Hp probook g1 650 does not charge
  • giulio93
    • Aug 2021
    • 258
    • Italy
    Re: Hp probook g1 650 does not charge
    To understand if they are good can i take them of the board and mesure in ohm? If the reading is 0 they are shorted, if it's not 0 they are good.
    Other question. To find on the market the mosfet, what is the important oart of the marking? Just the first part. For example for the 1 mosfet is enought that is a 7410?
    • mon2
      • Dec 2019
      • 14172
      7410 = AON7410
      https://www.digikey.com/en/products/...ON7410/3152538
      7452 = AON7452
      < datasheet is attached >
      The AON7410 is available through Digikey. Each one on your list should be available on Aliexpress - they seem to carry everything. Select the vendor with the best rating and fastest shipping and throw your list of parts at them for sourcing.
      If you are in a rush, can review alternate subs for each.
      On the shorting - yes, that is a possible reading if the part is shorted. If defective (aka partially wounded) - the resistance can vary with the wind and manufacturer. To compare, check your resistance readings of mosfet # 1 & # 4 - same component yet varying resistance values.
      It is possible that the mosfet readings are off since each part is still soldered onto the logic board. For this case, you can desolder the part, wait 5-10 mins to cool down the part and allow for discharge. Then measure the contacts on each mosfet again for the resistance.
      https://www.aliexpress.com/item/3280...99924011%7Csea
      We deal with this supplier often and have been for the past few years:
      https://www.aliexpress.com/item/3264...%3A%22-1%22%7D
      They should be able to source each one of the listed mosfets. Being so inexpensive, consider spares for the mosfets you have measured.
      • giulio93
        • Aug 2021
        • 258
        • Italy
        Ok I order them. The trusted ali shop is Shenzhen IC store or the other you link me?
        Last edited by piernov; 05-03-2022, 02:44 AM. Reason: remove full quote of previous post
        • mon2
          • Dec 2019
          • 14172
          We use the last link in my post. They are quick to reply and ship the same day.
          China is on a common holiday till May 5 so you should chat them ASAP and maybe they can ship out on May 5.
          We installed their AliExpress app on our phone to make it easy to order and chat with any vendor.
          Please continue to update this thread with your progress for future readers.
          • giulio93
            • Aug 2021
            • 258
            • Italy
            so the last part of the marking is not important. isn't it? For example mosfets 1 and 4 are both 7410 but with different lasting part.
            I need to spend 3 more euro to have the fast shipping (29/05). Is anything else I should change?
            • mon2
              • Dec 2019
              • 14172
              No. The other lines will be manufacturer trace codes such as which factory built the part, the date code, etc.
              As a general rule, we like to order a few of each mosfet linked to this charger ic, including some spare charger IC.
              Before ordering, remove the battery. Power up with only the adapter.
              Are you stable on each power up boot? Does the logic board boot to show you the bios screen? Initial HP boot logo or whatever is normal for this logic board?
              • giulio93
                • Aug 2021
                • 258
                • Italy
                #27
                With just the power connected the pc does not power up. With the battery the pc works fine. (if i connect both battery and charger the pc boots from the battery and the battery does not being charged).
                I order those:
                7410
                7752
                E100BN
                BQ736
                Should I order others?
                • mon2
                  • Dec 2019
                  • 14172
                  If you have fine enough tips on your multimeter, configure your meter to dc voltage mode (30v or higher scale).
                  Measure and post the voltage of each pin on the charger IC.
                  Do this very carefully else charger ic can get damaged and stop the logic board from booting.
                  Suspecting a fault is in the first 2 mosfets which is very common.
                  A better suggestion is for you to first, carefully measure the voltage reading on each of the first 2 mosfets.
                  Review,
                  Pin 1-2-3 = source cluster of pins.
                  Pin 4 = gate
                  Pin 5-6-7-8 = drain cluster of pins
                  Post the readings with the power adapter only attached.
                  Repeat for the 2nd mosfet.
                  Red meter lead on the mosfet pin; black meter lead to ground.
                  The logic board must boot without the battery.
                  • giulio93
                    • Aug 2021
                    • 258
                    • Italy
                    #29
                    Review,
                    Pin 4 = gate
                    Should I do this mesure for mosfet 1 and 2 refering to the pics I share before?
                    • giulio93
                      • Aug 2021
                      • 258
                      • Italy
                      #30
                      Review,
                      Pin 4 = gate
                      It's all 0V from mosft 1 to 3.
                      4 mosfet has about 4V on S and 4.5V on G and 0V on D. The first 2 values are not stable. They both go up and down from 4 to 4.5
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        #31
                        Originally posted by giulio93
                        If thought if the mosfets were shorted the ohm values should be 0, not in Kohm
                        mosfet
                        1 is a 7410 BA4324
                        2 is a 7752 GA4Z2P
                        3 is a E100BN
                        4 is a 7410 GA4127
                        In this message i missclick the 4 mosfet. It's a 7401. On the ali shop you linked me I found 2 tipe of 7401: AON7401 and SI7401. Which is the correct one?
