I measured 2 pin R8505)
                    upd I saw your upd (xd), so I will do it, I will continue tomorrow, thanks again for wasting your time on my problem
                    • mon2
                      • Dec 2019
                      • 14012
                      What is the voltage of PP3V3_G3H_RTC_X (measure anywhere you can on the board). This rail powers the mux IC you just measured.
                      Adding to your checklist for tomorrow. See attached.
                      • XVLZ
                        • Nov 2022
                        • 45
                        • Great Britain
                        #31
                        PP3V3_G3H_RTC_X
                        R6935 and R6934 test 1 pin = 3.3 V
                        ps really time to sleep before i screw up something
                        • XVLZ
                          • Nov 2022
                          • 45
                          • Great Britain
                          #32
                          hello mr mon2
                          I checked U5210, all pins are 0 V
                          and R5218 & R5219 is 0 V
                          • mon2
                            • Dec 2019
                            • 14012
                            See attached. Confirm the voltage to ground readings for each of these points of interest.
                            The I2C lines should NOT be @ 0v unless they are being pullled down due to some even OR the pull-up voltage rails are missing.
                            You are checking for the presence of the pull-up voltage rails.
                            I2C is an open-drain design. This means the logic IC can drive the pin LOW = 0v but not a logic HIGH. Instead, when it is a 'high', the trace is floating or high impedance. Respectively, the pull-up resistor(s) must be present AND they must be pulled to an active voltage like you see in the attached diagram.
                            If the voltages are missing, the I2C lines will be parked into 0v state and the interfaced logic will fail to operate (ie. webcam, backlight, etc.).
                            • XVLZ
                              • Nov 2022
                              • 45
                              • Great Britain
                              #34
                              i just checked all the lines you mentioned, on all lines 0 v
                              the motherboard was connected, including the charging was connected, but the display cover was closed
                              upd I measured the voltage on the pins in the attachment
                              • mon2
                                • Dec 2019
                                • 14012
                                Having the display cover closed will cause the backlight to be off. Can you test with the display cover open?
                                • XVLZ
                                  • Nov 2022
                                  • 45
                                  • Great Britain
                                  #36
                                  my bad..
                                  see attachment
                                  upd maybe some previous measurements should also be done with the display cover open?
                                  • mon2
                                    • Dec 2019
                                    • 14012
                                    Much better readings. Can you test the I2C lines again with the display lid open? That is, now you are measuring the voltage to ground on the OTHER side of each resistor.
                                    It is important that they are NOT @ 0v when the pull-up voltages are active.
                                    • XVLZ
                                      • Nov 2022
                                      • 45
                                      • Great Britain
                                      #38
                                      done
                                      • mon2
                                        • Dec 2019
                                        • 14012
                                        These are good readings. These set of I2C lines are ok.
                                        Can you check the EN pin again on the backlight (with the display lid open) ? Do you see ~3v on the EN pin or is it still 0 volts.
                                        If 0 volts, continue to check the mux pins..
                                        See attached. Check the voltage to ground of these lines which are linked to the MUX (multiplexer) that is used to enable / disable the backlight.
                                        • XVLZ
                                          • Nov 2022
                                          • 45
                                          • Great Britain
                                          #40
                                          EN at 17 pin U8400?
                                          do you mean R8442 and C8442?
                                          and can you tell me which mux you mean? can you give the boardview element number?
                                          upd I saw which mux you mean, thanks)
