Dell Inspiron 15 LA-9982p No power help please
  • harshana
    • Aug 2022
    • 216
    • Sri Lanka
    Motherboard: LA-9982p Rev3.0
    when I turn on power light appears but no display and even the fan is not spinning. I tested all the voltages.
    everything seems fine when standby stage. when I press power button, laptop takes around 0.6A and CPU/PCH heating(cause fan doesn't spin)
    when I check main signals I saw that SLP_S3# is missing and 1.4v at SLP_S4.
    also SUSP# missing. because of that No power at bios 8th pin.
    SUSP# and SLP_S3# resistance seems OK.
    Can you guys help me please. I have no idea to continue from here. Is this about faulty CPU? or is there any luck to fix this.
  • mon2
    • Dec 2019
    • 14698
    Re: Dell Inspiron 15 No power help please
    Hi.
    What is the voltage of CHG_B+ ? This is the #1 voltage required to get started.
    Voltage of ACOK on PU701 (charger IC) ?
    Not familiar with these models but you can review the following:
    1) susp# appears to be driven by the EC controller but the group of pins on the EC are marked as GPI which should mean as 'input only' ??
    2) is U2302 bios being powered at pin # 8 ? (+3VS)
    3) study the block diagram on sheet 46 for the power diagram
    a) do you see the DCin voltage reach the logic board when ON ?
    b) each regulator onboard is using this higher DCin voltage to power lower power rails (buck convertors) - confirm each voltage at the local coils.
    4) with NO power / no battery -> check the resistance to ground of the +CPU_CORE. This is to check if the CPU could be possible damaged already.
    • harshana
      • Aug 2022
      • 216
      • Sri Lanka
      Originally posted by mon2
      Hi.
      CHG_B+ ———> 19v
      PU701 (ACOK)——> 3.7v
      1. according to schematics SUSP# is both input and output I guess.
      2. No. U2302 has no power at pin 8.
      3.
      a) DC in voltage is appearing.
      b) I can only see 3v and 5v at coils.
      SYSON, VRON# and SUSP# signals are missing even after power btn. because of that I can’t see 1.5v and 1.35v
      This motherboard doesn’t have VGA chip.
      4. with no power CPU CORE resistance is 144ohms. seems like good.
      Any luck ???
      • mon2
        • Dec 2019
        • 14698
        Is the EC being powered? Measure the voltage.
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          yes. Pin 9,22,33,96,111,125 and 67 have 3v.
          • mon2
            • Dec 2019
            • 14698
            Review this thread:
            https://www.badcaps.net/forum/showthread.php?t=90578
            • harshana
              • Aug 2022
              • 216
              • Sri Lanka
              In my case RSMRST# is present after pressing the power button.
              SIO_SLP_S4# also present. but SLP_S3# missing
              • mon2
                • Dec 2019
                • 14698
                Wait on others to comment but from:
                https://www.leakymosfet.com/blogs/ne...op-motherboard
                If SLP_S4# and SLP_S3# does not come out when the power button is pressed, you may need to reflow, reball or replace the PCH.
                Last edited by mon2; 09-13-2022, 04:44 AM. Reason: Fixed the crazy auto fill keywords
                • harshana
                  • Aug 2022
                  • 216
                  • Sri Lanka
                  according to the link you sent, SLP_S5# should present before slp_s3.
                  But SLP_S5 is missing.
                  RTCVCC has 3.3v
                  I am unable to test other signals related to rtc because there is no sodler pad to test.
                  How can I test RTC Section? Or dont I need to test that section. What should I do next???
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    any luck
                    • mon2
                      • Dec 2019
                      • 14698
                      Remove all power. Meter in resistance mode.
                      Check SIO SUSP# pin resistance to GND.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Re: Dell Inspiron 15 LA-9982p No power help please
                        Are u sure laptop takes 0.6A when turned on while SUSP# is missing?? Seems like impossible to me. Had you checked Q8 is working or not. Measure voltage on U2301, PIn 1-2/13-14/6-7/8-9/3/4.. Voltage on J513(3VALW_PCH) is present??
