ASUS X550CL - Works only with battery ?
  • mon2
    • Dec 2019
    • 14691
    Re: ASUS X550CL - Works only with battery ?
    See attached.
    Interested in the voltage reading at the yellow arrow & with black meter probe to ground.
    Then check again at the PU8802 IC to be sure the voltage is the same.
    When the external power adapter is connected, a safe voltage should be present at the yellow arrows to inform the charger IC that the adapter is connected.
    Only then will the MOSFETS turn on through the gate voltages of each.
    • Acnologia
      • Dec 2016
      • 429
      • Poland
      #42
      Originally posted by mon2
      See attached.
      Did what you asked again.
      PIN - 6 in PU8802 still 0.00 voltage.
      Also i am attaching photo of the voltages around the parts you toldme .
      • mon2
        • Dec 2019
        • 14691
        See attached.
        Believe that PR8814 & PR8815 are the ACDET resistors.
        Carefully apply the ac adapter and measure the voltage on PR8814.
        What voltage reading do you see on each side of the pin ?
        • Acnologia
          • Dec 2016
          • 429
          • Poland
          #44
          See attached.
          You mean inject voltage ,on the main rail of the board ?
          • Acnologia
            • Dec 2016
            • 429
            • Poland
            #45
            See attached.
            if you don't mean that.
            Then you can see above in the picture the exact values i get to those resistors. I have image attached in my last message.
            • mon2
              • Dec 2019
              • 14691
              Ok.
              No injection. I meant for you to power up the board with the normal power adapter for this laptop.
              Remove all power.
              Meter in resistance mode (200k or higher scale).
              Measure the resistance of PR8814. What is the measurement ? This resistor is the one where you show 19v on one side and 0v on the other side.
              Then check the resistance of PR8815.
              Post each measurement. No power while you measure resistance.
              I think that PR8814 is defective.
              • Acnologia
                • Dec 2016
                • 429
                • Poland
                #47
                Ok.
                Remove all power.
                Done.
                See the attachment below.
                • mon2
                  • Dec 2019
                  • 14691
                  PR8814 is defective. It should measure to be 127K in resistance. That is the value showing in the boardview file. It should not be OL on the 200k scale of your meter.
                  Locate a 127K 0402 size 1% tolerance resistor to replace PR8814.
                  Carefully flux and replace this resistor on your logic board.
                  Then test again. If all goes well, you should measure 19v on one side of PR8814 and ~2v6 or so on the other side, not 0v like you have now.
                  • mon2
                    • Dec 2019
                    • 14691
                    Can you confirm if the charger IC has been replaced or is it the original?
                    If replaced, how is the soldering?
                    Confirm the resistance to ground of pin #6 (ACDET) of the charger IC.
                    Remove all power. Meter in resistance mode.
                    Check pin #6 to ground resistance.
                    Post the measurement. This extra test is to confirm the charger IC is not shorted on pin #6 which then implies that PR8814 is defective and has to be replaced.
                    You should also desolder PR8814 off the logic board and check it's resistance while off the board. If you measure 127K then the fault is still on the logic board.
                    • Acnologia
                      • Dec 2016
                      • 429
                      • Poland
                      #50
                      Good morning!
                      Just did everything you said.
                      Probe to "red wire" of the DC-Jack slot, and the black wire to the PIN 6 of PU8802, with resistance set to 200K .I get raising from 100+ all the way to 0.L.
                      Secondly ,
                      I removed the resistor , you said and it showed 0.L.
                      Beneath it , the PR8815 showed 20.1 again as before.
                      • mon2
                        • Dec 2019
                        • 14691
                        Which meter scale? 200k ?
                        If yes, this resistor is defective and must be replaced.
                        This measurement should be 127 on the 200k meter resistance scale.
                        • Acnologia
                          • Dec 2016
                          • 429
                          • Poland
                          #52
                          Yes, 200k meter.
                          The resistor was removed and i checked the 2 points,on board it showed 0.L .
                          Also checked the DC Port (red 19V) and PIN6 ,again 0.L
                          • mon2
                            • Dec 2019
                            • 14691
                            What is the measurement of the resistor that you have removed? Place the meter leads across the removed part, not the circuit board. I think that you may be checking on the circuit board pads? Use 200k scale.
