Help with board LA-9872P short to earth
  • ex250
    • Jun 2019
    • 97
    • Spain
    Hello, I have a Dell M6800 that power supply goes off every time you try to plug in. Power supply is on good condition, working Ok in other devices.
    The board is a LA-9872P, could not find a proper scheme, maybe 9871P is similar?
    The board has almost 2 mosfets dead, PQ5 and PQ701 (MDU3603 both ones). Changed them but plugging the power supply, the PQ5 died again, PQ701 still live, but short is still present.
    Tried to inject 2v, the PQ701 heats a lot, other components not seem to increase temp to my fingers "resolution".
    Totally lost, some one could point me?
  • mon2
    • Dec 2019
    • 13994
    Re: Help with board LA-9872P short to earth
    Hi.
    1) Yes, my database reports to use LA-9871P for this chassis.
    2) What part was used to replace PQ5 ? PQ701 ? MDU3603 for each ?
    Is it possible they were soldered in backwards ?
    3) Remove PQ5. Meter in resistance mode (2k).
    Check and post the resistance for the following with this mosfet off the logic board:
    source to drain
    source to gate
    gate to drain
    Checking for low resistance which will indicate the part is likely defective.
    4) With this mosfet off the logic board, meter in DC volts (20V should be ok for the scale).
    What is the voltage on PQ5 pads for pins 1-2-3 ? pin 4 ?
    Reference:
    http://electronicsbeliever.com/how-t...-is-defective/
    See the table on this website.
    • ex250
      • Jun 2019
      • 97
      • Spain
      Hello, thanks for answer!
      1) Oks, will use that one
      2) Replaced with the same fresh MDU3603, maybe others could be better for the board
      properly soldered, the layer on the board I think offers no doubt about position
      3) The PQ5 shorted was removed a throw away to waste, not fitted any other again yet (just to not burn other) The Source to Drain reading was continuity and discarted it as failed, not tested source to gate and gate to drain... I could solder a new one and let it burn to check. EDIT, maybe I'm just too stupid and throw away 4 good ones... (shit)
      4) with the PQ5 mosfet off and the power supply plugged, the pads 1,2,3 read is 19,57v and the pin 4 read is 9,29V, too high this one, not?, this not should be powered with the power button with 3.3v?
      • ex250
        • Jun 2019
        • 97
        • Spain
        Some update about, I'm totally nerd.
        I had desoldered all the coils, and remove the PJPs on board to try to asislate the circuit in short. Well seems the +VCC-CORE could be the problem, but seems that I cant find what is shorted. The PQ5 still heats up will all the PJPs jumps removed.
        Also there are a set of 2 lines of capatitors that seem in short line PC905 PC908 PC915 PC916 and all the small ones near cpu socket, but I'm not sure where to inject some voltage/amps to see which ones heats up without do more damage.
        Also I found that one of the bios eprom chips was in wrong position, reversed, just likely a previous try to repair by some one that could not want to any one try to repair the board. I removed both ones and put in the correct Pin 1 positions.
        I don't know it this board could be repaired and maybe is better to go for a new / repaired functional one.
        • ex250
          • Jun 2019
          • 97
          • Spain
          Any one has a .brd file of this board? reached a PU701 with short on pin 1,2,3 and a near cap shorted too (perhaps the 701)
          Edit: removed PU701 and the supposed PC701 but short still on board pads.
          Added schematic of the board
          • mon2
            • Dec 2019
            • 13994
            Have the boardview file but is tied to a paid sub.
            See attached to see if it helps.
            • ex250
              • Jun 2019
              • 97
              • Spain
              Many thanks, will check now.
              • ex250
                • Jun 2019
                • 97
                • Spain
                Well, the PU701 pads are all shorted, maybe a noob question, the PQ701 source pins are earth, not?
                The PR701 should give continuity? it’s earthed too on both sides
                I'm hitting the jackpot, any idea where to continue?
                • ex250
                  • Jun 2019
                  • 97
                  • Spain
                  Some update, found the PC535 (10uF 805) and PC529 (100uF CEEEFK1E101YP Panasonic) shorted, will change all the row of de 100uF capacitors for sure.
                  Almost one of the shorts is found, fingers crossed.
                  • ex250
                    • Jun 2019
                    • 97
                    • Spain
                    Found also the PC908 a 330uf in short.
                    Seems that all shorts are found. Now was trying to check if the mosfets 87350D, removed all from the board, any easy way to check if they are on spec?
                    • Tjp444
                      • Sep 2009
                      • 20
                      Hi, just curious if you had any luck with this repair? I have the same board and same problem. Thanks!
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • duwane
                        MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                        by duwane
                        Hi All.
                        I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                        Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                        After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                        Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                        10-17-2023, 07:48 PM
                      • sfernandes
                        Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
                        by sfernandes
                        Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
                        What I have done to try to isolate the issue so far:
                        The system powers on and stays on with...
                        01-23-2023, 06:03 PM
                      • survivalbloke
                        Need help pinpointing my short on this board (Lenovo) NM-D351
                        by survivalbloke
                        This is a Lenovo Thinkpad P15s Gen 2 with a board NM-D351. I'm having trouble finding my dead short to ground. I have the area narrowed down after much probing. You'll see in the boardview, there are two coils involved. I removed those coils and verified that that short is not on the mosfet side of those coils. . You'll see an arrangement on both sides of the board of 5 caps and one smaller one to the side. I have removed ALL 12 of these small caps and still have the short. Prior to that I injected at those caps with 1v5a and the short was only drawing 800ma so I could not see anything on thermal....
                        03-23-2024, 11:24 AM
