MacBook Air A1466 2015 no Power on
  • Strolch
    • Nov 2017
    • 245
    • Deutschland
    I have a MacBook Air 2015 2.2GHz i7 A1466 820-00165-A. It had worked normally. Now it doesn't start anymore. When Magsafe is plugged in, the LED will turn solid green and then orange. I can also do an SMC reset. But you can't turn it on.
  • mon2
    • Dec 2019
    • 14685
    Re: MacBook Air A1466 2015 no Power on
    What is the voltage value of PPBUS_G3H ?
    • Strolch
      • Nov 2017
      • 245
      • Deutschland
      I have at
      D7005 pin 1=0,0005V Pin2=16,475V Pin3= 16,185V
      L7130 Pin1= 8,547V Pin2=8,547V
      F7140 Pin1= 8,547V Pin2=0,0005V
      • mon2
        • Dec 2019
        • 14685
        Fuse is blown.
        Remove all power. Meter in resistance mode.
        Check the resistance to ground of fuse F7140, pin # 2. Post the resistance value.
        • Strolch
          • Nov 2017
          • 245
          • Deutschland
          F7140 Pin2= 0,3 piiiiip ;-) Pin1= 310
          • mon2
            • Dec 2019
            • 14685
            So far, yes. Will know more with the resistance reading.
            • Strolch
              • Nov 2017
              • 245
              • Deutschland
              I replaced F7140! But now C7621 is burned!. But why? You can't see anything on the board!
              • Strolch
                • Nov 2017
                • 245
                • Deutschland
                C7621 at Picture
                • mon2
                  • Dec 2019
                  • 14685
                  That was the reason to ask for the resistance reading.
                  The fuse blew for a reason.
                  What is the resistance to ground of the fuse that was showing 0v ?
                  Remove this blown capacitor.
                  • Strolch
                    • Nov 2017
                    • 245
                    • Deutschland
                    c7621 is removed should i insert a new one? the damage fuse has 8,2k ohms
                    • mon2
                      • Dec 2019
                      • 14685
                      I missed your earlier post.
                      What is the resistance scale used on your meter?
                      Without power, check the resistance again on both sides of the F7140 fuse.
                      Post the pic of your meter settings for this test.
                      For now leave the cap off.
                      The fuse readings are now good.
                      Check also the cap resistance to ground where the blown cap was soldered.
                      • Strolch
                        • Nov 2017
                        • 245
                        • Deutschland
                        the Fuse has now 0,8K both sides
                        • mon2
                          • Dec 2019
                          • 14685
                          Still sounds low.
                          If you remove the fuse, what is the resistance on each pcb pad of the removed fuse to ground?
                          • Strolch
                            • Nov 2017
                            • 245
                            • Deutschland
                            Should I desolder the fuse again? And how should I measure that?just hold the 2 contacts from the multimeter to pin 1 and 2 and read the ohms?
                            • Strolch
                              • Nov 2017
                              • 245
                              • Deutschland
                              The MacBook is running now. The new C7621 is in the Board. But after the gong at the start comes a lock with a password. I didn't get the password from the previous owner. Then should I buy an EFI Bios chip or is there another option?
                              • Simplebeans
                                • Sep 2021
                                • 135
                                Yes this would appear so - https://support.apple.com/en-gb/HT204455.
                                Ask the previous owner if he can provide you with the password. Otherwise you are going to need a EFI chip.
                                • reformatt
                                  • Feb 2020
                                  • 1522
                                  Plenty of guides on removing the password in the EFI of a MAC. Just need a programmer and hex editor.
                                  • Simplebeans
                                    • Sep 2021
                                    • 135
                                    Further to my previous message if you need a hand sourcing the EFI chip Strolch please drop me a message or post back on here and let me know.
                                    • Stevedb
                                      Stevedb
                                      • Feb 2018
                                      • 624
                                      • Belgium
                                      Do you have a programmer
                                      • SarcasticOP
                                        General question about MacBook power rails for repair.
                                        by SarcasticOP
                                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                        • PPBUS_G3H (12.6V-12.8V)
                                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                        • PP3V42_G3H (3.42V)
                                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                        • PPVRTC_G3H (3.3V)
                                          • This
                                        12-12-2024, 05:50 PM
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • ahmarzo
                                        MacBook Air a1466 no power
                                        by ahmarzo
                                        Have a MacBook Air a 1466 with part no 820-00165-a having no power and no light on magsafe adapter pp3v42 is 3.3v when I short r5100 near ic u5000 the light turns on and mac gives display . everything is working good but the keyboard and touchpad doesn't work.
                                        Should I change the ic u5000 please guide me...
                                        10-18-2025, 10:34 AM