                        I found other mosfet I like to replace, it is a E4 GVE (i'm not sure on the last part couse it's hard to read it off), this one is good?
                        https://it.aliexpress.com/item/40000...7eed41a52NidGt
                        • mon2
                          • Dec 2019
                          • 14172
                          The readings are difficult to follow.
                          Can you post them again but in a format with details like the following?
                          Mosfet #1
                          pins 1-2-3 (Source):
                          pin 4 (gate):
                          pins 5-6-7-8 (Drain):
                          and so on for each mosfet.
                          The above style will make it easier to review. Expecting to see at least some 19v readings on the first mosfet since the DC adapter should be spitting out this voltage -> enters the logic board -> interfaces with the 1st mosfet.
                          Each mosfet is ENABLED / DISABLED by the GATE pin.
                          If the GATE pin is sufficient, the flow should be onto the DRAIN. Think of the mosfets as solid state relays.
                          On the mosfet markings - many vendors build to the same or improved specs as the original. So AON Semiconductor is one vendor; SI = Silicon Labs(?) is another, etc. It is very common to see the same part but from different manufacturers.
                          The AON brand is popular but you can ask the shop @ Aliexpress on their feedback of the recommended brand for this repair.
                          Update:
                          1) adding the datasheet for the AON7410 (I may have done this earlier but not sure)
                          2) observe the broken (dashed) lines inside the circle of the schematic = ENHANCEMENT style mosfet
                          3) the datasheet lists as a N-channel model
                          reference reading:
                          http://www.learningaboutelectronics....hannel-MOSFETs
                          So with an ENHANCEMENT N-CHANNEL mosfet, the GATE of the mosfet must be more positive than the voltage it is passing between the SOURCE & DRAIN pins. So assuming that DCIN from the external adapter is ~19V, then the GATE should be about 19V+6volts = ~25V on the GATE to turn the MOSFET ON.
                          This 'boosted' gate voltage is to be generated by the charger IC if all goes well. The charger IC will accept the ~19v as input and multiply the voltage for the GATE driving of the mosfet (input_base+6v is common) to turn it ON.
                          To turn the ENHANCEMENT N-CHANNEL mosfet OFF, the gate should be lowered to GROUND or a low enough voltage that is lower than what it is passing between SOURCE & DRAIN.
                          Review the voltages on the mosfet to move forward. May need the voltage readings on the charger IC next which is also a common point of failure.
                          • giulio93
                            • Aug 2021
                            • 258
                            • Italy
                            #33
                            Mosfet #1
                            pin 4 (gate):
                            Update:
                            reference reading:
                            Today I was doing some V mesurments and I noticed that randomly the power led flashed, like a false contact. I grab a termocamera to inspect the mb and i noticed a hot spot at 2 mosfet, i touched them and the pc starts to work. I think one or both of them are not soldered on mb properly.
                            They are a 7401 and a E4
                            I think the best things is replace that two mosfet. It is correct?
                            • mon2
                              • Dec 2019
                              • 14172
                              Am I the last guy to not have one in the lab ?
                              I think it will be a great idea to remove all power -> apply flux on each side of each mosfet near the front side where the DCIN adapter is connector -> reflow each mosfet with hot air.
                              Then allow for the logic board to cool for a few minutes and power up again.
                              • Stevedb
                                Stevedb
                                • Feb 2018
                                • 624
                                • Belgium
                                #35
                                Check also the dock connector socket for any liquid damage . I had one where the problem was the dock connector.
                                • giulio93
                                  • Aug 2021
                                  • 258
                                  • Italy
                                  #36
                                  thanks for the advise. I hope I solved the problem. I resold properly a couple of mosfet ( the one I see hot whith the TC), and the pc seams to work fine. The time will give us the answer
                                  • techfreak9356
                                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                    by techfreak9356
                                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                    09-14-2023, 11:10 PM
                                  • ruletero
                                    Acer a515-43 low battery charge voltage
                                    by ruletero
                                    Hi
                                    Acer A515-43
                                    LA-H801P
                                    Fail: Does not charge battery, has low voltaje on connector.
                                    Laptop didn't want to turn on, only charge led blinked.
                                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                    10-24-2022, 02:31 PM
                                  • Klevjetack
                                    Charge a L19D3PDA battery externally from the laptop
                                    by Klevjetack
                                    Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                    03-05-2024, 07:26 AM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • giagi
                                    HP Probook 640 G4 not detecting the dc adapter and will not charge the battery
                                    by giagi
                                    I have a HP Probook 640 G4 laptop which does not detect the DC charger and therefore will not charge the battery. I checked the dc adapter on another working probook 640 and it functions adequately.
                                    I checked the voltages coming in on the motherboard connector from the DC adapter to the bad unit and measured one voltage to be 19vdc and the other the center pin to be about 0.8vdc. I tested the battery and it was found to be OK.
                                    I am not sure what the center pin voltage should be. I suspect the problem to be a component on the dc input line on the motherboard but I do not have any schematics...
                                    12-02-2023, 07:46 PM
