Hp z420 motherboard (?) issues
  • evoman2
    • May 2025
    • United kingdom
    Hello everyone! I have an old hp workstation z420. Xeon E5 1620 v2, 8gb ecc ddr3
    Basically, when I plug in the power cable to the power supply, it turns on and off while clicking every time it power cycles. Once I remove the power cable from the supply, it flashes a red light 4 times while beeping for about 10 seconds. I have purchased a new CPU and power supply already, but that hasnt fixed it so I'm convinced it's a motherboard level fault. If anyone has any ideas on what the fault could be, and/or how to diagnose it, that would be highly appreciated. Thanks!
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
  • Bonaventure Vigil
    Variable DC Power Supply cannot boot motherboard
    by Bonaventure Vigil
    Hi there,
    Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there....
    10-17-2024, 12:16 AM
  • Rosen Anastasov
    Dell XPS13 9370 with LA-E671P motherboard - power issues, no 3.3V and 5V always on voltages
    by Rosen Anastasov
    The computer is the one in the subject. Dead. So dead, that no button, no nothing works. Zero signs of it being live until I open it.
    What's verified - the B+ voltage is there at 8.4V.
    Battery is probably dead, cause it was a bit over discharged (to 6V). I forcefully charged it directly on the cell terminals to 3.8V per cell. Now it has voltage on the output connector, but it is 7.1V, not 7.6V. Even when connected to the motherboard it doesn't charge. But will look at that later.
    The +3VALWP and +5VALWP voltages are missing. Traced them to PU500 and PU501....
    08-01-2025, 06:06 AM
  • eduardo11791
    ASUS STRIX GL703GE Motherboard Issues
    by eduardo11791
    Hi, pretty much new here, glad I can be part of this community. I'm new to repairing laptops motherboards (Only previous experience was repairing a Z690I STRIX with a broken trace on the memory slot, and it was a sloppy job but worked)
    Bit of background: I'm not new replacing Laptop parts and doing general testing. Bought multiple laptops of the same model since it's easier to repair and got some that I can either switch parts and test.
    ASUS STRIX GL703GE-IS74
    Motherboard Model: DABKNBMB8D0 Rev D All of them
    Issues (Each one on a separate board)...
    12-06-2022, 11:41 AM