                            • Acnologia
                              • Dec 2016
                              • 429
                              • Poland
                              #54
                              It's gone....hahahahahahah
                              I sneezed,and the resistor flew, while i was trying to measure it.
                              So regardless of that ,i will replace it eitherway.
                              The circuit pads on the board (without the resistor) show 0.L
                              • mon2
                                • Dec 2019
                                • 14691
                                So the readings on the logic board are good since the resistor was removed.
                                Source a 127k 0402 1% resistor and replace it on the board. The resistance value is critical to the operation.
                                They are dirt cheap so buy extras.
                                • Acnologia
                                  • Dec 2016
                                  • 429
                                  • Poland
                                  #56
                                  Ordered x100 pieces,from aliexpress for around 4$ shipped to me (with aliexpress standard shipping).
                                  So i just have to wait.
                                  Thank you for your time and effort of helping me out, as soon as i get them back , i will let you know (also bought the PU8802 just in case).
                                  • Acnologia
                                    • Dec 2016
                                    • 429
                                    • Poland
                                    #57
                                    Hello once again.
                                    We are back online.
                                    I received the resistor , together with the PU8802.
                                    I swapped / replaced them ,and now the laptop turns on , works from battery, works alone with only charger , it detects the battery.
                                    All good.
                                    BUT!
                                    Now, it suddenly doesn't charge the battery...
                                    • mon2
                                      • Dec 2019
                                      • 14691
                                      Hi. Sounds good...sort of.
                                      Check the usual suspects which are the dcin mosfets.
                                      Remove all power and with no battery.
                                      Meter in resistance mode. Then check the resistance across the mosfet pins.
                                      Source & drain
                                      Source & gate
                                      Gate & drain
                                      Post each measurement and the meter scale used.
                                      • mon2
                                        • Dec 2019
                                        • 14691
                                        Measure the fresh voltage readings for the 2 x mosfets from your post # 6.
                                        These are critical to the operation with the adapter and charging.
                                        Interested in the voltage on each pin of these 2 x mosfets.
                                        • Acnologia
                                          • Dec 2016
                                          • 429
                                          • Poland
                                          #60
                                          Source & drain
                                          Source & gate
                                          Gate & drain
                                          Good morning!
                                          Mosfets ,have both stable voltage as indicated all the pins between them have the same exact value 19.14V to be precise.
                                          Now, for the 200k measurement with the multimeter for some reason all the Gate & Drain , Source drain etc . have 0.L i don't know ,if i am doing something wrong, even though i did testing around and it showed values,but to the specific mosfets , the value stays at 0.L. (all pins)
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • Gregoriy Kim
                                            Asus Vivobook M3502Q, no power through USB-C, works on battery.
                                            by Gregoriy Kim
                                            Hello everyone!
                                            Need help with Asus Vivobook M3502Q, Ryzen 5.
                                            First time working with failed power supply via USB-C ports. no schematics available.
                                            Symptoms:
                                            suddenly turned off and does not turn on,
                                            Upon first observation, turned out both CSD87501 mosfets had unsoldered due to overheating.
                                            Manually charged battery and laptop works on battery
                                            Soldered 2 new CSD87501 on board, but it didn't solve the issue.
                                            there is 3.3V and 1.6V from TPS65994. and it talks to charger, so charger sends 20V, but no load. There is 20V...
                                            04-13-2025, 03:25 AM
                                          • bykanovm
                                            Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                            by bykanovm
                                            Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                            If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                            If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                            even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                            Also, the laptop does not turn on without...
                                            04-02-2025, 02:45 AM
                                          • rob777
                                            Asus TUF won’t run off battery
                                            by rob777
                                            I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                            I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                            Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                            Thanks....
                                            05-27-2025, 07:07 PM
                                          • ivangserrano
                                            ASUS UX303UB REV2.2 WORKS ONLY BATTERY
                                            by ivangserrano
                                            Hello
                                            I have an ASUS UX303UB that only turns on with the battery connected, it doesn't turn on only with the charger connected.
                                            With the battery and charger connected, the computer turns on but does not charge and I can see some consumption at the source, it seems to me that the charger is taking over.
                                            In the work environment I can see that the battery is at 24% and does not charge or discharge.
                                            I checked the 24780s load ic and I have the following voltages.
                                            24780s
                                            vcc - 18.85
                                            24v acdriver
                                            acok 1.3v
                                            acdet 2.6v...
                                            06-29-2024, 06:35 AM
