HP LA-D711P no power after not charging
  • incorrect
    • Nov 2017
    • 22
    • Greece
    my LA-D711P stop working. found and replaced a failed ceramic at 3VALW.
    after that, battery couldn't charge but laptop could turn on.
    found that PQ4 was shorted. I replaced the PQ4 but no voltage on gate.
    Any idea will be welcome.
    Thank you
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP LA-D711P no power after not charging
    Which charging IC is in use here?? Measure ACP/ACN/CMSRC/ACDRV/ACDET/REGN pins for voltage.
    • incorrect
      • Nov 2017
      • 22
      • Greece
      Bq25a
      acn=0.8v
      acp=0.8v
      cmsrc=0v
      acdrv=0v
      acdet=2.64v
      regn=5.9v
      • DanielDacko
        • Mar 2015
        • 328
        • Macedonia
        Maybe this will help.
        I don't provide help for people using CH341A and a clip.
        • mon2
          • Dec 2019
          • 14685
          @DanielDacko - great document !
          @incorrect, what is Vcc on this charger BQ IC ?
          • incorrect
            • Nov 2017
            • 22
            • Greece
            I took a look to the bq datasheet yesterday already. I believe that the ic needs replacement, because of the shorted pq4 earlier.i will replace it as soon i receive a new ic and i will keep you up to date.
            @mon2 the voltage on vcc seems normal.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              What is the resistance on pin5 of 1st dc-in mosfet?? If the resistance is good, then try replacing the charging IC.
              • incorrect
                • Nov 2017
                • 22
                • Greece
                yes it is good 4.3k i think, i checked it yesterday
                • incorrect
                  • Nov 2017
                  • 22
                  • Greece
                  Hello again,
                  i replaced the charging ic but problem persists.
                  • mon2
                    • Dec 2019
                    • 14685
                    Check the first 2 mosfets mated with the adapter.
                    After the charging IC replacement, what are the voltages on ACDRV ? CMSRC ?
                    • incorrect
                      • Nov 2017
                      • 22
                      • Greece
                      ACDRV and CMSRC still 0V.
                      I removed the 2nd mosfet and shorted source with drain. ACDRV and CMSRC went to 0.8V.
                      Also, i found that BATDRV is 1.5V. not sure if it's normal
                      • incorrect
                        • Nov 2017
                        • 22
                        • Greece
                        update.
                        while i plug the charger i see a spike of 0.5v on the gate of the first mosfet.
                        seems like somethings turns the gate off.
                        • mon2
                          • Dec 2019
                          • 14685
                          From @DanielDacko (see above post), attached are the normal voltages for this charger IC.
                          Do not remove and bridge mosfets - this can lead to possible further damage.
                          On the removed mosfet - check the resistance on this part while it is out of circuit:
                          source to drain resistance ?
                          source to gate resistance ?
                          gate to drain resistance ?
                          With the mosfet on the logic board - do you see the adapter voltage reach the right side of the 2nd mosfet ? What is the voltage ?
                          • incorrect
                            • Nov 2017
                            • 22
                            • Greece
                            Acn= 0.8v
                            acp=0.8v
                            cmsrc= 0v
                            acdrv= 0v
                            acok= 0v
                            acdet=2.6v
                            iout=0v
                            sda=0v
                            scl=0v
                            ilim=0v
                            batdrv=1.88v
                            srn=1v
                            srp=1v
                            gnd=0v
                            lodrv=0v
                            regn=6v
                            btst=5.8v
                            hidrv=1v
                            phase=1v
                            vcc=19.5v
                            Edit: Please note that if i replace the 1st mosfet with the shorted one, the machine works. battery doesn;t charge of course
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Refer to LA-A992P schematic page 46 and check PQ102/PD101
                              • Scoff
                                HP Probook 470 G4 - Power and Charging Problem
                                by Scoff
                                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                07-03-2023, 09:28 AM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • Schluchti45
                                MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
                                by Schluchti45
                                i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
                                Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
                                11-18-2024, 02:05 AM
                              • rob_hen
                                Dell XPS 13 9370 Laptop, No power, not charging
                                by rob_hen
                                Hello!
                                This is my first post for help, and I am quite newer to board repair, so bear with me.
                                I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
                                After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
                                There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
                                My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
                                05-01-2025, 09:20 PM
                              • bcstedt
                                LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                                by bcstedt
                                LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                                Problem:
                                On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                                It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                                01-18-2024, 01:03 PM
