A1990 cant install OS after SSD nand repalced
  • sajidmirza
    • Aug 2021
    • 24
    • india
    Got A1990 with ssd nand ic shorted.Repalced all the nand ic from same donor board.Restored in apple configurator successfuly and booted to recovery.Its high siera recovery.But when i try to insatll OS from internet recovery it gives error "Recovery server could not be contacted".tried at different places thinking of low internet but still getting same error.Tried date adjustment from terminal also.
    i have heard that we cant install OS from high siera recovery at the moment.Is it true.If yes how to update recovery to latest one.tried to restore several times from AC2 but still getting same high siera reacovry.
    Cant install from external drive as it is security protected.
    Can any guide how to install OS in this mac.
  • anhbanxoi
    • Sep 2021
    • 180
    • VN
    Re: A1990 cant install OS after SSD nand repalced
    Try with Cmd + Opt + R to install lastest macos version.
    • sajidmirza
      • Aug 2021
      • 24
      • india
      tried several times but it still boots to high siera recovery.
      • kevingill
        • Jun 2013
        • 152
        • England
        Have you tried any other versions of MACOS from a USB stick?
        • DoOm86
          Swap nand flash smartphone for data recovery
          by DoOm86
          Hello everyone.
          I would like to know more about the following topic:
          Nand flash on smartphone for data recovery.
          I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
          But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
          How does it works? How do I know if data are encrypted or where is the key?
          I know there are also very expensive external socket where you can put the nand flash in...
          08-20-2023, 07:10 AM
        • tranquility
          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
          by tranquility
          i want to repair an Onkyo TX-NR809 receiver.
          symptoms:
          on power on, display appears and i hear one click. enue functions is given.
          - no hdmi output
          - audio output not tested, but i think it is not there
          - usb sticks are not recognized
          if i read out the chips with display+standby button + tone+
          both dts show only ????
          chip is D830K013BZKB4
          things i have done:
          - reflow of the dts chip without taking off and reballing
          - changed the aluminium caps without the big one with 25v because i dont...
          08-25-2025, 01:04 AM
        • netboy69
          Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
          by netboy69
          Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
          02-07-2024, 04:34 PM
        • duwane
          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
          by duwane
          Hi All.
          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
          The issue:
          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
          10-26-2022, 07:02 AM
        • mattpd
          PS5 EDM-031 - Pulsing BLOD - SSD NAND chips never heat up
          by mattpd
          PS5 died in the middle of a game and never would boot again. Pulsing BLOD stays on forever but never boots.
          No LM damage. UART gives a generic "APU not responding" error.
          Under thermal camera, the SSD NAND chips stay stone cold. The controller warms, but not the NAND. I have a good 2.5v and 1.8v around the NANDs...
          I don't have a ton of PS5 experience, but I assume that the NAND would need to warm at least a little bit in order to boot...
          So to those with experience, would you expect at least a little heat from the NAND during...
          09-02-2025, 09:42 AM
