VR_ON, ICH_POK missing
+ More Options
Posts
  • PinGuy
    • Oct 2016
    • 74
    • Argentina
    Trying to get a Lenovo G450 to turn on. When pressing power, the power led goes on for about a second, then off. And it won't turn on anymore until power-cycled.
    Measuring at the EC (page 36 at the schem), all these signals are at 0V, and blink to 3V for a brief moment when powering on:
    SLP_S3, S4 & S5
    SUSP#
    EC_RSMRST
    SYSON
    EC_LID
    EC_ON
    VR_ON is always 0V
    ICH_POK_EC is always 0V
    What condition is needed for those 2 signals to go high?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: VR_ON, ICH_POK missing
    For VR_ON (We are on ) H_PWRGOOD / ALLPWRGOOD / PWRGOOD for ICH_POK_EC +3VS voltage is required trace back ,Check the requirements of EC & Bios pins voltage? Flash bios backup original bin
    • PinGuy
      • Oct 2016
      • 74
      • Argentina
      Good info, techtiger, thank you.
      3VALW is present, but when checking the mosfet that turns 3VALW into 3VS, I found that the SUSP signal is always at 3V, and it won't "flicker" to 0 when powering on, like #SUSP does (to 3V of course), when it arrives to Q37. So what can force SUSP to be always 3V? Maybe a short somewhere? I checked all coil outputs and there are no shorts to ground
      • PinGuy
        • Oct 2016
        • 74
        • Argentina
        Please correct me if I'm wrong, so when there is power but the system is off, SUSP is 1, and all the mosfets it controls are off, and when the power button is pressed, the EC sends a 1 through SUSP#, making SUSP 0 and hence making all the mosfets turn on so the computer starts? Is this how this works or am I getting it the other way round?
        • Techtiger
          • Oct 2014
          • 1601
          • france
          [QUOTE=PinGuy;1107532]Good info, techtiger, thank you.
          3VALW is present, but when checking the mosfet that turns 3VALW into 3VS, I found that the SUSP signal is always at 3V, and it won't "flicker" to 0 when powering on, like #SUSP does (to 3V of course), when it arrives to Q37. So what can force SUSP to be always 3V? Maybe a short somewhere? I checked all coil outputs and there are no shorts to ground ]
          Q37 is NPN transistor When pin 2 gets positive supply SUSP# from EC NPN gets ON and send a negative supply so R279 will stop sending voltage for pin2 of (r297) now vola!SUSP
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Not all the fets only +3/5 SUS +RAM_SUS
            • PinGuy
              • Oct 2016
              • 74
              • Argentina
              I tried clipping the collector of Q37 to ground but it will not even try to power up this way, not even a brief blink at the power led. I also tried clipping it right when pressing the power button, but the power led goes off right when I send SUSP to ground
              • Techtiger
                • Oct 2014
                • 1601
                • france
                You have to check EC pin 9 67 37 117 127 16 & Bios pin Voltage
                • PinGuy
                  • Oct 2016
                  • 74
                  • Argentina
                  9, 16, 37, 67 and BIOS VCC are 3V and go to 0V 2 seconds after power button is pressed. So for some reason +3VALW goes to 0 after powering on.
                  117 is at 0V and blinks to 3V for half a second when power is pressed.
                  127 is always at 3V (using the AC adapter)
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    can you test PL401 +3VALWP / PL402 +5VALWP if the voltage drops when pressing the PWRBTN & makes sure no short in RTCVCC section
                    • PinGuy
                      • Oct 2016
                      • 74
                      • Argentina
                      Indeed, +3 and +5VALWP go to 0V after 2 seconds of pressing power.
                      The first thing I did when checking this one was replacing the old ML1220 battery (was at 1.8V) with a new CR2032, and removed PD104 to isolate the recharging circuit from the battery. CHGRTC is at 3.2V, RTCBATT is 3V.
                      Could it be that the EC it needs it to be 3.2V to power on?
                      Will try to check RTCVCC if I find it, as there is no silkscreen for the capacitors and resistors, and there's no board view. Thanks for the pointers!
                      • PinGuy
                        • Oct 2016
                        • 74
                        • Argentina
                        I found R823 after tracing visually and confirmed RTCVCC is at 3V.
                        • mat2k
                          Lenovo 300-15IBR - No SYSON, no SUSP#, bunch of missing voltages
                          by mat2k
                          Hello, I've been struggling with this one today. I'm troubleshooting a Lenovo 300-15IBR (board BMWC1/BMWC2 NM-A471) that turns on the power LED and does a bit of fan spin but nothing else. 3v3sb and 5vsb present, no 1.05v, no 1.35vddr, no vcore, no 1.8vsb.
                          BIOS has been reflashed with one I found here, supposedly tested OK by someone else. I don't have an EC programmer unfortunately.
                          I looked around and SYSON is 0v, SUSP# is 0v too. Forcing them to 3v3 enables the 1.35v rail, but the 1.05v and 1.8v rails are still missing (generated by PU704). EN_1P05A signal is 3.3v, and IN_1P05A...
                          12-01-2024, 11:00 PM
                        • ugamazing
                          820-02020 PPBUS_AON missing
                          by ugamazing
                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                          02-05-2025, 04:21 PM
                        • danny34
                          Thinkpad E15 Gen2 no SUSP# Signal from EC
                          by danny34
                          Hello folks,
                          following problem on an E15 Gen2 with i5 processor (NM-D011):
                          Doesn't start
                          SUSP - high (5.1V)
                          SUSP# - low (0V)
                          Pin124 (SUSP#) on the EC resistor to GND is 80kohm.
                          Does anyone know why the EC doesn't output SUSP#?
                          What requirements do you need to get a high there?
                          Thank you!☺
                          Schematic: HERE​...
                          11-07-2024, 11:54 PM
                        • jpreza
                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                          by jpreza
                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                          Looking at the card, it appears to be missing the following:
                          1x 1.0uH inductor - orange square
                          2x...
                          11-01-2024, 10:54 PM
                        • gurj1979
                          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                          by gurj1979
                          Hey guys.
                          Need help with this one.
                          Fan not spinning due to missing PWN Fan signal.
                          Also 5 seconds from powering up it freezes, unless in BIOS.
                          But as soon as Windows starts to load, it will freeze.
                          CPU is COLD / Room temp when it freezes.
                          I've replaced the CPU, same problem.
                          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                          Replaced fan - same problem.
                          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                          08-19-2024, 05:22 PM
