Heya, so recently a MacBook Pro 2017 A1706 820-00923 reached my table, showing no signs of life at all. I am trying to use it as an opportunity to get more into the details of fixing Apple products. What I did so far might not have been ideal, but I am trying to improve.
The story I got told:
The MacBook received a new battery at some point and later at a random point in time just stopped working. Some specialist shop tried to diagnose the issue but only tried another battery - concluded mainboard damage and returned it to the customer.
What I did and learned so far:
Visually it looks fine for the most part. The occasional solder ball or a minute amount of white debris do not really look like the issue.
U8200 got warm very quickly when powered from a 5 Volt power source (into a USB-C port on the mainboard). Measuring PP3V3_S5 to ground looked like a short (0 Ohms) to me. I desoldered U8200 to take it out of the equation, but nothing really changed. Wrong order of actions I suppose, but here we are.
The mainboard draws 1.5 Amps at 5 Volts. The CPU heats up slowly on 5 Volts, but gets hot very quickly with a 20V PD-supply.
I did not notice it at first, because at 5V 1.5A the heatsink did a great job of passively cooling it down.
Voltages:
Mosfets:
Resistance between:
Q7030:
I am suspecting a failure of the Mosfets or something in that direction, but I lack the experience to know where to look exactly and which conclusions to draw. The CPU might be gone for good, given it's intermediate role as a space heater (which . But I would still like to try to fix the rest and see for myself.
Any directions would be insanely helpful!
I did not notice it at first, because at 5V 1.5A the heatsink did a great job of passively cooling it down.Voltages:
PP3V3_G3H 3.42V
PPVIN_G3H_P3V3G3H 4.63V
PPBUS_G3H @ D6902, pin # 1 4.25V
PPDCIN_G3H_CHGR @ D6902, pin # 2 4.92V (Powerbank, 5V)
PPBUS_G3H @ F7000, pin # 2 4.25V
PPVBAT_G3H_CHGR_REG @ F7000, pin # 1 4.25V
PPDCIN_G3H 4.93V (Powerbank, 5V)
Q7030 1/2/3 4.92V
PPBUS_HS_CPU 4.22V
Q7030 1/2/3 4.92V
PPBUS_HS_CPU 4.22V
Mosfets:
Resistance between:
1. source & drain
2. source & gate
3. gate & drain
2. source & gate
3. gate & drain
Q7030:
1.1 630kΩ S1/D2-D1
1.2 -200kΩ S2-D1 going up
1.3 2000kΩ S2-S1/D2 going up
2.1 inf S1/D2-G2
2.2 1960kΩ S2-G2
2.3 2000kΩ S2-G1 going up
2.4 0kΩ S1/D2-G1
3.1 1920kΩ Ohm D1-G1 going up
3.2 0kΩ S1/D2-G1
3.3 2000kΩ D1-G2 going up
3.4 inf S1/D2-G2
Q7040:1.2 -200kΩ S2-D1 going up
2.1 inf S1/D2-G2
2.2 1960kΩ S2-G2
2.4 0kΩ S1/D2-G1
3.2 0kΩ S1/D2-G1
3.4 inf S1/D2-G2
1.1 50kΩ S1/D2-D1 going up slowly
1.2 -374kΩ S2-D1
1.3 555kΩ S2-S1/D2
2.1 1910kΩ S1/D2-G1
2.2 inf S1/D2-G2
2.3 inf S2-G1
2.4 1920kΩ S2-G2
3.1 inf D1-G1
3.2 inf D1-G2
3.3 1910kΩ S1/D2-G1
3.4 inf S1/D2-G2
1.2 -374kΩ S2-D1
1.3 555kΩ S2-S1/D2
2.1 1910kΩ S1/D2-G1
2.2 inf S1/D2-G2
2.3 inf S2-G1
2.4 1920kΩ S2-G2
3.1 inf D1-G1
3.2 inf D1-G2
3.3 1910kΩ S1/D2-G1
3.4 inf S1/D2-G2
