ASUS TUF FA506IV-AS76 vram mosfet short, then battery cant charge
  • jkyoho
    • Oct 2020
    • 17
    I recently fixed a FA506IV cam with Vram mosfet short on Vin(19v)to ground. Got both mosfet replaced and now laptop could turns on and GPU everything works but battery not charging. Battery status shows 100% on both BIOS page and Windows system.
    Measured voltage got 0.3v on battery red lead not going up. charging mosfet gate low and 19v not passing through inductor.
    I also tried dc bench supply 14v charge directly onto battery but seems not drawing anthing.
    Any idea?
  • mon2
    • Dec 2019
    • 14214
    Re: ASUS TUF FA506IV-AS76 vram mosfet short, then battery cant charge
    Check the voltage on each and every pin on the battery pack.
    The suspects are the SMBUS pins and the local ESD diodes.
    Post the schematic / boardview files if available.
    • jkyoho
      • Oct 2020
      • 17
      schematic is similar to FA506IH. Will post BQ24780S pin voltage later on.
      • piernov
        • Jan 2016
        • 4435
        • France
        https://www.badcaps.net/forum/showthread.php?t=90356
        Some of the above points at 2.1 No Power can also apply to battery charging so you should check them as well (in particular 2.1.3. Shorted DC-in MOSFET).
        • jkyoho
          • Oct 2020
          • 17
          I checked HI-side mos and lo-side as well diode reading seems normal, no internal short
          • mon2
            • Dec 2019
            • 14214
            Be specific on the references to make it easier to follow for other readers.
            From your post, assuming that you have inspected the battery charging mosfets @ PQ36, PQ55 & PQ38 ? Confirm it.
            Also post the actual measurements so others can review the details and/or learn from them.
            See attached. @Piernov is referencing to review the DCIN mosfets @ PQ33 & PQ34.
            I was requesting the voltage details of the SMBUS lines. Meter in DC volts scale (5 volts or higher is ok) -> red meter probe on SMBUS line under test; black meter probe to ground. Voltage reading ? Repeat for the next interface line.
            Update:
            What is the voltage reading (with the battery connected) of BAT_PRS# ?
            • jkyoho
              • Oct 2020
              • 17
              YES, I have inspected PQ36,PQ35, PQ71& PQ38. diode reading good.
              BAT_PRS# is 0v. LOW . So battery present
              • mon2
                • Dec 2019
                • 14214
                1) What is the voltage of ACDET on the charger IC (PU6, pin # 6) ?
                2) The ACDRV voltages are too low to turn on the DCIN mosfets @ PQ33 & PQ34.
                3) Remove all power / no battery. Meter in resistance mode (start with the lowest scale).
                Then check the resistance across the DCIN mosfets as follows:
                source (1-2-3) & drain (5-6-7-8)
                source (1-2-3) & gate (4)
                gate(4) & drain (5-6-7-8)
                Post each measurement. If the reading is '1' or 'OL' on the meter, switch to a higher scale.
                Also post the meter scale for each measurement.
                If the resistance is too low, the mosfet is defective and needs to be replaced.
                The TI charger IC requires a number of conditions before it will charge the battery so waiting on your ACDET reading.
                Updates:
                1) attaching the datasheet for the DCIN mosfets = N-channel.
                2) On an N-channel mosfet so the gate voltage has to be HIGHER than the source to turn ON the mosfet. Typically TI likes to use ~6 volts HIGHER than the source leg to turn it ON.
                3) What is the voltage of your applied battery ? Suspecting that it is not 19v3 on the battery.
                With the adapter connected -> the gate voltage being too low to have the mosfet technically ON -> suspecting that at least one of the mosfets is defective (PQ33 and/or PQ34).
                Would you have a donor board ? The mosfets are quite common and can be replaced with others.
                Still proceed to do the resistance checks on these mosfets as a confirmation.
                • jkyoho
                  • Oct 2020
                  • 17
                  My bad, ACDET is 2.65v on BQ24780S PIN6
                  OMG, you are right, for PQ33, I have low resistance around 2ohm on DS,SG and DG. PQ34 has 18 ohm on GS, DS and DG about 78k ohm.
