A1708 820-00840 Missing PP1V1_UPC_XA
  • AJ847.63e
    • Aug 2020
    • 166
    • Africa
    Hi All.
    Just wanted to see if I can get some assistance with a A1708 I'm working on. Board while looking clean had it's liquid marker tripped by U2890. Board started off as fluctuating between 0.0157A @ 5.1762V to 0.0132A - 5.1751V 0.190A. Went through and checked the CD3215 bootup table on logiwiki. Found all LDOs (step 2) are present bar P1V1_UPC_XA_LDO_BMC which is completely missing regardless which USB port I use and P1V1_UPC_XB_LDO_BMC which is 0.280V, Logiwiki noted that's likely a faulty TBT rom, and judging the sticker near it had tripped I decided to remove the rom and low and behold there was junk under it. Replaced it and now the boards up to 0.0230 with a short dip to 0.01 and a short spike to 0.04 than rinse and repeat.
    After replacing the TBT rom it shortly did get warm, not hot but it was evaporating IPA after maybe 40 sec or so, but after leaving it on for a minute or so and power cycling it's no longer doing that. Nothing else seems to be getting hot. Confirmed all traces between the TBT rom and the CDs are ok, as logi also mentions they often break.
    What else could be causing PP1v1 to be missing? Besides bad CDs hopefully because I do not have replacements.
    Thanks for your assistance.
  • mon2
    • Dec 2019
    • 13994
    Re: A1708 820-00840 Missing PP1V1_UPC_XA
    Meter in diode mode.
    Red meter lead to ground.
    Black meter lead to point to test.
    Check the diode mode reading of each CD3215 LDO rail.
    Post the values.
    https://boards.rossmanngroup.com/thr...h-ports.57331/
    • AJ847.63e
      • Aug 2020
      • 166
      • Africa
      Thanks. I get 0.485 diode mode for XA using the test point and 0.486 for XB using it's respective test pads. When I replaced the TBT ROM chip I did so with a ROM from a 820-01598 as that was all I had and was hoping the FW would be the same. Do we know if their the same or different? Are they flashable?
      • AJ847.63e
        • Aug 2020
        • 166
        • Africa
        Should also mention both CD fuses have been checked and both have 5.12v when their respective USB port is connected.
        Just checked the voltages on the no stuff caps as well as I noticed in the post you linked to they requested those.
        C3120 pad 1: 5.12v / pad 2: 4.19V
        C3121 pad 1: 4.56v dips to 4.31 than back up
        pad 2: 8.36 fluctuates all over the place quite rapidly. Lowest value was 6.35v.
        C3220 pad 1: 5.16v / pad 2: 7.2v
        C3221 pad 1: 5.15V dips to 4.82v than back up
        pad 2: 10.86V dips to 9.75v after about 20 sec but bounced back to 10.86 immediately.
        • mon2
          • Dec 2019
          • 13994
          https://boards.rossmanngroup.com/thr...equired.60466/
          • AJ847.63e
            • Aug 2020
            • 166
            • Africa
            Well, that's a surprise. Normally Apple write protects the chips so there not flashable. After the board numbers they usually have a dash something do we know what that denotes? I'm assuming probably a region designation. I did get a 820-00840-A donor board today, but the board I need a rom for is 820-00840-1. Does that matter? I've ordered some TBT roms from our local electronics supplier incase it does need to be the exact same one and will flash one once they arrive.
            • AJ847.63e
              • Aug 2020
              • 166
              • Africa
              For programming chips, has anyone tried the chipsetpro device? I haven't purchased a USB programmer yet so I've been doing some googling to try see what models people recommend.
              • mon2
                • Dec 2019
                • 13994
                I would backup the rom contents of your existing flash and apply a fresh image of the 820-00840-A onto the same device. From internet searching, do not see a dump mention of a 820-00840-1 specific rom.
                The flash device is industry standard SPI interface.
                So the access will occur over standard SPI read commands. Unless the logic board will extract and compare the flash device IDs, doubt there will be any issues.
                Any SPI compatible programmer will work as long as the voltage is supported for the same device.
                Confirm with the chip database that your exact flash is supported by the tool you wish to buy.
