Alienware 15 R3 Motherboard Issues Help Plz!
  • z32KRAzY
    Eager to learn!
    • Aug 2022
    • 37
    Re: Alienware 15 R3 Motherboard Issues Help Plz!
    Originally posted by Sephir0th
    Nobody noticed? From measurements one of your DC-IN MOSFET is internal shorted sind ACDRV doesn't reach 25V. Should be easy to solve from here.
    Okay so how do I determine which MOSFET it is? I've read the charging circuit sticky, and looked over the datasheet for the charge controller, sadly I just don't understand it enough to figure it out. I don't know which pins indicated to you that there is a shorted MOSFET, I am trying to figure it out on my own but I am just not seeing it.. Thanks for your time and interest! Could I get another hint perhaps? =)
    • sikocan
      • Oct 2019
      • 344
      PQ707, PQ701, PQ708, PQ702. With no power or battery check in resistance mode Gate to Source on all of them maybe.
      See pic.
      • sikocan
        • Oct 2019
        • 344
        Schematics if needed.
        • z32KRAzY
          Eager to learn!
          • Aug 2022
          • 37
          Okay I was just testing the mosfets in the area to see if any showed all pins shorted and pq701 has all pins shorted, is that my bad one then?
          EDIT: I checked pq707 and pq702, they are on the other side of the board, and pq707 is also shorted all pins. So would that mean both are bad? Thank you guys so much!! I feel like I'm so close to having this solved! =D
          • z32KRAzY
            Eager to learn!
            • Aug 2022
            • 37
            Just checking source to gate all 4 show source to gate shorted.. I'm checking pin 1 to 4, hopefully that's correct. I was trying to figure it out on my own before I saw the last couple posts..
            • mon2
              • Dec 2019
              • 13948
              How are you measuring the resistance?
              Which scale on your meter is being used?
              What are the exact meter readings?
              • z32KRAzY
                Eager to learn!
                • Aug 2022
                • 37
                I am just using auto range, if that's what you mean by scale?
                pq701 0.3 Ohms
                pq708 0.6 Ohms
                pq707 0.2 Ohms
                pq702 0.3 Ohms
                These are pin 1 to pin 4
                • mon2
                  • Dec 2019
                  • 13948
                  Remove PQ702 and check if short is gone.
                  Then remove pq708 and check again if required.
                  Do not power up after removing the mosfet (s).
                  • sikocan
                    • Oct 2019
                    • 344
                    It's quite rare for so many Mosfets to be shorted. Gate which connects to BQ is probably fault at, let's see.
                    • z32KRAzY
                      Eager to learn!
                      • Aug 2022
                      • 37
                      Should I not remove the MOSFET(s) then? I'll have to do it a little either way but I found all my equipment that I need I think.. It's been so long since I have used this stuff, anyone have any pointers to save me having to read up on how to do this stuff again? I just don't recall the preheat temps, the air nozzle temp and I'm wondering if I have to remove the plastic ac-in connector beside it or can I just shield it with some foil tape? Thanks!!
                      • piernov
                        • Jan 2016
                        • 4435
                        • France
                        #31
                        Gates are connected together so expected to have the same voltage on gate for all MOSFETs, and also show up on ACDRV.
                        PQ702/PQ708 are likely ok since current is flowing through body diode since they are not turned on (hence 0.6V drop).
                        Certainly a problem with PQ707/PQ701 since they are not turned on but still let current flow even though they are in reverse. They are in parallel so either or both could have a problem.
                        Schematics show 4.7 ohms resistor before gates of PQ707/701 so resistance measurement of PQ708/PQ702 are a bit surprising. Can be confirmed after isolating the issue with PQ707/PQ701.
                        • z32KRAzY
                          Eager to learn!
                          • Aug 2022
                          • 37
                          Okay I get it. I am back home now, I will get setup and pull one. Thank you!!
                          • z32KRAzY
                            Eager to learn!
                            • Aug 2022
                            • 37
                            I apologize, my girlfriend came over so I had to put everything away then set up again after she left.. I pulled pq702, now what would I test next? Ty!!
                            • sikocan
                              • Oct 2019
                              • 344
                              Check the MOSFET outside, still sorted? Replace it.
                              • z32KRAzY
                                Eager to learn!
                                • Aug 2022
                                • 37
                                Okay so this is a little bit frustrating.. The mosfets are marked with a circle on one side which I took as the indication that that was the side with pin 1. After removing the first mosfet looking at the bottom I can see that pin 1-4 are connected on the bottom side of the chip, so I don't know what's going on, it appears the chip is marked reversed. The mosfet isn't the same chip that the schematic showed being used for the mosfets but I looked at it's datasheet and it says the pinout is the same as the one the schematic shows but looking at the bottom of the chip pins 1-4 are clearly the drain. So I hope I don't have to put it back just to remeasure.. Anyway, retesting the resistance of the source to gates now that I know they are marked in reverse, and assuming they are all marked backwards, here's the results.
                                Pq702 - 5.8M Ohm (removed from board)
                                PQ707 - 12 Ohm
                                PQ708 - 6.6 Ohm
                                PQ701 - 2.1 Ohm
                                Should I put pq702 back?
                                Thanks guys.
                                EDIT - attached picture, the side with the big circle is not the side with pin 1.. 😕
                                • mon2
                                  • Dec 2019
                                  • 13948
                                  Ok. Just need to get your orientation correct for these parts.
