T2 Macbooks Power Issues
  • curiositymaster
    • Apr 2021
    • 45
    • Nigeria
    We have received a lot of Macbooks with power related issues lately. In most cases, the Macs doesn't power up but trackpad responds when pushed down.
    In every 10 Macs with this issue, 7 is A1990. This is worrisome and I'd like to know if anyone else have had this experience with T2 Macs and what measures do you usually take to solve the issue?
  • mon2
    • 14664
    Re: T2 Macbooks Power Issues
    Huh? Is the original power adapter being used ? What does the USB Type C meter report on voltage and current draw for such cases ?
    How can the trackpad respond if there is no power ?
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      7 A1990? Sounds like it could be battery issues. Have you tested it with a USB C meter and see what readings you get? What is the voltage at? 20V? Amps? if you are getting volts but no screen and no chime, possibly seeming Amps going up to 1.00 or higher? If so I would try a REVIVE in DFU mode. Sadly if you do this and you are attempting an unlock you may force yourself not being able to unlock them. HOWEVER, if this is the case at least one can be the test and you know it may be a battery issue. I know in some cases I would have the same issue with A1990 or A2141 macs and a revive brought the computer to life but it needed a new battery.
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
      • ugamazing
        • Jun 2013
        • 171
        • usa
        Corrupted T2 firmware likely the cause of several of them. Revive/Restore/etc via Apple Configurator.
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Careful now, doing a restore would force the new iBridge on these Macs and forcing him with working USELESS Macs because of Activation lock (until a new jailbreak is released). He would need to honestly do a revive first and not restore. Most likely corrupted T2 and needs AC2 however in most cases it usually was a bad battery for me. So replacing the battery could solve some issues but not guaranteed. I would do a revive to be safe so you possibly could get into the computer and use the internal OS for a wipe if the user does not have their iCloud locked in.
          sigpic
          • curiositymaster
            • Apr 2021
            • 45
            • Nigeria
            The charger is 100% original.
            I have done these steps and none works:
            -Revive and restore in dfu
            -replacement of battery
            It seems you haven't seen this issue before?
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              My experience with A1990 (820-01041-A) is most likely the ssd short to ground so check if you get 2.5v - 2.7v on L9080
              • curiositymaster
                • Apr 2021
                • 45
                • Nigeria
                Thanks.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • zlr8r
                  Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                  by zlr8r
                  hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                  Ill try and give as much info as I can.
                  Dell Inspiron 17 (7786) Laptop
                  Service Tag: 5J0NHT2
                  Bios: 1.9.0
                  When I received this , it would only flicker on the KB backlight for a second, then off and on.
                  Then it started getting weirder!
                  Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                  12-12-2023, 09:31 PM
                • sli4
                  Original NES power issues
                  by sli4
                  I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                  I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                  Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                  On the big blue connector I get...
                  11-28-2024, 12:52 PM
