iPhone X battery fpc connector
  • Nash99
    • Apr 2021
    • 51
    • South Africa
    Hi everyone.
    I have an iPhone X with a damaged battery fpc connector that I needed to replace. I also have an iPhone X donor logic board that I was going to salvage the connector from. The only problem is that it is plastic and I do not want to damage the salvaged connector when removing it.
    What temperature and speed should I make the hot air gun so that I do not melt the plastic on the connector?
    Thank you!
  • mon2
    • 14677
    Re: iPhone X battery fpc connector
    Practice on other donor boards with any similar parts.
    https://youtu.be/cgZoRhySwzg
    https://youtu.be/MU3FABXNSqI
    • Nash99
      • Apr 2021
      • 51
      • South Africa
      Thank you, this really helps!
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
