820-01521 only shows 5V 0.04A
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    i've been working on macbook air 820-01521
    it is dead no charging. tried to connect to apple configurator always shows accessories not supported.
    using amp meter only shows 5V and 0.04A
    here are some measurements:
    PPBUS_G3H = 12.26V
    PP3V3_G3H = 3.275V
    PP5V_G3S = 0V
    PP20V_USBC_XA_VBUS = 5V (can i inject 20V 1A here?)
  • reassor
    • Apr 2021
    • 176
    • Poland
    Re: 820-01521 only shows 5V 0.04A
    First check why there is no 20v.
    Check CD chips.
    Most of the time if you manage to make them go board will wake up.
    Do not start from back
    PP5VG3S_EN present?
    How do you have 12.2v on main rail?
    Do you meassure with battery connected? (come on)
    • mon2
      • Dec 2019
      • 14012
      No!! If you are not getting to 20v, something is wrong.
      Remove all power. Meter in diode mode.
      Red lead - yes RED meter lead to ground.
      Black meter lead to a LDO rail of each ACE power delivery controller.
      Check the LDO rails in diode mode of each ACE controller and post the readings.
      Repeat for each ACE device.
      • kingskie
        • Oct 2014
        • 249
        • indonesia
        Check CD chips.
        PP5VG3S_EN present?
        there is no rail called PP5VG3S_EN
        yes i have 12.26V on PPBUS rail
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          PP3V3_UPC_XA_LDO = 26K ohm
          PP3V3_UPC_XB_LDO = 25K ohm
          PP5V_S5_LDO = 15.4K ohm
          • mon2
            • Dec 2019
            • 14012
            These are resistance readings. Do you have a diode scale on your meter? Can you post a pic of your meter?
            Then review my earlier post on how to use the diode mode scale and take the measurements.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              i'm using fluke 101
              • inflex
                • Aug 2012
                • 544
                Originally posted by kingskie
                i'm using fluke 101
                Press the yellow button to cycle through to diode-mode.
                It'll likely show a diode symbol on the screen
                YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                • Simplebeans
                  • Sep 2021
                  • 130
                  As mon2 said kingskie, checking diode mode readings should start to give you a idea of which ACE controller may be acting differently. It may show all the same readings for all but it is a good place to start to see any differences.
                  • kingskie
                    • Oct 2014
                    • 249
                    • indonesia
                    U3200
                    PP3V3_G3H_RTC = 0.425
                    PP3V3_UPC_XB_LDO = 0.466
                    PP1V8_UPC_LDOA = 0.482
                    UPC_XB_R_OSC = 0.481
                    UPC_XA_UART_TX = 0.682
                    PP1V1_UPC_XB_LDO_BMC = 0.460
                    UPC_XB_GPIO1 = 0.705
                    PP1V8_SLPS2R = 0.327
                    PP1V8_UPC_XB_LDOD = 0.444
                    UPC_XB_SPI_CS_L = 0.536
                    UPC_XB_SPI_CLK = 0.519
                    UPC_XB_SPI_MOSI = 0.541
                    UPC_XB_SPI_MISO = 0.537
                    I2C_UPC_XB_DBG_CTL_SCL = 0.716
                    I2C_UPC_XB_DBG_CTL_SDA = 0.715
                    PHV_INT_XB_G3H = 0.589
                    UPC_XB_GATE2 = 0.595
                    PPDCIN_G3H = 0.519
                    PP5V_G3S = 0.393
                    TBT_POC_RESET = 0.514
                    USB_X_RESET_L = 0.707
                    TBT_X_USB_PWR_EN = 0.492
                    PP20V_USBC_XB_VBUS = 0.108
                    USBC_XB_CC2 = 0.550
                    USBC_XB_CC2 = 0.533
                    USBC_XB_SBU2 = 0L
                    PD_TBT_XB_LSRX = 0.692
                    PD_TBT_XB_LSTX = 0.759
                    USB_UPOC_XB_F_P = 0.580
                    U3100
                    PP1V8_UPC_XA_LDOD = 0.448
                    PP1V1_UPC_XA_LDO_BMC = 0.461
                    PP3V3_UPC_XA_LDO = 0.468
                    PP1V8_UPC_XA_LDOA = 0.482
                    The lowest is PP20V_USBC_XB_VBUS and USBC_XB_SBU2 is 0L
                    • mon2
                      • Dec 2019
                      • 14012
                      Do you see the same voltage and current draw for each USB type C port?
                      What are the voltage readings of the following?
                      PP1V8_SLPS2R
                      PP1V1_SLPS2R
                      • kingskie
                        • Oct 2014
                        • 249
                        • indonesia
                        do you see the same voltage and current draw for each usb type c port?
                        pp1v8_slps2r
                        pp1v1_slps2r
                        pp1v8_slps2r = 1.793v
                        pp1v1_slps2r = 1.096v
                        • mon2
                          • Dec 2019
                          • 14012
                          These 2 rails are ok. They power the T2 device.
                          • kingskie
                            • Oct 2014
                            • 249
                            • indonesia
                            yes they both have the same current draw...could it be T2 chip is the culprit or PMIC?
                            • kingskie
                              • Oct 2014
                              • 249
                              • indonesia
                              any suggestions?
                              • mon2
                                • Dec 2019
                                • 14012
                                SBC_XB_SBU2 = 0L
                                Is not correct for this diode reading. Can you check again?
                                It should be about 0.65.
                                Check also
                                USBC_XB_SBU1
                                USBC_XA_SBU1
                                USBC_XA_SBU2
                                • kingskie
                                  • Oct 2014
                                  • 249
                                  • indonesia
                                  SBC_XB_SBU2 = 0L
                                  Check also
                                  USBC_XB_SBU1
                                  USBC_XA_SBU1
                                  USBC_XA_SBU2
                                  i checked USBC_XB_SBU2 from the test point that i attached still OL
                                  USBC_XB_SBU1 = OL
                                  USBC_XA_SBU1 = OL
                                  USBC_XA_SBU2 = OL
                                  • mon2
                                    • Dec 2019
                                    • 14012
                                    Post a pic of your multimeter so we can confirm the diode mode setting.
                                    • kingskie
                                      • Oct 2014
                                      • 249
                                      • indonesia
                                      this is my multimeter
                                      • mon2
                                        • Dec 2019
                                        • 14012
                                        You are in ohms mode.
                                        Press the yellow button till you see the diode symbol and measure again.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • Rauni
                                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                          by Rauni
                                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                          Read also that we should test what happens if we...
                                          10-01-2023, 12:06 AM
