QALA1 LA-7762P What are the coils?
  • magicpc
    • Jun 2022
    • 17
    • Poland
    Hello, I found the LA-7762P motherboard described as turning on once rather than once.
    I checked the coil resistances and the two coils had 4ohm resistances. After desoldering, I already have 9kohm. The only question is what to replace them with? How to find out which coils to use? The diagram and the view of the board did not help me much. Coil marking on R36J 1226F.
  • mon2
    • Dec 2019
    • 14040
    Re: QALA1 LA-7762P What are the coils?
    Wait.
    Can you clarify how you are measuring the resistance ?
    If you are using the multimeter across the legs of the coil then yes, the resistance of 4 ohms or similar are OK.
    The coil is just that, magnet wire over a bobbin.
    It is rare for coils to be damaged.
    Or are you measuring with the resistance to ground - one meter lead on the coil; other meter lead to ground of the logic board ?
    • magicpc
      • Jun 2022
      • 17
      • Poland
      Black probe to ground on the motherboard and red probe to the coil.
      Resistance without coil: 9kohm
      Coil resistance: 3.9ohm
      Coil resistance after desoldering (two probes per coil) 0.09ohm
      • vannix
        • Mar 2018
        • 74
        • Italy
        If those coils are for gpu power, 4ohm could be ok, so the problem could be somewhere else.
        That notebook (dell e6530, correct?) has dual graphics. Nvidia nvs+intel hd, so you could try uma conversion if you think the problem is the discrete gpu.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Yes, the two removed coils are for gpu power and resistance of 4 Ohms may be ok.
          • Rik vb
            Power issues with HP pavillion 15 eh1815nd
            by Rik vb
            I have some issues with my HP pavillion 15 eh1815nd.
            It doesn't wanna power on anymore, when i click the start button it briefly turns white, then the light goes off again.
            The charge light is indicating that it's charging when i plug it in.
            I did some tests accross the board, and found 2 (coils?) near the CPU, one of the small (chips?) next to the bottom coil seems to get unusually hot, and the coil shows quite a lower resistance then the coil above.
            Most/all capacitors next to, and below the bottom coil seem to be connected to ground on both...
            09-08-2024, 01:09 PM
          • chth96
            How can I test coil whether it is really broken or not?
            by chth96
            I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
            I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
            I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
            I want to replace this round black fuse and unidentified coil if it got broken.
            02-20-2024, 01:07 AM
          • double_DD
            HP Probook 455 G8 charging but doesn't turn ON
            by double_DD
            Unfortunately I cannot/don't know how to edit my last query, so I'll create another one instead.
            So I've received this laptop to try and fix it. There were 2 blown components - small inductor and cap, both on Vin (main power rail) on the IN pins of the 0.75V chip (SY8388RHC). I've replaced that chip and the nearby 0.75V_DEEP_SUS (same type), and of course both of blown components. There was still a short on 3V coil, which went away when I replaced PI3DPX1207C chip next to usb-c port (as it was overheating). Luckily I have older non-working 455 G7 for the spare parts....
            03-13-2025, 05:06 AM
          • smic717394
            Asus UX533FD no power
            by smic717394
            Hi guys, I need a bit of help, I have a Asus Zenbook with motherboard UX533FD Rev 2.1. Connecting the laptop draws 30mah and not coming on, Measuring the coils I got the values below. Measuring in resistance all coils have normal values, cpu about 8ohm and the gpu about 5ohm but I guess its normal. Checking with the thermal camera, the only 2 chips that have a bit of heat signature are the U3501 (pd controller) and the U3001 that is the KBC. Now I guess the PD controller it's not the the problem because the battery is fully charged and trying to turn on on battery is the same.
            Just...
            03-29-2024, 06:59 AM
          • waterchill
            What part is this coil from a MacBook A2681 ?
            by waterchill
            Hi everyone
            I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
            So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
            IAny ideas? It is from a MacBook A2681
            Thank you...
            08-08-2024, 01:46 AM