                  FYI, I have auto rate UT61E DMM
                  • mon2
                    • Dec 2019
                    • 14214
                    I will suggest to replace BOTH of these DCIN mosfets - they are quite inexpensive. You are in TO and should have lots of access to such parts - if not shout back and will see if we can hunt them down.
                    DK / Mouser / Arrow are outside sources for the same.
                    The ACDET voltage is good.
                    A bit concerned about the TI charger IC as well since the conditions appear to be OK but with defective DCIN mosfets, the charger IC may be folding back and not allowing for further charging. That is, the ACDRV is low when expecting ~25v on the gate of each DCIN mosfet. Just a guess that the charger IC is turning OFF this flow of events.
                    Respectively - not a bad idea to hunt for replacement mosfets for the DCIN x 2; battery charging mosfets x 3 and the charging IC itself.
                    Each are easy to source from Aliexpress but if in a rush - shout back. We may have some here in the building but need to check...
                    • jkyoho
                      • Oct 2020
                      • 17
                      Thank you, hunting on DK for DCIN MOSFET now, charging ic I can grab one from a donor.
                      • mon2
                        • Dec 2019
                        • 14214
                        You can also review Mobile Sentrix but believe they only deal with business accounts.
                        https://www.mobilesentrix.ca/catalog...p&p=1&q=mosfet
                        BUSINESS LOCATION & HOURS
                        25 Planchet Road Unit 5, Concord Ontario L4K2C5
                        Monday - Friday, 11AM - 8PM EST
                        Saturday : 12 PM - 6 PM (EST)
                        Customer Support Number :+1 (647) 317-3118
                        We seem to be ordering from them every other day lately. Send me PM if you wish to source from them and do not have an account.
                        Otherwise Digikey is great. We have used TI parts to replace such mosfets in the past.
                        • jkyoho
                          • Oct 2020
                          • 17
                          lol. MS I have been dealing with a lot as well mostly for game console parts. But for SMD parts, DK has more variant
                          • mon2
                            • Dec 2019
                            • 14214
                            I think something like this should work out fine - you are not drawing this type of peak current (130A):
                            https://www.digikey.com/en/products/...35NT1G/1793042
                            The original part datasheet notes 5x6 physical size but the rest should be a drop in replacement. Do proceed to confirm the specs but looks like a winner and is in stock (rare these days).
                            • jkyoho
                              • Oct 2020
                              • 17
                              https://www.digikey.ca/en/products/d...T1-RE3/7566716
                              I believe this works
                              • mon2
                                • Dec 2019
                                • 14214
                                The electrical specs look good but the physical may not be a drop in replacement.
                                Check the E2 and D2 dimensions on page # 7 of the datasheet.
                                The original has to be 5x6 but your selection appears to be 4x4. Confirm it.
                                My bad...D x E dimensions seem to indicate that max size is 5 x 6 so I think you are ok here. Also your pulse current is higher than the one I found earlier.
                                • jkyoho
                                  • Oct 2020
                                  • 17
                                  Yes, I measured the Original mosfet and dimensions close enough to this one.
                                  • jacobtc
                                    • Apr 2016
                                    • 274
                                    • Denmark
                                    I had a similar issue with my Asus G14, and a new battery fixed the problem. Also measured very low to none voltage on battery (0-0.4V).. See thread:
                                    https://www.badcaps.net/forum/showthread.php?t=105577
                                    • jkyoho
                                      • Oct 2020
                                      • 17
                                      Just post update and thanks to @mon2 advice, after replacing 2x DCIN mosfet, charge ic finally shut out 17.2v to battery and now charging like a charm.
                                      • mon2
                                        • Dec 2019
                                        • 14214
                                        Well done ! Thanks for the update - this will help future readers.
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • dclass-pro
                                          Latitude 3301 not charge battery
                                          by dclass-pro
                                          Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                                          I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                                          I noticed 2 things:
                                          1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                                          2) if I try to turn it on without the battery...
                                          05-06-2025, 06:19 AM
                                        • zaurus81
                                          HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                          by zaurus81
                                          Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                          WITHOUT BATTERY WITH BATTERY
                                          PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                          05-06-2025, 09:48 AM