                        I just repaired LA-9981(with graphics). Was dead. 3/5V PWM ic was corroded. Replaced this regulator. When turned on light glows but consumption moves from 0.010 mA to 0.019mA only. In my case also SUSP# was missing. Replacing U2301 fixed it. Hope this helps you but no case is same-so keep that in mind.
                        PS: No need to rest RTC section for now as it turns on and power light is glowing.
                        • harshana
                          • Aug 2022
                          • 216
                          • Sri Lanka
                          SUSP# to ground——-> 76kohms (200k range)
                          • harshana
                            • Aug 2022
                            • 216
                            • Sri Lanka
                            Im facing a power cut now. I will share photographs showing the DC unit. It take 0.605A when I power on. also will check voltages at U2301. (as I remember when I test U2301, I saw input voltages are there but enable signals were missing)
                            Unfortunately Still I wasn't able to find Q8 on my board. if you own boardview for this laptop, can you share with me please
                            • harshana
                              • Aug 2022
                              • 216
                              • Sri Lanka
                              Voltages at U2301 after power on.
                              1,2—-> 5v
                              13,14—->0v
                              6,7——>3.3v
                              8,9——->at the beginning 0.27v and after some time it turn into 0.96v
                              3—>0v
                              4—->5v
                              5—-> 0v
                              Voltage at J513 ——-> 3.24v
                              here I attached DC unit photo also when I power on. still Im unable to find Q8
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Q8 is located near Audio jack(between audio jack and 51225C IC). Its a 2N7002 mosfet. Just replace it with any mosfet marked 702/K72/S72 which you can get plenty from scrap boards.
                                Yes, indeed your consumption indicates a short somewhere.Under normal circumstances, when SUSP# is missing on this mb, consumption wont exceed 100mA (after turning on) as SUSP# is the enable for almost each and every IC.
                                Measure resistance on each and every coil in ohms mode without power.
                                • harshana
                                  • Aug 2022
                                  • 216
                                  • Sri Lanka
                                  I replaced Q8 with S72 mosfet. Still nothing changed.
                                  when I test resistance at coils the lowest resistance I was 70ohms at PL301 and another lowest was 90ohms at PL502.
                                  I guess Thats normal. May be I was wrong.
                                  Important thing is CPU is heating. Thats the guy who takes that 0.6A after power sw on. CPU died??? or can we continue ??
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    When SUSP# is missing, Vcore cant rise.So cpu should'nt heat at all. Please confirm whether CPU is heating or PCH part of SOC is heating?? However, both the parts of SOC shouldnt heat in absence of SUSP#.My doubt goes towards a shorted SOC or any rail which goes to SOC.
                                    • harshana
                                      • Aug 2022
                                      • 216
                                      • Sri Lanka
                                      I see square and rectangle there. square part is heating up. My mistake. PCH is the part heating up. I thought its cpu.
                                      anyway Means PCH dead or continue?
                                      • harshana
                                        • Aug 2022
                                        • 216
                                        • Sri Lanka
                                        Any Luck
                                        • LimesKey
                                          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                          by LimesKey
                                          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                          10-17-2025, 05:33 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • Tomylee
                                          Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
                                          by Tomylee
                                          I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
                                          Here’s what I’ve checked so far:
                                          No reaction when pressing the power button (no LEDs, no fan).
                                          The power adapter works fine (tested).
                                          One chip gets extremely hot as soon as I plug in the charger.
                                          The capacitors around that area are not shorted.
                                          I’m attaching photos of the board to show the issue.
                                          Based on this, what kind of fault or defective component could be related to this overheating?...
                                          10-19-2025, 12:24 PM
                                        • madura2010
                                          Dell inspiron 3168 (15299-2) no power
                                          by madura2010
                                          Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
                                          But after removing battery, worked perfectly.
                                          next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
                                          But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
                                          Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
                                          01-28-2024, 09:10 PM
