I have a MacBook Air 2015 2.2GHz i7 A1466 820-00165-A. It had worked normally. Now it doesn't start anymore. When Magsafe is plugged in, the LED will turn solid green and then orange. I can also do an SMC reset. But you can't turn it on.
MacBook Air A1466 2015 no Power on
Re: MacBook Air A1466 2015 no Power on
I missed your earlier post.
What is the resistance scale used on your meter?
Without power, check the resistance again on both sides of the F7140 fuse.
Post the pic of your meter settings for this test.
For now leave the cap off.
The fuse readings are now good.
Check also the cap resistance to ground where the blown cap was soldered.Comment
Yes this would appear so - https://support.apple.com/en-gb/HT204455.
Ask the previous owner if he can provide you with the password. Otherwise you are going to need a EFI chip.Last edited by Simplebeans; 03-19-2022, 10:32 AM.Comment
Further to my previous message if you need a hand sourcing the EFI chip Strolch please drop me a message or post back on here and let me know.Yes this would appear so - https://support.apple.com/en-gb/HT204455.
by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
- PPBUS_G3H (12.6V-12.8V)
- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)
- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)
- This
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by ahmarzoHave a MacBook Air a 1466 with part no 820-00165-a having no power and no light on magsafe adapter pp3v42 is 3.3v when I short r5100 near ic u5000 the light turns on and mac gives display . everything is working good but the keyboard and touchpad doesn't work.
Should I change the ic u5000 please guide me...10-18-2025, 10:34 AM - Loading...
