Macbook A1706 EMC3071 (2017 Touchbar)
  • mon2
    • Dec 2019
    • 14681
    Re: Macbook A1706 EMC3071 (2017 Touchbar)
    Resistance is ok on the diode.
    Next, power the logic board and measure the voltage to ground on the same diode pins. Post the readings.
    Too busy at the office.. vendor meetings today. If you read 0v then likely a short on the default Vbus line on the usb connector. The power supply is shutting down. Test another port on the logic board as well.
    • kurtspirit
      • Feb 2019
      • 112
      • France
      #62
      I understand, no problem. Thank you for your time !
      So, Pin #1 : 5V, Pin #2 : 5V, Pin #3 : 4.75V.
      Is it ok ?
      • mon2
        • Dec 2019
        • 14681
        Voltage is fine at the diode.
        Check the voltage to ground at the coil on the output of U6903. Measure on both sides of the coil.
        What is the measurement?
        • kurtspirit
          • Feb 2019
          • 112
          • France
          #64
          If you talk about the L6900, i have 3.7V on both side. Is it correct ?
          • kurtspirit
            • Feb 2019
            • 112
            • France
            #65
            I don't want to spam but are you allright ? I hope you're fine.
            • mon2
              • Dec 2019
              • 14681
              Hi. Thanks for asking. Actually, no. Facing a personal hell.
              Last Saturday night, a drunk driver ripped through our company building and stopped about half way in. Destroyed lots of expensive equipment, inventory, my workspace, furniture. The emergency crew killed our fire door and my office. Building damage at $250k (estimated). Clean up crew is onsite and I need to go through boxes and boxes of damaged goods to then receive some sort of compensation. Our 40 year old business is at a stand still. We now have hydro, phone and heat back while our winter starts. Glass everywhere. No ceiling. Not fun times. I do have internet access now. Will monitor this thread to avoid depression. My wife does not want to even view the building pics. This is a business I started as a teenager and we supply key clients with our custom products. Hope to pass onto our son. Have meetings tomorrow for the inspection of our SMT line to review that damage. Will update you more later.
              • kurtspirit
                • Feb 2019
                • 112
                • France
                #67
                Wow! I'm sorry for you and your family, sincerely!
                I don't know what to say, the situation seems terrible, so I'm just going to cross my fingers for you. Maybe you have an insurance that can help you even if I don't know if it works like at home in France?
                I am totally helpless and unfortunately cannot bring you much except my total support.
                Courage to you and yours and I hope it will be able to "work out" soon enough.
                Take care of yourself !
                • redoxy
                  • Sep 2018
                  • 100
                  WOW!!
                  Sorry to hear this as well. I'm sure lots of people on this forum will be as you have been selfless in helping complete strangers.
                  Hopefully, there were no injuries to any of your staff.
                  I hope this gets resolved and you are able to get back to some level of normal operations soon.
                  • mon2
                    • Dec 2019
                    • 14681
                    Thank you for your kind words. Lots of office work ahead.
                    See attached. The 3v7 on PP3v3_G3H is too high. It should be 3v3. Suspecting that the feedback resistors may be at fault.
                    Remove the resistor @ R6915 (do not lose it).
                    Then power up again and confirm the voltage is still 3v7. Then with NO power, review the feedback resistors noted in the partial schematic. These values must be the same as the official schematic to dial up the 3v3 voltage. Only after this voltage is normal, then place back R6915. Rossmann forum notes this rail should be 3v3.
                    • kurtspirit
                      • Feb 2019
                      • 112
                      • France
                      #70
                      I hope you are well today despite your situation..
                      So, i remove the R6915 and i have 3.40V on L6900.
                      For the resistors, here are the measurements :
                      R6910 : 110kohm
                      R6911 : 110kohm
                      R6913: 47hohm (?!)
                      Strangely, the R6910 look like a capacitor. It's a white spare, not black as usual for resistor.
                      What do you think ?
                      Thank you
                      • mon2
                        • Dec 2019
                        • 14681
                        Attached is the layout I see in the database for this logic board.
                        Can you confirm that yours is the same?
                        Are you using fresh batteries for your meter? It is recommended so that we can rule out the tool as a fault of the values.
