The computer is the one in the subject. Dead. So dead, that no button, no nothing works. Zero signs of it being live until I open it.
What's verified - the B+ voltage is there at 8.4V.
Battery is probably dead, cause it was a bit over discharged (to 6V). I forcefully charged it directly on the cell terminals to 3.8V per cell. Now it has voltage on the output connector, but it is 7.1V, not 7.6V. Even when connected to the motherboard it doesn't charge. But will look at that later.
The +3VALWP and +5VALWP voltages are missing. Traced them to PU500 and PU501. Both of this have the EN2 at 2.2V, but have the EN1 at 0 volts. So these are not enabled due to the EN1 pin being at 0V.
Tried to trace back the EN1 pint. This is the ALWON line. I think it should come from the MEC5105 IC. But I also see a comment next to one of the ALWON lines saying "Check pull up resistor of SPOK at HW side".
The questions I have are:
1) Who is actually supposed to provide that ALWON and under what conditions?
2) IF this is the MEC5105 - can I get one from somewhere and replace it or it contains some proprietary firmware and the laptop is literally dead?
And to ease the process - here are forum links for the motherboard. This is direct link to a attachment in another thread here - https://www.badcaps.net/filedata/fetch?id=2059001.
