Hp probook g1 650 does not charge
  • giulio93
    • Aug 2021
    • 258
    • Italy
    Hi everyone, I have a problem with this laptop Hp probook 650 G1. Today it decides to not charge the battery anymore.. The pc works fine but the battery does not take the charge. I had the exact same problem 3 months ago. 3 months ago I "solved" just totally disassembly it and then magically it starts to go normaly. Now i tried to unplug the ram modules, the main battery, the bios battery ( doing a clear cmos shorting the 2 pins ). Unplugged everything I press for 30sec the power botton, then plug one ram module, plug the battery and try to restart but same issue, the battery does not take any charge. I notice that the problems comes when I leave the pc in suspension for a long time (about 1 day), it can be the problem?
    Thank you
  • mon2
    • Dec 2019
    • 14675
    Re: Hp probook g1 650 does not charge
    With the power adapter & battery connected - measure and post the voltage readings of each pin on the battery connector.
    • giulio93
      • Aug 2021
      • 258
      • Italy
      The pins on mobo side or the battery pins?
      • mon2
        • Dec 2019
        • 14675
        Technically, the voltages should be the same on either side but start with the measurements on the battery contacts.
        • giulio93
          • Aug 2021
          • 258
          • Italy
          ok, I'll do it. Should be a win suspension state related problem?
          • loopster
            • Sep 2020
            • 80
            You could also run a diagnostics check on the battery with
            HP PC Hardware Diagnostics Windows
            https://support.hp.com/us-en/documen...927-1713329-16
            Had the same problem on an Elitebook 8570w.
            Turned out the battery had a blown fuse and was faulty.
            • giulio93
              • Aug 2021
              • 258
              • Italy
              Mesuring the V with the battery connected and the charger plugged in.
              from the longs pin (the left if you watch the mobo with the cpu at top left)
              0
              0
              0
              0
              3,38
              3,38
              11,5
              11,5.
              The same measure but without The battery
              0
              0
              0,24
              0,5
              0,33
              0,33
              0
              0
              The pc does not turn on just with the charger plugged in. The charger works, I tested with a multimeter
              • giulio93
                • Aug 2021
                • 258
                • Italy
                And sometimes when I plugged the charger in, i see for a sec the light of the power Button goes on and then turn off.
                • mon2
                  • Dec 2019
                  • 14675
                  So wish to confirm,
                  1) if battery only - the laptop will not turn on?
                  2) if adapter only ( no battery ), laptop works?
                  • giulio93
                    • Aug 2021
                    • 258
                    • Italy
                    So wish to confirm,
                    Yes
                    No
                    • giulio93
                      • Aug 2021
                      • 258
                      • Italy
                      Update. I leave the mobo disconnected and separate from the rest of pc and secondary mb, and after about 1 hour the laptop starts work correctly. Why?? I don't understand the problem!
                      • mon2
                        • Dec 2019
                        • 14675
                        Share any pics / white silk screen markings on the logic board so we can locate possible schematics for a deeper review. PICs are best.
                        Remove all power. Locate where the DCIN power connector is located. This trail should follow with 2 mosfet devices and a local charger IC that is used to charge the local battery. You can share pics on this forum to help.
                        Once the mosfets are found, with NO power (no battery), meter in lowest resistance mode - we can check if the mosfets are defective.
                        Often the mosfets are 8 leads (4 on each side).
                        The pinout for the mosfets are usually common - proceed to check the resistance between:
                        source (1-2-3) & drain (5-6-7-8)
                        source (1-2-3) & gate (4)
                        gate (4) & drain (5-6-7-8)
                        We are looking for a low resistance in the readings which means the mosfet is defective / shorted and must be replaced. If you see '1' or 'OL', this means the meter scale is too low so increase till you have a reading.
                        Share the readings & meter scale for each for the next review.
                        Do measure both of the front side mosfets. It is very common to have defective mosfets in this region of the logic board.
                        PS: I am assuming that you are using the official and suitable power adapter for this logic board ? What is the output voltage ?
                        Do post the markings of the charger IC so we can locate a datasheet (if it exists). Then a reference schematic of the charger IC will educate us on how the logic board is most likely wired for this portion of the design.
                        Till then, need to cut my overgrown lawn - (not) a favourite past time
                        • giulio93
                          • Aug 2021
                          • 258
                          • Italy
                          Ty for your reply. Now the pc works and it is closed.. If a short is present the laptop should not restart to work properly, isn't it?
                          • mon2
                            • Dec 2019
                            • 14675
                            Yes, if it is working then leave it be. Did you have to replace / repair any parts to get it to work properly ?
                            • giulio93
                              • Aug 2021
                              • 258
                              • Italy
                              No, i don't replace anything. How can be possible? What was the problem?
                              • giulio93
                                • Aug 2021
                                • 258
                                • Italy
                                Now the pc starts to fail again.. I have to disassemle the board again. I write here when i do it. But i AM confused. The pc seams to fail randomly.. Now with the charger plugged in the charge start and stops randomly. I test it with another charger and same result. When I oper it 3 days ago the power always went in in the board going out from the current resistor.. If there is a short the pc should starts and work fine even if for a small amount of time?
                                • mon2
                                  • Dec 2019
                                  • 14675
                                  Review my post #12.
                                  Measure and post the resistance of each mosfet. No power when measuring the resistance.
                                  • giulio93
                                    • Aug 2021
                                    • 258
                                    • Italy
                                    Review my post #12.
                                    Here the mesures
                                    1
                                    S-D 52 kOHM UP TO 0L
                                    S-G 208 KOHM
                                    G-D 1,2 MOHM
                                    2
                                    S-D 30 kOHM UP TO 1 MOHM
                                    S-G 202 KOHM
                                    G-D 146 KOHM
                                    3
                                    S-D 20 kOHM UP TO 20 MOHM
                                    S-G 3,8 MOHM
                                    G-D 510 MOHM
                                    4
                                    S-D 1,5 MOHM
                                    S-G 2 MOHM
                                    G-D 270 KOHM
                                    The mesures seems to be good, isn't it? No low resistance
                                    • mon2
                                      • Dec 2019
                                      • 14675
                                      In my opinion, mosfets @ 1, 2 and 4 have low resistance with the Kohm readings.
                                      They are very inexpensive - consider to replace each and test again.
                                      Post the markings on the topside of each for a review of which devices are on this logic board. Very likely, you can replace with other mosfets.
                                      • giulio93
                                        • Aug 2021
                                        • 258
                                        • Italy
                                        If thought if the mosfets were shorted the ohm values should be 0, not in Kohm
                                        mosfet
                                        1 is a 7410 BA4324
                                        2 is a 7752 GA4Z2P
                                        3 is a E100BN
                                        4 is a 7410 GA4127
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • giagi
                                          HP Probook 640 G4 not detecting the dc adapter and will not charge the battery
                                          by giagi
                                          I have a HP Probook 640 G4 laptop which does not detect the DC charger and therefore will not charge the battery. I checked the dc adapter on another working probook 640 and it functions adequately.
                                          I checked the voltages coming in on the motherboard connector from the DC adapter to the bad unit and measured one voltage to be 19vdc and the other the center pin to be about 0.8vdc. I tested the battery and it was found to be OK.
                                          I am not sure what the center pin voltage should be. I suspect the problem to be a component on the dc input line on the motherboard but I do not have any schematics...
                                          12-02-2023, 07:46 PM