                        • kurtspirit
                          • Feb 2019
                          • 112
                          • France
                          #72
                          It's exactly the same as the layout. It have Resistor / Condensator / Resistor / Resistor.
                          I do a fresh mesurement :
                          R6912 : 12.2ohm
                          R6910 : 54kohm
                          R6911 : 12.95kohm
                          R6913 : 1.45kohm
                          Stranges values no ?
                          • mon2
                            • Dec 2019
                            • 14681
                            Yes, only some of the values match.
                            With care, flux and remove R6910 & R6911 off the board. Check their values when the parts are off the board and on your table.
                            Will assume that the values in the schematic are correct.
                            So R6910 should be 115k (1% is recommended).
                            R6911 should be 47K (1% is recommended).
                            Other 2 resistors are fine. If you do not read these values after the resistors are removed, consider to replace them and measure again.
                            • kurtspirit
                              • Feb 2019
                              • 112
                              • France
                              #74
                              I remove the resistors and out of circuit, they have goods values. If i replace them on board, the values return to my last measurements...
                              • mon2
                                • Dec 2019
                                • 14681
                                Ok. If the IC has been replaced, consider to replace the resistors in this leg of the circuit, they are very inexpensive.
                                From this thread, the voltage output should be 3v3 at the end of the exercise.
                                https://boards.rossmanngroup.com/thr...0-00239.60462/
                                • kurtspirit
                                  • Feb 2019
                                  • 112
                                  • France
                                  #76
                                  I just make the same measurements than the thread... Results are really bad :
                                  PPDCIN_G3H_CHGR = 5 V
                                  PPVBAT_G3H_REG = ?
                                  PPBUS_G3H = 0 V
                                  PP5V_S4 = 0 Volt
                                  PP3V3_S5 = 0 Volt
                                  P3V3G3h = 4.79 V
                                  3V0_G3H = 0 V
                                  L7030 = 0.730M
                                  L8410 = 109k
                                  L7660 = 15k
                                  L7600 =33K
                                  L3500 = 16K
                                  I don't understand what happen with this board :/
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • BillyJ
                                    2017 Apple MacBook Pro 13 inch touchbar A1706 - Not turning on - PPBUS Short?
                                    by BillyJ
                                    Is there a boot-up sequence for the A1706 (Kaby lake) to see where the computer is getting stuck? Equiv to the below for older MBP's?
                                    https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
                                    currently I measure:
                                    PP20V_USBC_XB_VBUS = 20
                                    PPDCIN_G3H_CHGR = 20.4
                                    PPDCIN_G3H = 20.4
                                    SMC_RST_L = 3.4
                                    PM_EN_P3V3_G3H = 5.2
                                    PP3V3_G3H = 3.4
                                    PPBUS_G3H = 0V (2.1 Ohm to GND - ISL9239 failure?)
                                    S5:
                                    PP3V3_S5 = 0
                                    PP5V_S5 = 0.346
                                    PPBUS_HS_OTH3V3 = 0.0186
                                    PPBUS_HS_OTH5V = 0.0186...
                                    01-02-2022, 03:54 PM
                                  • sofles
                                    Macbook a1707 2017 model 820-00928 GPU issue
                                    by sofles
                                    Hello there
                                    I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                    I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                    11-21-2024, 05:25 AM
                                  • Tennen
                                    MacBook Pro 2017 A1706 820-00923 no power, low voltage PPBUS_G3H
                                    by Tennen
                                    Heya, so recently a MacBook Pro 2017 A1706 820-00923 reached my table, showing no signs of life at all. I am trying to use it as an opportunity to get more into the details of fixing Apple products. What I did so far might not have been ideal, but I am trying to improve.
                                    The story I got told:
                                    The MacBook received a new battery at some point and later at a random point in time just stopped working. Some specialist shop tried to diagnose the issue but only tried another battery - concluded mainboard damage and returned it to the customer.
                                    What I did and learned...
                                    10-20-2022, 07:26 PM
                                  • modtool
                                    Macbook Pro A1989 fallen, reboots if touchbar connected
                                    by modtool
                                    Hi to all,
                                    the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                                    Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                                    11-10-2023, 07:42 AM
