Thinkpad E15 Gen2 no SUSP# Signal from EC
  • danny34
    • Jul 2024
    • 49
    Hello folks,
    following problem on an E15 Gen2 with i5 processor (NM-D011):
    Doesn't start
    SUSP - high (5.1V)
    SUSP# - low (0V)
    Pin124 (SUSP#) on the EC resistor to GND is 80kohm.
    Does anyone know why the EC doesn't output SUSP#?
    What requirements do you need to get a high there?
    Thank you!☺
    Schematic: HERE
  • danny34
    • Jul 2024
    • 49
    I have an identical motherboard. Fully functional.
    I measured both on the BQ25710 and had the following results:
    Working E15:
    Pin 1 VBUS: 20V
    Pin 2 ACN: 20V
    Pin 3 ACP: 20V
    Pin 4 CHRG_OK: 3.3V
    Pin 5 ENZ_OTG: 0V
    Pin 6 ILIM_HIZ: 2.2V
    Pin 7 VDDA: 6V
    Pin 8 IADPT: 0.3V
    Pin 9 IBAT: 0V
    Pin 10 PSYS: 0.3V
    Pin 11 PROCHOT#: 1V
    Pin 12 SDA: 3,3V
    Pin 13 SCL: 3,3V
    Pin 16 COMP1: 1.3V
    Pin 17 COMP2: 1,2V
    Pin 22 VSYS: 9V
    Pin 28 REGN: 6V
    Defective E15:
    Pin 1 VBUS: 20V
    Pin 2 ACN: 20V
    Pin 3 ACP: 20V
    Pin 4 CHRG_OK: 3.3V
    Pin 5 ENZ_OTG: 0V
    Pin 7 VDDA: 6V
    Pin 8 IADPT: 0V
    Pin 9 IBAT: 0V
    Pin 10 PSYS: 0V
    Pin 11 PROCHOT#: 0V
    Pin 12 SDA: 3,3V
    Pin 13 SCL: 3,3V
    Pin 16 COMP1: 1.25V
    Pin 17 COMP2: 1,1V
    Pin 22 VSYS: 9V
    Pin 28 REGN: 6V
    The values differ for IADPT (Pin 8), PSYS (Pin 10) & PROCHOT# (Pin 11).
    These are all outputs. Do you think the BQ is defective?
    EDIT: I swapped the two BQ's with each other and there is no change. So it's fine, but I don't understand why there's no output
    • danny34
      • Jul 2024
      • 49
      I now measured the other pins of the BQ:
      Pin Defective E15 Working E15
      23 5.3V 9V
      24 5.5V 14V
      25 9V 14V
      26 0 0
      27 0 0
      28 0 0
      29 0 2.4V
      30 10V 15V
      31 5V 12V
      32 5V 9V
      • guyandpit
        • Oct 2021
        • 89
        • Philippines
        Hi any updated on this, have you solved missing missing susp#? Thank you
          Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
          09-06-2024, 09:45 AM
          09-06-2024, 09:40 AM
        • Grafnus
          Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
          by Grafnus
          Hey there,
          first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
          So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
          Specs:
          • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
          • CPU, GPU, RAM work fine (not involved in the Problem)
          So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
          Now I noticed...
          08-06-2025, 11:54 AM