                                  When you review the datasheet -> place the component on your table and review the dimple or white dot which should be located to the TOP LEFT corner of the mosfet.
                                  That is pin # 1.
                                  Below it, still on the left is pin # 2 -> # 3 and # 4 (end).
                                  Now counting in a 'U' shape, BOTTOM RIGHT side = pin # 5 -> # 6 -> # 7 -> #8 (TOP RIGHT of the mosfet).
                                  ICs work and count in the same manner.
                                  On these mosfets, pins 5-6-7-8 are all shorted together to allow for heavy currents to travel through the device = DRAIN pin cluster.
                                  So back to 1-2-3 = grouped together = SOURCE pin cluster.
                                  Only pin # 4 will be by itself = GATE.
                                  Now, when you solder this back onto the PCB, locate the side of the PCB pattern that has pins 5-6-7-8 shorted together. Check it with your meter first.
                                  You are placing the pins down and the datasheet has the 'superman x-ray view' so you are looking through the device to solder onto the board.
                                  Hope this is clear.
                                  If you are observing that this removed mosfet is NOT fixing the short, just make a note of it and proceed to remove another.
                                  @Piernov mentioned above that he suspects the FIRST 2 pair should be reviewed for this shorted part.
                                  Either way, my suggestion is to only draw a small diagram of which parts are where and make a note of the pin # 1 of each so you can solder them back. Also suggest to leave the parts off the board till you locate the short.
                                  One mosfet can make this board look shorted.
                                  • z32KRAzY
                                    Eager to learn!
                                    • Aug 2022
                                    • 37
                                    Okay I think I understand. One other thing, I just noticed the two mosfets on the bottom of the board are different than the top ones, they seem to be dual mosfets, each has 2x D1, 2x D2, 2x S1, 2xS2, 2x G1, 2x G2.. These are the ones in the picture from my last post. This is a picture of the ones on the top side. By top side I mean the side with the cpu and gpu..
                                    • sikocan
                                      • Oct 2019
                                      • 344
                                      Gate to source should measure in k ohms or higher.
                                      Here is a good video
                                      https://youtu.be/Xc_yIdHw0zI
                                      • z32KRAzY
                                        Eager to learn!
                                        • Aug 2022
                                        • 37
                                        So on the dual ones should I be checking g1-s1 and g2-s2?
                                        • mon2
                                          • Dec 2019
                                          • 13948
                                          The mosfets in the schematic are showing as singles. Confirm the white silk screen labels for each.
                                          Make a note of which parts are linked to where on the PCB. These are common parts and from the schematic - each mosfet is the same for these 4 mosfets.
                                          See attached which should clarify the pin # 1 and placement for the share pic.
                                          • evoman2
                                            Hp z420 motherboard (?) issues
                                            by evoman2
                                            Hello everyone! I have an old hp workstation z420. Xeon E5 1620 v2, 8gb ecc ddr3
                                            Basically, when I plug in the power cable to the power supply, it turns on and off while clicking every time it power cycles. Once I remove the power cable from the supply, it flashes a red light 4 times while beeping for about 10 seconds. I have purchased a new CPU and power supply already, but that hasnt fixed it so I'm convinced it's a motherboard level fault. If anyone has any ideas on what the fault could be, and/or how to diagnose it, that would be highly appreciated. Thanks!
                                            05-09-2025, 07:31 PM
                                          • eduardo11791
                                            ASUS STRIX GL703GE Motherboard Issues
                                            by eduardo11791
                                            Hi, pretty much new here, glad I can be part of this community. I'm new to repairing laptops motherboards (Only previous experience was repairing a Z690I STRIX with a broken trace on the memory slot, and it was a sloppy job but worked)
                                            Bit of background: I'm not new replacing Laptop parts and doing general testing. Bought multiple laptops of the same model since it's easier to repair and got some that I can either switch parts and test.
                                            ASUS STRIX GL703GE-IS74
                                            Motherboard Model: DABKNBMB8D0 Rev D All of them
                                            Issues (Each one on a separate board)...
                                            12-06-2022, 11:41 AM
                                          • Docus
                                            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                            by Docus
                                            Hi everyone 😀,
                                            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                            1. I already own the exact same model, but its plastic chassis is badly damaged.
                                            06-10-2025, 04:24 PM
                                          • paparazzo79
                                            Alienware 17 R3 freezing in games
                                            by paparazzo79
                                            Hi guys.
                                            I own Alienware 17 r3 6820HK GTX 980M.
                                            I purchased it recently tried some gaming (Rise of the Tomb Raider, Serious Sam) and after 10-15.min games freeze, but I could hear audio from game.
                                            Now I am not yet at home, but when it happens I do get separate window error message and will post it later.
                                            Then again there are moments when I could play for like an hour and no errors.
                                            From my experience reading about this issue, this means my GPU is dying, correct?
                                            I installed most recent nVidia drivers.
                                            Temp of GPU while gaming is max 76 C, but usually around...
                                            04-19-2024, 12:07 PM
                                          • amigo744
                                            PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
                                            by amigo744
                                            Hello there,
                                            ps5 cfi-1016a disk console
                                            Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
                                            After the shut down the console boots up normal and then the ps4 game functions without a problem.
                                            ps5 games run allways without any problems after cold boot.
                                            Thats absolutely curious....
                                            I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
                                            That doesen´t help
                                            Furthermore i have opened console and renew liquid metal on gpu.
                                            This all doesn´t...
                                            06-19-2023, 05:02 AM
