New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Macbook Pro A1990 (820-01814) no backlight display
Re: Macbook Pro A1990 (820-01814) no backlight display
Good reading and matches the 47k pull-down resistor shown in the schematic.
Meter in DC volts mode (10 volts or higher is ok). Power on. Measure the voltage to ground of this same test point. We are checking if the voltage to enable the backlight is originating at this MUX IC or not? This MUX IC outputs the logic '1' or '0' near this local resistor = ball # 12 of the MUX IC (BGA package). However, we are unable to probe the ball directly so this local resistor should suffice.
What is the voltage to ground @ R9833, pin # 2 ? Measure with care since the power is ON.
Very good but confirm again that with power off, R8442 is ~47kohms ??
This should be ~0 ohms so if accurate, R8442 is clearly defective. This is a tiny resistor but with care, you can flux it and remove it. You can actually blob with a sharp point on the soldering iron to short the PCB pads. That is, apply a bit of solder on your soldering iron and just dab the 0201 pads on the PCB.
Just be careful to NOT short to the cap that is missing beside this resistor. The cap is going to ground so we do not want this 3v3 signal going to ground. It has to reach pin # 17 of the backlight IC.
PS: Before you power up after this R8442 bypass - post a pic for a quick review of the work.
PS #2 - after you blob it -> you can apply IPA (alcohol from Costco works well here) & Q-tip to clean up the flux so you can actually see the soldered pads once again.
It is a very common 0 ohm 0201 smd size resistor. It is meant to be a 'jumper'.
Remove all power -> meter in resistance mode -> check the resistance to ground of R8442 but measure the OTHER side of this 0 ohm resistor = pin # 2. This pin # 2 will be the side going to the backlight IC.
We want to know the resistance to ground of pin # 2 on R8442.
Yes, this high resistance can impact the operation of the backlight.
From your earlier posts, when you apply power, pin # 2 of R8442 = 0 volts ?
Inspect this part of the PCB to be sure there are no solder faults.
In summary, if the resistance to ground of pin # 2 of R8442 is not low, then you can just apply a small solder blob to bypass R8442. It is the same effect.
You will have to do this with care since the part is very small and will require a steady hand.
or I just need to remove it and connect directly pin 1 and pin 2 of R8442?
then what is the role of this resistor? is it okay if we directly connect two pins? Could this affect the performance of the laptop in any way? Or is it better to replace it with a new one?
If the resistance is not ~0 ohms, then this resistor is defective.
Apply flux and reflow with low air pressure. Perhaps not soldered or was moved from earlier work. Use low air so the part does not go flying. Then allow it to cool and check the resistance again across the pins of this part.
I think that you may be measuring incorrectly.
When checking the resistance of R8442, apply one meter probe on pin #1 and other meter probe on pin #2 of R8442. This reading should be ~0 ohms to match the schematic.
The 47k resistance you are reading is from the pull down resistor that exists on the same signal line.
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
Here’s what I’ve observed so far:
When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
Hi
I have the exact same fault as princepal
No display, no backlight, BL_PWR_EN = 0V
Lid sensor works fine, also ext display via USB works fine.
I don't have a spare display available for testing, any idea how to proceed?
Hi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
Battery replaced with another unit → same problem.
ISL9239 replaced → no change.
SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
Any ideas or advice would be a huge help!
Thanks in advance for your time.
i got a A1990 which shows strange colors. Sometimes looking faded or like a water mark and only visible when the cursor moves over the spot. With an external display everything looks fine.
So is there anything i can do on my own to fix this issue?
It doesn't look like the flexgate macs i have seen....
