HP G62 No Power Issue
  • harshana
    • Aug 2022
    • 215
    • Sri Lanka
    MotherBoard: DA0AX1MB6H1 REV H
    I tested this board with my current knowledge and I found these things.
    19v rail ----> OK
    3.3v Rail -----> OK
    5v Rail --------> OK
    1.05v Rail ------> Missing
    When I check 1.05v controller (PU8), I noticed that LEN Pin which needs to generate LDO is missing.
    According to the schematics LEN pin receive <MAIN_ON> signal from the IO chip.
    I guess this signal should present before power switch on. May Be I was wrong because I have very poor knowledge about signals.
    However I can see 3v in BIOS chip and also IO chip.
    Here I attach the schematics for your reference. Please help guys. Where to go. Im stuck.
  • harshana
    • Aug 2022
    • 215
    • Sri Lanka
    Re: HP G62 No Power Issue
    I was Wrong. MAINON signal is only present after power on switch. However the thing I noticed now is RSMRST# is missing.
    What should I do
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      check VCC for SIO and AC_IN. Flash bios
      • harshana
        • Aug 2022
        • 215
        • Sri Lanka
        VCC and ACIN -----> OK
        I see there are 2 winbond Chips.
        One chip has 3v on its 8th pin and Other one has no power. Is that normal???
        Here I attach the images.
        • harshana
          • Aug 2022
          • 215
          • Sri Lanka
          • mon2
            • Dec 2019
            • 14552
            Is U12 stuffed (soldered) on your PCB ?
            • harshana
              • Aug 2022
              • 215
              • Sri Lanka
              Yes both chips soldered
              • harshana
                • Aug 2022
                • 215
                • Sri Lanka
                I see that the U12 is main BIOS which needs to have 3v at pin 8. But the voltage is 0. Is that normal??? No voltage at power switch as well. I see 3v is missing on some places but the thing is 3.3v available on EC bios.
                • mon2
                  • Dec 2019
                  • 14552
                  You will have to confirm if the rail is fed from the same source which it appears to be. Have too many other fires in the building to hunt this one down but check the schematic. Perhaps you have a blown trace on the PCB but check for the main regulator that powers this BIOS.
                  Found it...see attached.
                  Measure the voltage on mosfet @ PQ20. This section of the circuit needs a review if the +3v is not enabling.
                  Also - +3v is NOT +3.3v - important to note this in your repair. Separate rails.
                  • harshana
                    • Aug 2022
                    • 215
                    • Sri Lanka
                    My bad. I thought 3.3v ok means 3v okay. Just noticed that PQ20 has 0v out. when I check gate 0v at there also.
                    So I looked PR110 and I see it only has 6.38v which needs to be 10v always pwer.
                    I should recheck 10v always power line I guess. Am I correct?
                    • harshana
                      • Aug 2022
                      • 215
                      • Sri Lanka
                      Here What I found.
                      When MAINON signal is low, PQ37 doesn't start to flow. because of that PQ19 & PQ32 gates are high, which connects the power line to the ground.
                      According to my knowledge, if we need 3v and 5v to be present, then MAINON signal should be high.
                      I can guess those voltages are only work when the system is at on stage. So Main bios will not power up until IO send MAINON signal.
                      However 3v which should appear in power switch also missing.
                      What do you think? May I try to flash EC bios???
                      I don't have a bios programmer. But I heard that I can use arduino to do that. What should I do.
                      • harshana
                        • Aug 2022
                        • 215
                        • Sri Lanka
                        I did a small research about bios programing using Arduino and the things I noticed is arduino produce 5v which is not suitable for the chip. however, I found that the raspberry has 3.3v. So I will flash using raspberry. Will update the progress soon.
                        • usyusy
                          • Sep 2021
                          • 171
                          • Pakistan
                          this may be normal, as in some boards, Main Bios has voltage after pressing power-button, as sir mcplslg123 suggested flash clean and tested BIOS for both EC bios and main bios.
                          for flashing winbond chips, ch341a programmer is ok
                          • harshana
                            • Aug 2022
                            • 215
                            • Sri Lanka
                            I ordered Ch341a programmer but It will take around 30-40 days to deliver. So I planed to use raspberry Pi 3 Model B to flash bios. Hope it will work fine. Let's see.
                            • harshana
                              • Aug 2022
                              • 215
                              • Sri Lanka
                              I flashed EC bios still nothing. Even there is no 3v at power button. No RSMRST#
                              What should I do
                              • harshana
                                • Aug 2022
                                • 215
                                • Sri Lanka
                                In schematics there is a resistor called R74 which connects 3v to power switch. It was missing. I soldered a resistor there and now I see 3v on power button. but still nothing happens
                                • Sephir0th
                                  • Oct 2020
                                  • 1283
                                  Lid Switch is always something worth to check. Also check for unexpected short at logic signals which should show voltage.
                                  FairRepair on YouTube
                                  • harshana
                                    • Aug 2022
                                    • 215
                                    • Sri Lanka
                                    lid switch line has 3v.
                                    What signals should I check mainly?
                                    • Sephir0th
                                      • Oct 2020
                                      • 1283
                                      The power switch line for example and RSMRST# line for example. Also detailed visual inspection of the EC and surrounding area. Who knows what you'll find
                                      • harshana
                                        • Aug 2022
                                        • 215
                                        • Sri Lanka
                                        I can't see any short to ground from power switch amd RSMRST#
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • reessi
                                          HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                                          by reessi
                                          I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                                          It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                                          What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                                          I have checked these lines in diode mode and they seam normal -> 600.
                                          I have checked to see if they come on for even a fraction of a second...
                                          07-15-2025, 09:14 AM
                                        • shellybelly
                                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                          by shellybelly
                                          Back Story
                                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                          08-27-2023, 10:40 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
