hp spectre 13t-v100 battery connector
  • qtechphaz
    • Mar 2021
    • 7
    need the connector type for the mb battery connector.
    hello, I have the hp spectre 13t-v100 and I'm assuming the battery connector on the board is the same for variations of the product line. I have to replace the connector but lost the one I desoldered.
    please help
  • mon2
    • 14662
    Re: hp spectre 13t-v100 battery connector
    Post clear pics of the battery connector and where the mating connector was on the logic board.
    How many pins?
    Update:
    1) 30 pins ?
    2) Watch this video:
    https://youtu.be/H22Q2vIffN0
    Is your connector the same ?
    It should be possible to purchase the same macbook connector for your repair - appears to be the keyboard connector common to Apple logic boards.
    3) If you have or can source from your local store, grab a micrometer and measure the pin-to-pin pitch of the connector pads on your logic board. This will allow us to confirm which connector models can be used.
    • qtechphaz
      • Mar 2021
      • 7
      yes the connector is 30 pins, however i don't have a tool to measure the exact pitch. I do know that a connector with pitch of 0.5mm is to gives a width that is to wide for the flex cable. Also when desoldering I blew off 3 resistors and only a schematic will help - I guess there is none available as I have searched endlessly.
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
