MBA 820-01521-A Missing PP5V_G3S
  • MobileXT
    • Oct 2012
    • 200
    Hello, I am working on a board that has no water damage just died and only have 5v on the charger. I do have PP1V8_SLP2R present, PP3V3_G3H_RTC Present and PHV_INT_XA_G3H Present. Missing PP5V_G3S. Where is this power generated? from CD3215 or U7100? I need your help please. Thanks.
  • mon2
    • Dec 2019
    • 14247
    Re: MBA 820-01521-A Missing PP5V_G3S
    Power is generated by the external power adapter. It will start off by default @ 5V and provided that each CD3215 is working properly, only then can they negotiate with the external power adapter to supply the 20V power delivery contract. Respectively, it is vital that the CD3215 are functioning properly.
    What is the voltage for PPBUS_G3H ?
    Measure @ C7050 on the logic board. Meter in 20V DC scale.
    Red meter probe to C7050 (+) = pin # 1. Black meter probe to ground (shield) or can be pin # 2 on the same capacitor or convenient cluster of caps in the same group.
    • MobileXT
      • Oct 2012
      • 200
      Measure @ C7050 on the logic board. Meter in 20V DC scale. 12.33v
      C7050 PIN1= 333k Ohms red on +
      • mon2
        • Dec 2019
        • 14247
        PP5V_G3S is created by U7650.
        Remove all power. Meter in resistance mode (2k scale).
        Check & post the resistance to ground for L7670 (either side). Checking for a low resistance value which will likely lead to a bad (shorted) cap. This will cause an excessive current draw and force this regulator to shut down.
        If the resistance is not very low, then proceed to use the meter in DC volts mode (20V DC scale).
        Measure & post the voltage for:
        P5VG3S_EN_DLY
        P5VG3S_EN
        L7690
        PP3V3_G3H
        U7650 is responsible for 2 voltage rails. You have confirmed that at least one side is not working as expected. Confirm the ENABLE is present for this missing rail.
        While there, check the right side rail as well to see if it is working.
        • MobileXT
          • Oct 2012
          • 200
          P5VG3S_EN_DLY
          =0v
          P5VG3S_EN = 0V
          L7690 3.3v no shorted on L7670 = 0v
          PP3V3_G3H
          = 3v3
          No shorted on L7690 and L7670
          L7690 = 3.3v
          L7670= 0v. no short.
          • Pedro147
            • Sep 2016
            • 158
            Hi I am also working on an 820-01521 that has no PP5V_G3S. U7650 is not getting enable signal for this voltage. It looks like that EN should come from PMIC U7800. Any further news on this repair please @MobileXT ?
            Thanks I know it's probably best to make a new post but this one isn't that old so I thought I would just piggyback on here.
            My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
            • mon2
              • Dec 2019
              • 14247
              What is the voltage of
              P5VG3S_EN @ R7613, pin # 1 ?
              P5VG3S_EN_R @ R7613, pin # 2 ?
              Remove all power. No battery. Meter in resistance mode.
              What is the resistance to ground of P5VG3S_EN @ R7613, pin # 1 ?
              • Pedro147
                • Sep 2016
                • 158
                What is the voltage of . . . . etc
                I realise that this is the other guys post but he is MIA I would greatly appreciate any help please @mon2
                * I have 0v both sides of R7613 (working board is 1.79v)
                * R7613 measures 0.7Ω (should be 0Ω but probably just resistance of DMM leads?)
                * RTG of P5VG3S_EN is 46K (working board is 46K also)
                * P5VG3S_EN comes from PMIC U7800 so am I screwed
                PS - I tried DFU restore / revive but board wouldn't go into DFU mode
                • mon2
                  • Dec 2019
                  • 14247
                  What is the voltage of PPBUS_G3H ?
                  • Pedro147
                    • Sep 2016
                    • 158
                    Sorry for the delay but I have now turned on thread notifications.
                    PPBUS_G3H - 12.64v 20v / 0.03A on charger and seeing what else I have or am missing.
                    PP3V3_G3H - 3.3V
                    PP5VG3S - 0.029V diode 0.441 so no short
                    P5VG3S_EN_DLY - 0v
                    this comes from U7610 which has its
                    PP3V3_G3H supply at 3.3v
                    but no P5VG3S_EN_R (diode 0.540 so no short) which also comes from U7800
                    P5VG3S_PGOOD - 1.75v
                    P1V8G3S - 0v
                    P1V8G3S_EN - 0.560 so no short
                    Pointing to PMIC/T2 issues?
                    I also forced into DFU mode (1v8v into SOC_FORCE_DFU) but it timed out and would't complete. I tried twice but cannot recall the exact error. Suffice to say that isn't going to fix it
                    • mon2
                      • Dec 2019
                      • 14247
                      Use the exact net names from the schematics. It will make the review much easier to follow.
                      P1V8G3S - 0v (correction: PP1V8_G3S)
                      This does not look correct.
                      PGOOD signals are open-drain lines. There will be a logic low but no logic high. Instead, '1' state will be high impedance and demands a local pull-up.
                      The pull-up here is R7600. The other side of R7600 should be 1v8 (PP1V8_G3S).
                      You have 1v75 yet the PP1V8_G3S = 0v ??
                      Confirm the voltage of PP1V8_G3S.
