Hi all.
I'm trying to fix up another iPhone XS intel board which does not want to charge its battery. I noticed the pins in the battery connector looked slightly recessed into the plastic and weren't able to get them looking like there sitting correctly so I took the board apart and removed the connector. In the heat of removing the connector a few caps around it went flying. Those were replaced. There's two larger ones above the top left pin for the battery connector which are still missing and another larger one to the diagonal left of those directly under the touch connector I think it is.
I then realised that U5701 is missing. Is that normal? Ie no stuff? Been trying to find a replacement for like 4 hours now on Ali and other places but can't find anything hence why I'm thinking it's a no stuff. Not to mention it's in a much higher up place than where I was working so I can't see how u5701 gets desoldered from desoldering the battery connector. It's a fair way away.
One other thing I noticed is the one pin that's not ground on the battery connector facing the bottom of the board is reading OL. None of the components on that line are missing so unsure why that's reading OL.
Thanks for your assistance.
