Smd code to part number
This topic has been answered.
  • esinior
    • Nov 2022
    • 9
    • Iran
    Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
    I've attached pics of this part
  • Answer selected by esinior at 09-07-2024, 04:25 AM.
    lotas
    • Jan 2016
    • 4755
    • Russia
    https://monitor.net.ru/forum/threads/669255/
    https://www.digikey.com/en/products/detail/maxlinear-inc/SPX1431M1-L-TR/2472297
    • truclacicr
      • Apr 2019
      • 343
      • australia
      It would help to see the part on a photo of the full PCB, or at least the surrounding area.
      • esinior
        • Nov 2022
        • 9
        • Iran
        It's a component on the PFC (power factor correction) section of a SPS (switching power supply) and i think it could be a shunt regulator too, but it's named Q on the board, I send pics of board and daughter board
        • lotas
          • Jan 2016
          • 4755
          • Russia
          SPX1431M1-L/TR (TL431)
          • esinior
            • Nov 2022
            • 9
            • Iran
            Thanks for your helpful reply, but its smd code due to datasheet is "N011" and my code is "Q011" probably, do u have any comment about it?
              • Jul 2011
              • 6068
              I did a quick google search and found a part marking with “Q011” but unfortunately this device package has 5 pin but your device is a 4 pin so it not the same part
              • lotas
                • Jan 2016
                • 4755
                • Russia
                • esinior
                  • Nov 2022
                  • 9
                  • Iran
                  Thanks a lot, i think it's true number, I will test it, middle pin is connected to GND as expected
                  • esinior
                    • Nov 2022
                    • 9
                    • Iran
                    Circuit workd with SPX1431
                    part is correct Thanks for your help
                    • lotas
                      • Jan 2016
                      • 4755
                      • Russia
                      Ok!
