Motherboard LA-B972P it has no backlight
  • resistor83
    • Oct 2018
    • 127
    • Italy
    hi everyone, I have this hp laptop, motherboard LA-B972P that hasn't had the backlight from a few days. However, you can see the image through the flashlight but without backlight.
    I also tried to change the monitor but the backlight is not present. It can only be seen through a flashlight. So I guess there is a problem on the motherboard.
    What measurements could I start taking?
    Thank you
  • mon2
    • Dec 2019
    • 14203
    Re: Motherboard LA-B972P it has no backlight
    What is the voltage readings of the following ?
    INVPWR_B+
    • resistor83
      • Oct 2018
      • 127
      • Italy
      INVPWR_B+ 19,60v
      • ahmarzo
        • Mar 2015
        • 171
        • india
        Check 3v and 19 v on led circuit
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          UG1-pin1 Voltage??
          • resistor83
            • Oct 2018
            • 127
            • Italy
            UG1-pin1 Voltage??
            UG1-pin1 3,31V
            • JaroTech
              • Mar 2015
              • 351
              Hi, what voltage do you have on pin 23 of your LCD connector?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Pin24 also
                • resistor83
                  • Oct 2018
                  • 127
                  • Italy
                  pin 24 3,35V
                  pin 23 0,07V
                  • JaroTech
                    • Mar 2015
                    • 351
                    What voltages on pins 1, 2, 4 and 5 of UT3.
                    • resistor83
                      • Oct 2018
                      • 127
                      • Italy
                      pin1 3,35V
                      pin2 3,30V
                      pin4 0,07V
                      pin5 3,37V
                      • mon2
                        • Dec 2019
                        • 14203
                        pin1 3,35V
                        pin2 3,30V
                        pin4 0,07V
                        pin5 3,37V
                        Pin #4 is the wrong output value. This is a push-pull, 2-input AND logic gate.
                        It is being powered (pin # 5).
                        Both inputs are 3v3 = '1'.
                        So pin # 4 should be also 3v3 = '1' unless something is pulling it down.
                        Remove all power. Meter in resistance mode.
                        Check the resistance to GROUND of pin # 4 - what is the measurement ?
                        If the resistance is not very low, then this component is defective and should be replaced.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Yes, agree with @Mon2's observation. However, you can test if display comes on screen by bridging between pin23-24 . This is just a quick fix and not solution in perfect sense.
                          • resistor83
                            • Oct 2018
                            • 127
                            • Italy
                            pin4 2,4ohm
                            making the bridge between pin 23 and pin 24 the display turns on!
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Originally posted by resistor83
                              pin4 2,4ohm
                              Glad to know that.
                              • resistor83
                                • Oct 2018
                                • 127
                                • Italy
                                so can i keep it with the bridge?
                                UT3 needs to be replaced or can I keep it?
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  You can keep it this way. It wont harm you.
                                  • resistor83
                                    • Oct 2018
                                    • 127
                                    • Italy
                                    thank you @mon2 and @mcplslg123
                                    just another question:
                                    I realized that if I only use the battery I always have the backlight off.
                                    The video drivers are already up to date and the brightness is at maximum
                                    What could it be?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Brigtness will be at maximum and you cant adjust it with this fix. It should have worked with battery alone also. You need to measure those same pins with battery power only(laptop turned on obviously).
                                      • resistor83
                                        • Oct 2018
                                        • 127
                                        • Italy
                                        sorry for the delay, i had a very busy week at work.
                                        I made the measurements with battery only:
                                        INVPWR_B + 15.85v ***
                                        UG1: 3.31V
                                        pin23 24 LVDS: 2.85V ***
                                        UT3:
                                        pin1 3.35V
                                        pin2 3.30V
                                        pin4 0.14V ***
                                        pin5 3.37V
                                        I noticed that the brightness only disappears when I am inside windows. If I stay in the bios the brightness remains.
                                        I mean with only the battery connected
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • Ado02
                                          Nitro 5 Motherboard: LA-F991P LCD Backlight Problem
                                          by Ado02
                                          I am currently working on a Nitro 5 laptop that came in with an issue involving the hinge and the LCD cable. The LCD cable has been replaced, and so has the screen. However, I am encountering a problem with getting the backlight to work.
                                          While I am not an expert in this area, I suspect that PCH_BLK_PWM and BKOFF may be related to the backlight circuit. However, both of these components lead to integrated circuits (ICs), which makes it challenging for me to perform any checks.
                                          Does anyone have any suggestions on where I should begin troubleshooting?...
                                          10-09-2023, 05:53 AM
                                        • Archimedes
                                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                                          by Archimedes
                                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                                          Fans are spinning. Blindly could install windows11 and got the device manager...
                                          07-30-2024, 05:14 PM