                We are considering to buy the U301 tool for the rom dumps.
                • AJ847.63e
                  • Aug 2020
                  • 166
                  • Africa
                  I ended up buying the BY-301 tool off phonefix and the RT801 off Ali will backup the existing chip once they arrive. Apparently the BY-301 has built in backups of all the ROM files for all the USB c boards 2016 - 2020 which is nice.
                  • mon2
                    • Dec 2019
                    • 13994
                    Excellent. They do not list a dump for your exact logic board but do mention 820-00840-A. So likely it will be the same and suitable for your 820-00840-1.
                    After the tool is received, can you post all of the TBT rom dumps here?
                    It will be helpful to all techs.
                    Thanks.
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      000840 should have CD3215C00, but USB-C controller firmware also depends on the USB-C controller revision (B01/B03/C00).
                      • AJ847.63e
                        • Aug 2020
                        • 166
                        • Africa
                        Thanks Piernov. Sure, once the tool arrives I’ll upload the FWs to this thread.
                        • Pedro147
                          • Sep 2016
                          • 157
                          Originally posted by AJ847.63e
                          Thanks Piernov. Sure, once the tool arrives I'll upload the FWs to this thread.
                          Thanks, watching with interest
                          My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
                          • shah05
                            • May 2023
                            • 5
                            • malaysia
                            hi every one i need help macbook pro A1707 no power i find out problem with charging ic cd3215c00 with 6aa041w ,g1 082..is short, so i replace i replace with cd3215c00 77cL0ft , but not working.
                            • mon2
                              • Dec 2019
                              • 13994
                              Measure the voltage to ground of each LDO rail on the cd3215 controllers. Each cd3215 must be working to dial up the 20v power rail from the host adapter.
                              See the detailed article by @Piernov on how 20v is selected. There are numerous steps taken in the handshake.
                              https://logi.wiki/index.php/CD3215_Bootup_Sequence
                              What is the voltage value of ppbus_g3h to ground?
                              • nassih
                                a1708 820-00840 missing PPBUS_G3H
                                by nassih
                                hello! I want to open a new topic about MacBook Pro a1708 820-00840 no power giving me some issues.missing PPBUS_G3H
                                state before replacing some components:c7078,c7062 was shorted,u6990,d6905
                                all this line are not present: USB meter show 5.2v 0amp
                                PPVIN_G3H_P3V3G3H : 0.23
                                PM_EN_P3V3_G3H_R : 0.12v
                                PP3V3_G3H : 0.2
                                PPBUS_G3H : 0.02
                                NOW i have : USB meter show 20.1v 0.08amp
                                PPVIN_G3H_P3V3G3H : 19.75v
                                PM_EN_P3V3_G3H_R : 5v
                                PP3V3_G3H : 3.4v
                                PPBUS_G3H : 0.132v
                                03-02-2023, 01:13 PM
                              • Proteus2188
                                A1708 5V chip on boardview missing
                                by Proteus2188
                                I need some help to identify a chip that is missing in all boardview files i found.
                                820-00840-A Board for the A1708 with a 5V issue.
                                via voltage injection on PP3V3_G3H_VR i found a hotspot near the USB C port.
                                when i check the boardview the chip is not there.
                                Does anyone know what chip this is?...
                                06-21-2022, 07:48 AM
                              • ugamazing
                                820-02020 PPBUS_AON missing
                                by ugamazing
                                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                02-05-2025, 04:21 PM
                              • jpreza
                                Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                by jpreza
                                I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                Looking at the card, it appears to be missing the following:
                                1x 1.0uH inductor - orange square
                                2x...
                                11-01-2024, 10:54 PM
                              • gurj1979
                                Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                by gurj1979
                                Hey guys.
                                Need help with this one.
                                Fan not spinning due to missing PWN Fan signal.
                                Also 5 seconds from powering up it freezes, unless in BIOS.
                                But as soon as Windows starts to load, it will freeze.
                                CPU is COLD / Room temp when it freezes.
                                I've replaced the CPU, same problem.
                                Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                Replaced fan - same problem.
                                Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                08-19-2024, 05:22 PM
