ASUS G731 shorted motherboard
  • PowerAmpFreak
    • 982
    • Sweden
    Hi, got this Asus ROG G731 with a "shorted motherboard", at least there are shorts measuring across a bunch of electrolytic decoupling caps. Probably been exposed to a faulty charger / wrong polarity charger.
    At least, inside I found a working 512GB SSD and 16GB of ram.
    Anyone have any service manual to this guy or any advice where to focus my probing ?
    • 20888
    Re: ASUS G731 shorted motherboard
    laptop schematic requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=41 .Find the white silkscreened part number,it will probably be on the other side of the board
    • PowerAmpFreak
      • 982
      • Sweden
      Thanks, so you mean I will need to start the process by getting the MB out of the unit firstly, loosening the heatpipes and everything else ?
        • 20888
        Yes ,you`ll have to take the board out. Remove the heatsink screws a few turns out each evenly until theyre all loose,then try and lift the heatsink off near the screw area,if you lift it by the fan end it`ll bend like a banana
        • PowerAmpFreak
          • 982
          • Sweden
          Adding some pictures of the bottom side aswell.
          Obviously there is a G531 GT rev 1.5 motherboard I am looking for the service manual for.
          • PowerAmpFreak
            • 982
            • Sweden
            It seems as far as I can understand, that the system power bus is shorted.
            All the electrolytes with a 25V rating are less than 1ohm across...
            I wonder if I should try to supply some current limited voltage through the charger input?
            I have a high resolution thermal camera that I could use to see if there are any heating stuff...
              • 20888
              Post the resistance to gnd on those caps,and all the large square grey coils
              • PowerAmpFreak
                • 982
                • Sweden
                Here you are...
                Measured to GND with LCR meter.
                EDIT: Listen to this:
                I connected a heavily current limited supply across the short. Slowly increased the voltage to 100mV, current consumption increased to around 50mA initially and slowly faded down.
                After this the static short is gone.
                Hmm....
                • Adenitz
                  • Jan 2021
                  • 122
                  • Congo
                  When doing voltage injection usually one starts with 1 V DC and current limit set to 2 A, since this will not cause any damage. 50 miliamps will cause nothing to significantly heat up.
                  • PowerAmpFreak
                    • 982
                    • Sweden
                    I suspect a MLCC ceramic cap somewhere on the system bus to be shorted. Eventually by injecting a small current will affect the MLCC material properties. I got the information from the previous laptop owner that it was dropped onto the floor and perhaps this damaged a MLCC.
                    Normally, MLCC are quite sensitive to mechanical stress and I will now go through them with freeze spray and measure resistance and see any change.
                    • Adenitz
                      • Jan 2021
                      • 122
                      • Congo
                      Look at this video:
                      https://youtu.be/WU8_eTglue0
                      You can learn about the basic troubleshooting procedures.
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        Question, does ASUS laptops detect the presence of a charging plug attached other than measuring the incoming voltage?
                        Apart from DC in, there are two small pins which could be some kind of detection pins or similair..
                        • juntmeako
                          NOOB
                          • Jul 2020
                          • 67
                          • na
                          Here you are...
                          Hmm....
                          hello, please measure the resistance to ground of the current sensing resistor, its usually located after the dc-in mosfets
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            It seems I found the problem in this motherboard.
                            The story is the following:
                            Previous owner dropped the laptop on the floor.
                            That destroyed the charging connector
                            He tried to replace the connector
                            He then accidently managed to short a 0402 MLCC by a solder bridge.
                            When fixed the bridge the short is gone.
                            What's left to understand is the post above, what the smaller pins in the charging connector does. If they are used to detect the charging plug. One pin is grounded, the other is not. The via hole for this pin was damaged in the process of connector replacement.
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              Now it seem to work.
                              • PowerAmpFreak
                                • 982
                                • Sweden
                                What is a typical resistance measured across the lowside fets in the high current core supply buck converter?
                                I recently had another ceramic cap failed across the AC_SYS_BAT rail, and after replacing it, the PC works, but when measuring across the core supply to GND, there is very low resistance. The core supply works though. So I need to figure out if the load of the core is very low resistance.
                                • piernov
                                  • Jan 2016
                                  • 4435
                                  • France
                                  https://www.badcaps.net/forum/troubl...61#post1459061
                                  2.2. Don't suspect that something is shorted with no reason
                                  Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
                                    ASUS ROG Hero III G731 Notebook Strix Specification for Upgrade or Repair
                                    This specification for the ASUS ROG Hero III G731 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Hero III G731 boardview and Hero III G731 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 09:10 AM
                                  • glovecaps
                                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                    by glovecaps
                                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                    11-25-2024, 04:23 PM
                                    ASUS P5GC-MX motherboard recap
                                    by momaka
                                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                    So here is what the motherboard looked like with its original caps:
                                    CPU VRM area up close…...
                                    01-27-2021, 11:59 PM
                                  • FriedFred
                                    ASUS ROG STRIX G713IC-HX041W, Mainboard G513-MP-GBM, battery shorted out
                                    by FriedFred
                                    6050A3249305-MB-A01
                                    2021-11-05
                                    Hello, everyone!
                                    I have some trouble with the G513-MP-GBM board, it's from an ASUS ROG STRIX G713IC-HX041W.
                                    The total current consumption was about 200mA. The 0.8 Volt rail at the CPU was correct working.
                                    But the power button has not been pressed...
                                    I found some spurious solder between the pads 6 (VRA_SVT) and 7 (APU_PWR_EN) of the PWM-controller, "U66000".
                                    Which can explain why this power rail has been starting without...
                                    01-19-2025, 09:00 AM
                                  • Pedro Ramírez
                                    BIOS on an Asus Prime H310M-E R2 motherboard
                                    by Pedro Ramírez
                                    Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup....
                                    07-29-2025, 04:18 PM
