Dell Inspiron 15 LA-9982p No power help please
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Inspiron 15 LA-9982p No power help please
    Very likely shorted PCH. What is the exact resistance(no power connected) at PL301?? Are you getting +1.05V(I beleive no as SUSP# is the enable and missing)??
    • harshana
      • Aug 2022
      • 216
      • Sri Lanka
      PL301 —-> 70ohms
      No I can’t see 1.05v
      • Sephir0th
        • Oct 2020
        • 1289
        Beside the sum of measurements which does not fit to the observations I totally agree with mcplslg123:
        Without this early sequences present the CPU can't heat up. On the other side we have way way to much consumption for the actual state of the board, even when we take a short in mind.
        Also the heating PCH points to a short exactly there. On the other side the resistance of the 1.05V is still fine. But what about the 3VALW? If the resistance is fine there too there is still no reason for this high consumption confirmed then
        So we probably have missing infos and for sure some wrong measurements here, which let us drive in circles.
        How hot in fact is the PCH die. Can you still touch it or will it burn your finger?
        FairRepair on YouTube
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          Im away from the board now. But Im sure resistance of 3VALW was okay. and also I saw 3.3v there.
          currently PCH is under a heatsink and for sure it will burn my finger after few seconds if I remove the cover.
          this only happen after I press power button. before the power on signal, everything is normal. No heat appears on PCH before the power signal
          • harshana
            • Aug 2022
            • 216
            • Sri Lanka
            any luck
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              As @sephir0th has already mentioned, I still cant see any reason for PCH heating up as resistance on both 1.05V and 3.3V is ok as per your observations. Since the mb is trigerring, i dont think RTC section is shorted.Honestly, i couldnt figure out the reason for high consumption in absence of SUSP# signal.
              • harshana
                • Aug 2022
                • 216
                • Sri Lanka
                #27
                Here is the reason as I found.
                When I press the power button U2304 gets PCH_PWR_EN signal. (this signal enable PCH power. thats why PCH is heating.
                when I test the resistance of 3VALW_PCH, it only has 55ohms.
                I tested this rail at J513. Is that okay?? I think its lower. what do you think?
                • Sephir0th
                  • Oct 2020
                  • 1289
                  55Ohms at +3VALW_PCH is in fact a partial shorted 3.3V and most likely the reason for the hot PCH. So the 3.3V is not okay like already assumed before.
                  PCH is dead, board is donor.
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    #29
                    Thank you for the support. Csn you please check my other thread as well. Im stuck there also. Here is the link
                    https://www.badcaps.net/forum/showthread.php?t=109457
                    • LimesKey
                      Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                      by LimesKey
                      Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                      10-17-2025, 05:33 PM
                    • zlr8r
                      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                      by zlr8r
                      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                      Ill try and give as much info as I can.
                      Dell Inspiron 17 (7786) Laptop
                      Service Tag: 5J0NHT2
                      Bios: 1.9.0
                      When I received this , it would only flicker on the KB backlight for a second, then off and on.
                      Then it started getting weirder!
                      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                      12-12-2023, 09:31 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • Tomylee
                      Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
                      by Tomylee
                      I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
                      Here’s what I’ve checked so far:
                      No reaction when pressing the power button (no LEDs, no fan).
                      The power adapter works fine (tested).
                      One chip gets extremely hot as soon as I plug in the charger.
                      The capacitors around that area are not shorted.
                      I’m attaching photos of the board to show the issue.
                      Based on this, what kind of fault or defective component could be related to this overheating?...
                      10-19-2025, 12:24 PM
                    • madura2010
                      Dell inspiron 3168 (15299-2) no power
                      by madura2010
                      Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
                      But after removing battery, worked perfectly.
                      next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
                      But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
                      Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
                      01-28-2024, 09:10 PM
