HP 15-ab271sa repair
  • case sensitive
    • Jul 2014
    • 13
    Hi, I have an HP 15-ab271sa that I'm trying to repair, the board (Quanta X12A) doesn't power on.
    The problem manifests itself in one of two ways:
    1) The LED on the DC jack switches off briefly when the power button is pressed (then back on) and the 3.3V rail powers on for a few seconds before switching off.
    OR
    2) (rarely) the DC jack LED stays off after pressing the power button and 3.3, 5 and VCC_Core all power on (and stay on). 1.05V and 1.35V (RAM) are not present. When this happens HWPG (power good?) is 0V which I assume is why I don't get 1.05 and 1.35V.
    When I got it to repair the laptop did very rarely successfully power on into Windows but doesn't anymore.
    Boardview and schematics have been posted by other users here: https://www.badcaps.net/forum/showthread.php?t=53625
    Any suggestions on where to look next? Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15-ab271sa repair
    All indicators are towards AD_ID problem. Probe AD_ID voltage at dc jack as well at SIO pin. This is a common fault with this model. If you have a spi programmer, take backup of your existing bios chips and flash known good bios with clean me.
    • case sensitive
      • Jul 2014
      • 13
      0.6v for AD_ID at the DC jack and SIO, AD_TYPE is 0.6v too.
      I have a spi programmer so will try that, thanks.
      • case sensitive
        • Jul 2014
        • 13
        OK after reprogramming the bios chip there is some progress. The board will now reliably attempt to power on and the power LED on the other side of the board (from DC jack) now turns on (didn't happen before). It will then power off and the DC jack and power LED will flash once before turning off again.
        As far as I can tell 3.3, 5 and 1.05v are powering on but it's so quick it's had to catch with the multimeter.
        Is 0.6v AD_ID correct? The behaviour is the same when the battery is connected.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          0.6v at AD_ID is correct.
          • case sensitive
            • Jul 2014
            • 13
            All the main power rails except VCC_CORE seem to be powering on now (which is strange because I had 1.7v on VCC_CORE before flashing the bios).
            So currently what happens when I press the power button is:
            1) 3.3 and 5v turn on
            2) board powers off (leds and 3.3/5v turn off)
            3) board powers back on
            4) 3.3, 5, 1.05, 1.5 and 1.35 (ram) power on for less than a second, no VCC_CORE
            5) power off again
            VRON from the SIO is 0v but I'm not sure at what point that is supposed to turn on.
            VR_ENABLE and VR_READY are both 0v too.
            Thanks for your help so far, is there anything else that is a common problem on these boards that is worth checking?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Did you take backup of your original bios?? If yes, flash it back and check again whether you have VCC_CORE. If that's the case, then perhaps new bios flashed may have issues. BTW, 1.8V is present??
              • case sensitive
                • Jul 2014
                • 13
                I have a backup so can try flashing that back.
                One thing I didn't notice before is that as soon as I plug the charger in (before pressing power button) the board actually powers up the 3.3, 5 and VCC_CORE rails (I just thought it turned the LED on), no 1.05v though.
                Kind of stumped at this point, all the power rails are there at various times just never all at once and it clearly shouldn't be powering on the moment the charger is plugged in.
                I can't see any mention of a 1.8V rail in the schematic. VCC_CORE is 1.7V though, is that what you mean?
                • sergiobtnrs
                  Macbook A2337 820-02016 5.135V 0.275A
                  by sergiobtnrs
                  Hello!
                  New to this forum, I have a 820-02016 board which cannot turn on.
                  This one does 5.135V ~275mA for a short time, then goes down to ~100mA before shutting down and starting the cycle anew (USB-C multimeter).
                  Measured the mentioned points:
                  PP3V8_AON_VDDMAIN - ~3.8v
                  PPBUS_AON -12.3V then 12.0V and going down during reset
                  PPVDD_SOC_S1 - ~0.67v
                  PP1V8_S2 - ~1.8v
                  PP2V5_AWAKE_NAND - 2.5v
                  PP1V25_S2 - 1.22v
                  PP3v3_S2_UPC - 3.28v
                  PP5v_S2 - 5.2V
                  PP3v3_UPC0_LDO - 3.25v
                  PP3v3_UPC1_LDO - 3.25v...
                  09-12-2023, 01:35 AM
                • Perry Babin
                  Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
                  by Perry Babin
                  This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
                  04-03-2024, 10:40 AM
                • quickcalldave
                  HP 15-ab269sa X12A
                  by quickcalldave
                  motherboard has part no: 836098-601 label
                  laptop dead, 21.2v on the board by PSU connector, but I can see visual discolouration on what I think are open SMD resistors.
                  Laptop vents, fan and CPU heatsink congested with fluff - possible overheating.
                  Searched high and low for the schematics and boardview files to no avail.
                  Thanks for any help!
                  06-27-2020, 10:39 AM
                • sikocan
                  BIOS Request: Razer rc09-03304e42
                  by sikocan
                  This one boots no post.
                  Serial: BY2032A98801257
                  I've tried cleaning ME Region, failed ;(
                  Used this guide: https://winraid.level1techs.com/t/gu...zation/31277/2
                  At section, I couldn't find this field:
                  At "SMIP Signing Key" field, input the placeholder RSA Private Key (dummy.pem) that was created by the OpenSSL tool. Then go to "Build > Build Settings", input the Manifest Extension Utility (MEU) executable location at "Intel(R) Manifest Extension Utility Path"...
                  02-29-2024, 02:03 AM
                • JayToot
                  Diagnosing an FFalcon 50" UF1 series TV
                  by JayToot
                  I got a UF1 series and from my (basic) diagnosis I think the TCON board is gone, as I have audio, and the TV will change channels, open netflix etc on the remote, but has no visual. I used a flashlight to see if it was the backlight but nothing at all shows, so I'm thinking it may be the TCON board, though I can't say I'm 100% sure on that if anyone knows further testing I can do.
                  I'm wondering if this is possible to repair? Sure the TV was "only" $400 but I would prefer being able to fix it rather than chuck it out as I rarely used it and I would love it to last longer...
                  10-23-2025, 10:48 PM
