Toshiba Qosmio X755 Charging problem
  • delphi_firebird
    • Mar 2015
    • 36
    • France
    Hello Guys,
    I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
    - When battery is unplugged i works without any problem.
    - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
    - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
    Can you help me diagnose the problem? I have attached the motherboard schematic for your reference.
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
    Link to schematic - https://www.badcaps.net/forum/showthread.php?t=124760
    Thank you
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Toshiba Qosmio X755 Charging problem
    check PQ208/209 with the battery inserted verify if the voltage is flowing from Drain to Source could you provide the voltage at the Gate /Source /Drain pin ? PQ201 with the battery inserted verify if the voltage is flowing from
    Source to Drain provide the voltage CHG_B+? test for any short on these two P-channel FETs (PQ208/209) using the Diode mode on the multimeter Source, Drain, and Gate."
    • delphi_firebird
      • Mar 2015
      • 36
      • France
      Hello ,
      Thank you for your answer.
      PQ208/209 are not shorted . with battery inserted Gate is 0 and 14,5V is flowing from Drain to source.
      CHG_B+ is 14,5 V so BATT+ is flowing from the source to the drain on PQ201 (it is not shorted )
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Now check PQ208/209 with the adapter (with out battery) inserted provide the voltage on Drain Gate pin ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Either of these 4 mosfets is very likely shorted or leaky.
          PQ203/204/208/209. Check resistance of all these fets.
          • delphi_firebird
            • Mar 2015
            • 36
            • France
            Hello Guys
            Thank you @Techtiger
            and Thank you @mcplslg123 , you were right the pq204 was not completely shorted but was leaky , i replaced it and the problem was solved .
            You
            • Techtiger
              • Oct 2014
              • 1601
              • france
              Well done mcplslg123@
                Toshiba Qosmio X755 Laptop Schematic
                LA-7191P...
                10-14-2024, 05:09 AM
              • Scoff
                HP Probook 470 G4 - Power and Charging Problem
                by Scoff
                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                07-03-2023, 09:28 AM
              • delphi_firebird
                Toshiba Qosmio X755 Compal LA-7191P Rev1.0 schematic
                by delphi_firebird
                Toshiba Qosmio X755 Compal LA-7191P Rev1.0 schematic...
                10-16-2023, 03:04 AM
              • huzo
                Strange problem charging battery Toshiba Z50-E
                by huzo
                First of all i haven't found the board number other then FLESSY2 G4227A A4227A etched under the DC in connector...
                The problem is laptop does not charge the battery...Laptop works on battery and work on charger, but doesn't charge the battery... when off, it pulls 0.13A ,when turned on it pulls around 0.500A and has spikes 0.6-0.8 A when booting, i found that ISL9238H is the charging regulator and i replaced it with ISL 9538H and it's all the same...i checked all the passive components and all seem to be ok...
                Anyone have an idea what to look for next? The battery...
                05-03-2024, 01:58 AM
              • ahmarzo
                Hp laptop charging problem
                by ahmarzo
                Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
                Charging ic is bq737 with voltages on pin no
                1&2 -19v
                34&5 -0v
                6 -2.56 v
                7- 0v
                8&9 -3.15v
                10 -0v
                11 -0.18v
                12 & 13 -13v
                14&15 -0v
                16 -6v
                17;18&19 -13v
                20 - 19v
                Voltages on battery connector are
                1&2. -13v
                3&4 -3.14 v
                5&6 -0v
                8&9 are ground...
                03-20-2025, 05:13 AM
