ASUS X550CL - Works only with battery ?
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Hello to all!
    Another brainstorming, no indication of liquid, no indication of something blown (under microscope) , laptop works fine with battery (had the same to another laptop that was charged) and i saw it boots up with the battery just fine.
    The DC-Jack , shows 19v ,inside the motherboard.
    So the problem is afterwards i believe ?
    Which place i should look first you think ?
    Thanks a lot gyuz.
    Any help is much appreciated.
  • mon2
    • Dec 2019
    • 14106
    Re: ASUS X550CL - Works only with battery ?
    Sharing the boardview file for this logic board.
    1) Start with the review of the charger IC @ PU15 = BQ24780.
    2) Remove the battery. Attach the power adapter. Meter in DC volts (20v scale).
    Check the voltage of ACDET signal against ground. What is the reading ?
    3) Proceed to very carefully check if the LDO onboard this IC is working.
    Pin # 24 (REGN) - what is the reading ?
    • piernov
      • Jan 2016
      • 4435
      • France
      https://www.badcaps.net/forum/showthread.php?t=90356
      • Acnologia
        • Dec 2016
        • 421
        • Poland
        Holly molly ,i thank you both for the guides that you shared with me ,i will try my best
        Keep learning ,keep learning .
        Thanks guyz
        • Acnologia
          • Dec 2016
          • 421
          • Poland
          I downloaded your .zip file but i cannot find anything like the PU15 not even on board not even in the boardview.
          But from the file you showed me i searched some other values.
          I mean based on the "ACDET" i searched in the .zip file and found those values.
          • Acnologia
            • Dec 2016
            • 421
            • Poland
            Something else, just in case i changed the MOSFET (that are coming in with DC) because i saw something strange. (if i don't understand correctly let me know)
            1 mosfet , has 19v ,and the second one is dropped below 19v.
            From the schematic i see they are in parallel ? So shouldn't it be 19v as well?
            The mosfets are brand new.
            • mon2
              • Dec 2019
              • 14106
              Yes, they should be the same voltage value.
              Remove all power and check the resistance between the 2 mosfets for these pins. You should have ~0 ohms as you measure between the mosfet pins since it is a large and common PCB trace.
              Next consider to desolder mosfet PQ8802 and power up again to confirm the 19v reaches the PQ8802 pads.
              Remove for now PC8812 to confirm it is not shorting.
              What are the markings of the original mosfets for each?
              What are the markings of the replacement mosfets?
              • Acnologia
                • Dec 2016
                • 421
                • Poland
                Will do by morning.
                I had bought long ago, many MOSFET with the same values, i mean the same exact type. Not even a single marking / value / letter is different.
                Even with the "old" ones the 19v is not present on the 2nd mosfet in the , pins that i am showing to you .
                Strange for me ...
                I will check the resistance between the 2 . If not , i think there is somewhere else the problem ? I mean "before" that ?
                • Acnologia
                  • Dec 2016
                  • 421
                  • Poland
                  Did resistance check and it was 0.00
                  But , now don't know why the MOSFET on the side that they are connected, don't show 19V any more...
                  Removed the PC8812 and PC8805 and nothing changed.
                  So the problem starts from somewhere else ?
                  • Acnologia
                    • Dec 2016
                    • 421
                    • Poland
                    Removed both PQ8802 and PQ8801 same behaviour again.
                    One side no 19v.
                    Changed again the MOSFET of PQ8801. One side 19v and the other side again 0
                    PC8812 one side 0.05 and the other 0.00 ,and PC8805 ,one side 19v the other 0.00volt.
                    What the hell is going on?
                    • Acnologia
                      • Dec 2016
                      • 421
                      • Poland
                      PR8806 (Resistor near DC-in) is also 0.05
                      • mon2
                        • Dec 2019
                        • 14106
                        Post a close and clear pic of this mosfet area.
                        If there is a solid pcb trace between the 2 mosfets, the voltage should reach the other side.
                        • Acnologia
                          • Dec 2016
                          • 421
                          • Poland
                          Done.
                          • mon2
                            • Dec 2019
                            • 14106
                            Leave in only the mosfet that passes through the 19 volts.
                            Remove the next mosfet. Then power up.
                            Do you see the 19v on the removed mosfet pads?
                            If not, remove the cap that is in between the mosfets on the pcb. Test again.
                            If the trace is solid, it has to pass the voltage through.
