ITE 8518E 1207-cxs should i replace with the full number
  • bembeno
    • Feb 2016
    • 309
    • egypt
    i want to buy it should i have
    ITE 8518E-cxs
    or it should writen 18518E-1207 cxs on it ?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ITE 8518E 1207-cxs should i replace with the full number
    Only 8518E and suffix CXS matter. Rest is datecode which you can ignore.
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • Devonavar
      Vizio M43-C1 - How closely do I need to match the mainboard number?
      by Devonavar
      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
      So, I've ruled out the PSU for now.
      The reboot loop...
      08-14-2022, 08:46 PM
    • matyx
      My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
      by matyx
      i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
      Can somebody please help.
      I dont know how to uplode the .bin file
      02-20-2025, 02:26 PM
    • esinior
      Smd code to part number
      by esinior
      Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
      I've attached pics of this part
      Thanks...
      08-20-2024, 02:50 AM
    • Friend33
      Updating Serial Number on EliteBook x360 1030 G3
      by Friend33
      I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
      Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
      My serial number is: 5CD849BL7Q
      FeatureByte:
      3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
      06-20-2024, 03:55 PM
