ITE 8518E 1207-cxs should i replace with the full number
  • bembeno
    • Feb 2016
    • 313
    • egypt
    i want to buy it should i have
    ITE 8518E-cxs
    or it should writen 18518E-1207 cxs on it ?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ITE 8518E 1207-cxs should i replace with the full number
    Only 8518E and suffix CXS matter. Rest is datecode which you can ignore.
    • bruce35
      HP 600 G3 MT serial number change please
      by bruce35
      HP 600 G3 MT
      SERIAL NUMBER MXL8301K1C Serial number in the file in bios
      SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
      Thank you very much...
      09-24-2025, 02:32 AM
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • acerRI
      Gigabyte MB missing serial number in BIOS
      by acerRI
      We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
      PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
      I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
      Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
      Any help will be...
      09-23-2025, 05:26 AM
    • Devonavar
      Vizio M43-C1 - How closely do I need to match the mainboard number?
      by Devonavar
      I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
      I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
      Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
      So, I've ruled out the PSU for now.
      The reboot loop...
      08-14-2022, 08:46 PM
    • matyx
      My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
      by matyx
      i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
      Can somebody please help.
      I dont know how to uplode the .bin file
      02-20-2025, 02:26 PM