                            Also review the bottom side of your mosfets to confirm they are being soldered in correctly in the right direction.
                            Compare the pins that are shorted under the part to the pcb tracks for the mosfet sites.
                            • Acnologia
                              • Dec 2016
                              • 421
                              • Poland
                              I don't know if the battery is dead,but now it won't turn on either :P After all those , tests to see if it works in battery 100% (and i don't have the 2nd laptop that i used to charge her up) .
                              But is strange....
                              • Acnologia
                                • Dec 2016
                                • 421
                                • Poland
                                Yes i already did that.
                                I used only the 1st mosfet (Tried 3 different chips- PQ8801) but on the side that is connected to the "red" wire of the DC-Jack ,it comes 19volt. (on the chip is the side that all pins are connected into one single section).
                                On the pins (1-2-3-4) still remains 0.20volt
                                (The ones that i have in circle) don't mind the PQ8802.
                                • Acnologia
                                  • Dec 2016
                                  • 421
                                  • Poland
                                  Removed everything.
                                  • mon2
                                    • Dec 2019
                                    • 14106
                                    See attached. Do you see 19 volts on each pad with the arrows ?
                                    When you had 19 volts with the mosfet soldered @ PQ8801, the voltage should be present on each red circle pad.
                                    Review the BOTTOM side of the mosfets and share the pics.
                                    They must be soldered in the same orientation - look for the 4 pads that are common under the mosfet and it must be soldered on the PCB in the same direction.
                                    Both are N-channel mosfets - can you share the exact p/n used for the replacements ?
                                    The BV file references QM3024M3 for the 2 * mosfets.
                                    • Acnologia
                                      • Dec 2016
                                      • 421
                                      • Poland
                                      No , even without the mosfets on it, i don't have 19V.
                                      Even with PQ8801 i don't have 19V on the back end of it.
                                      It's like it's gone dead?! Strange.
                                      The mosfets from the factory are : M3024M 32919P
                                      And the ones that i got replacement are : M3024M 1XLN6
                                      Now, i understand what you are saying and for sure, i have soldered them correctly because you cannot solder them , opposite or wrong. Because only 4 pins are from one side,and on the other (opposite) side,it's all as a single pin (i think is commong to ground)
                                      But, i have tried everything, 19V doesn't go anywhere not even from the 1st mosfet (it comes inside ,but never leaves....)
                                      Opposite from the motherboard ,there is nothing i mean in case something from behind it's not / soldered / broken etc.
                                      So i think the problem starts from the MOSFETS ? What the hell?
                                        • 20781
                                        Power is nothing without control. What are the gate voltages,where do they come from ?
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Gregoriy Kim
                                          Asus Vivobook M3502Q, no power through USB-C, works on battery.
                                          by Gregoriy Kim
                                          Hello everyone!
                                          Need help with Asus Vivobook M3502Q, Ryzen 5.
                                          First time working with failed power supply via USB-C ports. no schematics available.
                                          Symptoms:
                                          suddenly turned off and does not turn on,
                                          Upon first observation, turned out both CSD87501 mosfets had unsoldered due to overheating.
                                          Manually charged battery and laptop works on battery
                                          Soldered 2 new CSD87501 on board, but it didn't solve the issue.
                                          there is 3.3V and 1.6V from TPS65994. and it talks to charger, so charger sends 20V, but no load. There is 20V...
                                          04-13-2025, 03:25 AM
                                        • bykanovm
                                          Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                          by bykanovm
                                          Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                          If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                          If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                          even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                          Also, the laptop does not turn on without...
                                          04-02-2025, 02:45 AM
                                        • rob777
                                          Asus TUF won’t run off battery
                                          by rob777
                                          I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                          I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                          Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                          Thanks....
                                          05-27-2025, 07:07 PM
                                        • ivangserrano
                                          ASUS UX303UB REV2.2 WORKS ONLY BATTERY
                                          by ivangserrano
                                          Hello
                                          I have an ASUS UX303UB that only turns on with the battery connected, it doesn't turn on only with the charger connected.
                                          With the battery and charger connected, the computer turns on but does not charge and I can see some consumption at the source, it seems to me that the charger is taking over.
                                          In the work environment I can see that the battery is at 24% and does not charge or discharge.
                                          I checked the 24780s load ic and I have the following voltages.
                                          24780s
                                          vcc - 18.85
                                          24v acdriver
                                          acok 1.3v
                                          acdet 2.6v...
                                          06-29-2024, 06:35 AM
