Asus Fx 504 gm shorted motherboard, dabklimbac0 rev:c
  • Taitan0909
    • Sep 2025
    • 5
    • Italia
    Hi guys i have this Asus laptop and its a strange thing so the laptop of i connected It to Power supply i Will change and i can turn it on but no display, and i have the bdv file of the motherboard of you Need It , so i disassembled the laptop and motherboard, and i found the Power rail of CPU and GPU are shorted tò ground, and for the MOSFET under the intersil ic It Will get 19v but tò the other side i Will not pass the current, im very grateful thank you very much guys
  • glovecaps
    by glovecaps
    11-25-2024, 04:23 PM
  • dhenion
    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
    by dhenion
    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
    The original board was:
    ASUS X510UNR REV 3.0 A
    The replacement board is:
    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
    01-30-2024, 01:45 PM
  • FriedFred
    ASUS ROG STRIX G713IC-HX041W, Mainboard G513-MP-GBM, battery shorted out
    by FriedFred
    6050A3249305-MB-A01
    2021-11-05
    Hello, everyone!
    I have some trouble with the G513-MP-GBM board, it's from an ASUS ROG STRIX G713IC-HX041W.
    The total current consumption was about 200mA. The 0.8 Volt rail at the CPU was correct working.
    But the power button has not been pressed...
    I found some spurious solder between the pads 6 (VRA_SVT) and 7 (APU_PWR_EN) of the PWM-controller, "U66000".
    Which can explain why this power rail has been starting without...
    01-19-2025, 09:00 AM
    ASUS P5GC-MX motherboard recap
    by momaka
    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
    So here is what the motherboard looked like with its original caps:
    CPU VRM area up close…...
    01-27-2021, 11:59 PM
  • MakNCheese
    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
    by MakNCheese
    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
    Symptoms:
    • Severe lag across the system, including BIOS navigation.
    • Slow boot times and unresponsive performance in Windows.
    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
    • No error messages or BSODs, just extreme sluggishness.
    What I've Tried:
    • Replaced
    06-04-2025, 12:48 AM
