Motherboard LA-B972P it has no backlight
  • JaroTech
    • Mar 2015
    • 351
    Re: Motherboard LA-B972P it has no backlight
    Change UT3 for a good one.
    • resistor83
      • Oct 2018
      • 127
      • Italy
      i could not find it on aliexpress
      this is fine?
      https://www.ebay.it/itm/202705262562...QAAOSw~PBdAMaY
      • resistor83
        • Oct 2018
        • 127
        • Italy
        hello everyone, I finally got the UT3 component, I only have one question before trying it: do I have to remove the bridge from pin 23 24?
        • mon2
          • 14664
          Yes !! With the bridge, you are forcing the voltage to be present but this missing voltage is coming from UT3. That is, you cannot have 2 output voltages connected together like this.
          Remove the bridge between pins 23 & 24 -> confirm the bridge is no longer there.
          Then solder in the fresh UT3 and test again.
          • resistor83
            • Oct 2018
            • 127
            • Italy
            it's work! thank you!!
            • javben
              • May 2013
              • 11
              • spain
              #26
              thanks !! it works nicely
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • glovecaps
                by glovecaps
                11-25-2024, 04:23 PM
              • Docus
                Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                by Docus
                Hi everyone 😀,
                I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                1. I already own the exact same model, but its plastic chassis is badly damaged.
                06-10-2025, 04:24 PM
              • Ado02
                Nitro 5 Motherboard: LA-F991P LCD Backlight Problem
                by Ado02
                I am currently working on a Nitro 5 laptop that came in with an issue involving the hinge and the LCD cable. The LCD cable has been replaced, and so has the screen. However, I am encountering a problem with getting the backlight to work.
                While I am not an expert in this area, I suspect that PCH_BLK_PWM and BKOFF may be related to the backlight circuit. However, both of these components lead to integrated circuits (ICs), which makes it challenging for me to perform any checks.
                Does anyone have any suggestions on where I should begin troubleshooting?...
                10-09-2023, 05:53 AM
              • cheebster
                iPad Pro 12.9 5th Gen Backlight Issue
                by cheebster
                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                Anyone...
                05-20-2025, 09:17 AM
