HP250 G3 Battery not charging
    • 20807
    Re: HP250 G3 Battery not charging
    Can you try this software. Once installed run it and click on the small red/blue battery icon at the top left ,and post a screenshot https://www.passmark.com/products/batmon/
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Gate voltage is incorrect for PQ101/PQ103. HAve you checked the PQ101/103 mosfet out of circuit. The mosfet are as per schematic or changed by someone earlier. LODRV/HIDRV will not work at all unless ACDRV is fixed. So, i see the following probabilities:
      01.BQ24738 is bad or not properly soldered.
      02.PQ101/103 is/are bad or not as per schematic.
      03.PR108 is not as per schematic value or track is damaged.
      I'll strongly suggest to replace PQ101/103 as per schematic as you have said the mb was worked upon by someone earlier.
      • piernov
        • Jan 2016
        • 4435
        • France
        Clearly PQ101 is shorted.
        One day people will read and follow https://www.badcaps.net/forum/showthread.php?t=90356 , maybe…
          • 20807
          Oh dear
          • mon2
            • Dec 2019
            • 14140
            Update and good news! I thank you all. (It's been no bed of roses, no pleasure cruise).
            Issue was with PQ101.
            After removal, found that source & drain are shorting @ 0.6 ohms.
            PQ101 = AON6414A which is a rare bird to locate locally. Have many incoming from Asia but found a drop in with better specs using
            TI # CSD17579Q5A (valid drop-in replacement for AON6414A)
            MOSFET N-CH 30V 25A 8VSON
            from Digikey.
            Reference:
            https://www.ti.com/product/CSD17579Q5A
            Laptop charged the rather stale original HP battery in less than an hour to full capacity. Still waiting on the replacement battery pack which should behave the same but will last longer to discharge than the original battery pack.
            Many thanks again to everyone who chimed in to help !!
              • 20807
              Everyone makes mistakes.I`m happy you fixed it .
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
              • razenxd
                How can I charge that battery pack?
                by razenxd
                it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                Now, I have noticed a few things.
                The "dead" battery, while connected to charger and NOT Charging will...
                12-05-2024, 06:11 AM
              • ruletero
                Acer a515-43 low battery charge voltage
                by ruletero
                Hi
                Acer A515-43
                LA-H801P
                Fail: Does not charge battery, has low voltaje on connector.
                Laptop didn't want to turn on, only charge led blinked.
                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                10-24-2022, 02:31 PM
              • Klevjetack
                Charge a L19D3PDA battery externally from the laptop
                by Klevjetack
                Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                03-05-2024, 07:26 AM
              • dclass-pro
                Latitude 3301 not charge battery
                by dclass-pro
                Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                I noticed 2 things:
                1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                2) if I try to turn it on without the battery...
                05-06-2025, 06:19 AM