                      Also remove all power, confirm the resistance of R7600. Measurement ?
                      • Pedro147
                        • Sep 2016
                        • 158
                        Apologies for the sloppy net names @mon2
                        Yes I see what you are saying now.
                        PP1V8_G3S is indeed 0v diode 0.344
                        R7600 is 99.7Ω so within spec.
                        I rechecked all my other readings and they are all good, both voltages and diode reading.
                        • mon2
                          • Dec 2019
                          • 14247
                          What is the voltage of P5VG3S_PGOOD ?
                          Measure at the resistor R7600.
                          • Pedro147
                            • Sep 2016
                            • 158
                            That is the voltage measured at R7600.
                            Diode value 0.344v refers to diode mode measurement of that line PP1V8_G3S
                            P5VG3S_PGOOD is 0v too
                            • mon2
                              • Dec 2019
                              • 14247
                              In post #10, you had 1v75 for this signal. No more?
                              Remove all power, meter in resistance mode.
                              Check the resistance to ground of P5VG3S_PGOOD.
                              Post the measurement and meter scale used for the measurement.
                              • Pedro147
                                • Sep 2016
                                • 158
                                Yes sorry post #10 was a mistake. I had three of these boards going at once and I got confused
                                P5VG3S_PGOOD resistance to GND is 595K ohms on auto ranging scale.
                                • mon2
                                  • Dec 2019
                                  • 14247
                                  Check and post each SLPS2R and AWAKE rail voltage:
                                  PP1V8_SLPS2R
                                  PP1V1_SLPS2R
                                  PP0V8_SLPS2R
                                  PP1V2_AWAKE
                                  PP3V3_AWAKE
                                  • Pedro147
                                    • Sep 2016
                                    • 158
                                    Pin 1 (PP1V8_SLPS2R) of R4519 is a steady 1.8v but PP1V8_SLPS2R_SOC_LPOSC_RC (pin 2 of R4519) is only 0.628v (should be 1.8v)
                                    R4519 is correct value at 49.9Ω
                                    In regard to your questions, I have all those voltages.
                                    PP1V8_SLPS2R - 1.8v
                                    PP1V1_SLPS2R - 1.1v
                                    PP0V8_SLPS2R - 0.8v
                                    PP1V2_AWAKE - 1.2v
                                    PP3V3_AWAKE - 3.3v
                                    • mon2
                                      • Dec 2019
                                      • 14247
                                      PP1V8_SLPS2R_SOC_LPOSC_RC is not at the correct value.
                                      Remove all power. Meter in resistance mode. Check the resistance to ground of PP1V8_SLPS2R_SOC_LPOSC_RC.
                                      What is the voltage of PP1V8_SLPS2R_SOC_LPADC_RC ?
                                      • Pedro147
                                        • Sep 2016
                                        • 158
                                        resistance to ground of PP1V8_SLPS2R_SOC_LPOSC_RC - 63.3Ω
                                        voltage of PP1V8_SLPS2R_SOC_LPADC_RC - 1.8v
                                        • Lucifer87
                                          rx 5700 pulse Schematic & Boardview request 1.8 missing sometimes present
                                          by Lucifer87
                                          Hi, I need the schematic and boardview of a Radeon RX 5700 Pulse, sometimes it turns on, sometimes it doesn't... I checked when it doesn't turn on, the enable signal is missing on pin 15 EN2 3v to power 1.8v... the problem is that when it works I can't test it since the signal is present... I would like to check the signal paths but I would need the diagram and the boardview thanks​...
                                          12-15-2024, 12:29 PM
                                        • Kooopa
                                          Acer Nitro 5 EC_RSMRST# present, Missing SLP_S5#!!!
                                          by Kooopa
                                          Hi! I'm diagnosing my Nitro 5 AN515-43 Mobo: FH50Q LA-J621P. I left it on sleep mode but when I came back It won't turn on. Power LED would turn on for a few seconds then off. no fan spin nor keyboard backlight.
                                          So I tried the usual procedures first, power cycling and bios reset but non did the trick so I decided to delve deeper.
                                          Nothing strikes as red flags aside from the dust. there's no history of any liquid being poured at it since I bought the thing, I've been real careful. Anyways.
                                          I checked the usual rails +5VALW +3VALW even the 1.8VALW and 0.9VALW...
                                          09-06-2024, 11:38 AM
                                        • Prott
                                          Surface 7 - missing S3 sleep signal, S4 present but weird
                                          by Prott
                                          Hey fellow Badcappers
                                          I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
                                          Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
                                          - The resistance to ground on the SLP_S3 line is >50 kOhms.
                                          - No shorts on any powerrails that I can find.
                                          - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
                                          - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
                                          07-08-2023, 04:54 PM
                                        • saronno
                                          1050ti asus cerberous: 1.8v present, 1.8v pgood missing ..
                                          by saronno
                                          I have this weird case where 1.8v is presente but 1.8v pgood is missing preventing the card to post.
                                          The card sometimes post, in particular when mb and gpu are cold e without voltage for long time. If it post, then no problem, it loads the drivers and everything works fine.
                                          the chip who provide 1.8v is an nb671lb.
                                          have you ever had an issue like that on a 1050ti or any other pascal gpu?
                                          TIA
                                          05-07-2023, 05:15 AM
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
