BIOS Request: Razer rc09-03304e42
  • sikocan
    • Oct 2019
    • 344
    This one boots no post.
    Serial: BY2032A98801257
    I've tried cleaning ME Region, failed ;(
    Used this guide: https://winraid.level1techs.com/t/gu...zation/31277/2
    At section, I couldn't find this field:
    At "SMIP Signing Key" field, input the placeholder RSA Private Key (dummy.pem) that was created by the OpenSSL tool. Then go to "Build > Build Settings", input the Manifest Extension Utility (MEU) executable location at "Intel(R) Manifest Extension Utility Path" field, input Win32 OpenSSL Lite 371 executable location at "Signing Tool Path" field, make sure that "OpenSSL" is selected at "Signing Tool" field, make sure that "Verify manifest signing keys against the OEM Key Manifest" is set to "No", leave all other settings intact and click Close.
    Error:
    Executing post-build actions
    Error 241: [Ifwi Actions] Failed to validate Key Manifests. The public key in "PMC Binary File" does not match the public key hash in the Key Manifests.
    Error 21: [Csme Binary Gen] Error executing post-build actions.
    Error 2: Failed to build.
    Failed to build!
    Thank you.
  • rex98
    • Feb 2023
    • 1293
    • Mandaue CEBU, Philippines
    Error:
    Failed to build!
    Thank you.
    try.
    i used Intel CSME System Tools v14.0 r4 (For 400-serie Comet Lake H_LP systems which run CSME v14.0) it has no errors.
    • sikocan
      • Oct 2019
      • 344
      Thanks for your help, I had used 14.5.45.1763_CON_V_A_PRD_EXTR which gave me the error, I'll keep in mind to use same version next time. Thank you
      • vinaypundith
        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
        by vinaypundith
        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
        So, I'm looking for a BIOS dump for this machine - a 16MB one....
        08-03-2024, 12:32 PM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • theplop
        Razer blade 2022, 14" PI480 wont boot to OS, freezes
        by theplop
        Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
        I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
        I've run memtest quite a few times, and more often then not...
        03-20-2025, 06:42 PM
      • shellybelly
        Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
        by shellybelly
        Back Story
        I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
        So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
        08-27-2023, 10:40 PM
      • chickenhawk88
        RAZER BLADE 15 2021 MODEL
        by chickenhawk88
        Looking for schematic for RAZER BLADE 15 RZ09-0369. Looks like the motherboard is Razer DA560. TIA
        05-12-2024, 10:25 PM
