Toshiba C70-B charging troubles
  • mr_grey_hat
    • Apr 2019
    • 4
    • Turkey
    I have a Toshiba Satellite C70-B (Motherboard AR10SU-6050A2631701-MB-A01) with, I presume, issues with its charging circuit. I had a dead battery for a long while and had to keep the AC connected to be able to use it. I decided to finally replace the battery, but the replacements are not working. The amber power LED blinks repeatedly and the laptop refuses to start. I tried multiple replacement batteries, they all show the same behaviour.
    Here is what I know so far:
    AC only - OK. Power LED burns white and laptop boots.
    AC + dead battery - OK. Power LED burns white and laptop boots. After a while, the LED starts blinking amber, but I can keep using it. If I turn off the laptop while LED blinking, laptop won't start until AC disconnected and reconnected.
    New battery - Power LED blinking amber. Doesn't start
    AC + New battery - Power LED blinking amber. Doesn't start
    When I boot with AC only and then connect the new battery, power LED turns from white to amber (blinking), OS shows 60% charge but 0 charging current. If I then unplug the AC, laptop shuts down.
    As I tried multiple replacement batteries, and they all behave the same, I opened up the laptop and took some measurements of the charging IC BQ24735 (see attachments). Nothing really jumped out at me, other than BTST not being Vbat+6V when new battery + AC connected, but I have no idea why this is the case. I also found it odd that on the new battery, BATDRV is high and I see VCC on the SYSTEM output, meaning the laptop should be working but doesn't?
    Any ideas on how to proceed? Is the charging IC faulty, a short somewhere around it or an issue with current sensing resistors? Also, I was unable to find a board view or schematic for this board, so if anyone could share, that would also be very helpful.
    Thanks in advance!
  • mon2
    • Dec 2019
    • 14342
    Re: Toshiba C70-B charging troubles
    1) Power down, remove the battery.
    2) Meter in resistance mode (200 ohms). Check the resistance for each and every mosfet linked to this charger IC for possible shorts.
    Resistance between SOURCE & DRAIN ?
    Resistance between SOURCE & GATE ?
    Resistance between GATE & DRAIN ?
    Repeat this for all 4 mosfets linked to this IC.
    As a comparison to a similar charger IC device, review the posted chart by @DanielDacko here:
    https://www.badcaps.net/forum/showthread.php?t=98587
    • mr_grey_hat
      • Apr 2019
      • 4
      • Turkey
      I measured all 5 mosfets going to the IC at 200ohms mode. ACFET, RBFET, BATFET, LODRV and HIDRV all show open line between S&D, S&G and G&D, so no shorts there.
      I also checked the diodes, capacitors and resistors around the area, no shorts to ground. Resistor values seem good, except the 2 R020 resistors showing 0.3Ohm instead of 20mOhm, but I don't really have precision equipment to measure those. Diode between REGN and PHASE also okay.
      • mon2
        • Dec 2019
        • 14342
        Review this thread in the meantime for other ideas:
        https://www.badcaps.net/forum/showthread.php?t=90356
        • viking6791
          • Aug 2018
          • 42
          • My Desk
          Hello all, I have the same defect on my Toshiba C70-B (AR10SU). I tried to solve this issue with a clean ME region but without success.
          I changed BQ735 and 3 mos transistors on charging circuit before clean ME.
          The battery is new and fully charged on other laptop.
          I need schematic or some guidance to repair this laptop.
          Thanks in advance!
          • viking6791
            • Aug 2018
            • 42
            • My Desk
            My problems was the new battery, now I wait tools for repairing battery.
            • shahnld
              Sony kdl 65xg9505 green amber blinking
              by shahnld
              Good Day.
              I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
              i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
              green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
              01-03-2024, 03:05 PM
            • Thomasraud
              Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
              by Thomasraud
              i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
              QUOTED
              -It works on charger (without battery connected-only charger)
              -It works on battery (without charger connected-only battery)
              -& it also works when plugged in battery & charger, but it's not charging the battery
              //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
              and..
              QUOTE
              The IC cannot maintain the input current level
              06-28-2022, 06:47 PM
            • Avinitlarge
              Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A) not charging
              by Avinitlarge
              Does anyone have a schematic for a Toshiba Tecra A40-G-138 (FUZ2SY1 A4607A motherboard)?
              It's not charging through USB C, the mosfet was dead, I've replaced it but still not working. The charger is putting 20v out and the laptop is showing it's charging so it's partially working.
              The original mosfet was a AON7422G, I’ve replaced it with a AON7430 which is a similar spec
              12-15-2024, 11:53 AM
            • binary0101
              Asus X453SA No Display - Charging Indicator Blinking
              by binary0101
              Greetings
              I got an Asus X453SA for repair
              Symptom : no display, with charging indicator blinking, with or without battery. Power indicator is steady. When battery plugged in, the current consumption jumps, but the charging indicator is still blinking.
              Here is the measured power sequence :
              +3VA_EC +3.3V
              EC_RST# +3.025V
              +5VSUS_ON +3.307V
              PWR_SW# +2.982V
              3VSUS_ON +3.307V
              SUS_PWRGD +3.386V
              +1.05VSUS_PWRGD +1.061V
              1.8VSUS_EN +1.873V
              VSUS_PWRGD +3.383V
              PM_PWRBTN# +1.830V
              PM_RSMRST#...
              02-01-2023, 02:33 PM
            • delphi_firebird
              Toshiba Qosmio X755 Charging problem
              by delphi_firebird
              Hello Guys,
              I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
              - When battery is unplugged i works without any problem.
              - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
              - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
              Can you help me diagnose the problem? I have attached...
              10-16-2023, 03:04 AM
