HP250 G3 Battery not charging
  • mon2
    • Dec 2019
    • 14250
    Hi. Have a HP250 G3 laptop (schematic attached) that will not charge the battery.
    1) The laptop works fine with the AC adapter.
    2) The laptop works fine with a pre-charged battery (HP original with 880 cycles). The battery was depleted when brought in for service and we purchased a new clone with 2 charge cycles on it. The clone battery was received DOA and also will not charge with the laptop.
    Then we purchased the NLBA1 tool which worked well to ping the clone and HP battery with success. While we could readout the parameters with the I2C / SMBUS interface, the clone battery was unable to be charged with the NLBA1 tool.
    The same NLBA1 tool was able to charge the HP original battery with 100% success in about an hour.
    We applied this pre-charged battery onto the logic board and the laptop booted fine into Windows and reports the battery gauge @ 98%. The laptop continues to work while the battery drains and is presently @ 45% and going down.
    If we attach the ac adapter, the battery level will become static but continues to state "charging" but it does not charge up. Will remain at the current % level.
    3) Have replaced the charger IC @ PU101 and the 3 interface mosfets with no improvements.
    So we know that the AC adapter is able to power the logic board and does not make use of the battery since the battery level does not drain in this configuration.
    If using the battery only, the laptop works but drains the battery.
    In the absence of the battery, the BATT rail is ~3V.
    With the battery & ac adapter, the BATT rail is ~15V.
    Is it possible that PU101 (charger IC) is unable to charge this somewhat stale battery due to perhaps a higher current draw during the charging cycle ? Again, NLBA1 tool can charge this battery if out-of-circuit.
    Any ideas / suggestions on what could be at fault ? Thanks.
    • 20990
    Re: HP250 G3 Battery not charging
    Check the ADP_ID circuit ,voltage on PR1 both pins
    • mon2
      • Dec 2019
      • 14250
      Thanks @SMDFlea for your suggestions.
      To confirm, you are referencing PR108 & PR109 ?
      This logic board has been worked on by other techs so will investigate.
      Forgot to mention that with the battery docked on this logic board, the WHITE adapter light does turn ORANGE.
      Respectively, without the battery, the WHITE light remains WHITE. Perhaps this LED colour is triggered after the I2C / SMBUS investigation of the battery.
        • 20990
        i meant PR1
        • mon2
          • Dec 2019
          • 14250
          Thanks.
          1) PR1, Pin1 = ADP_SIGNAL @ +1v8.
          2) PR1, Pin2 = voltage divider junction @ 0V9.
          We are using a universal AC adapter @ 19V on this logic board.
          Update:
          OMG - just found the following using the keyword "ADP_ID":
          https://yashan.co.in/hp-cq40-battery...g-discription/
          Had no idea on this ID pin. We are < 1V here with the charging cable.
          Can a 3v3 rail feed be placed onto the ADP_ID rail to pacify the logic level ?
          So, the idea is to REMOVE PR1 -> apply a 3v3 jumper off the logic board to emulate the logic '1' (high) for the KBC.
          More...
          If the power adapter cable is REMOVED and measured without connecting to the logic board, then the ADP_SIGNAL = 19v0 !!
          If the same power adapter cable is connected to the logic board, ADP_SIGNAL drops to +1v8. According to the above website, the end result for ADP_ID must be +3v3..+3v6 to pacify the KBC.
          Removed PD2 - same results. ADP_ID remains @ 0v8.
          • mon2
            • Dec 2019
            • 14250
            So the plot thickens...zener diode PD3 is missing off the logic board.
            Based on this, believe that 19v0/2 = ~9v5 was seen by the ADP_ID pin on the KBC ??
            This would certainly nuke the GPIO pin?
            This would imply that KBC @ UK1 must be replaced?
            Never programmed the KBC9012 devices. From where can we source the contents of this KBC device ? Do see the mention of the SVOD3 programmer and see it on Ebay. We need this tool to program a fresh (empty) KBC?
            I think a damaged GPIO pin is the only way the 19v0 on pin 5 of the power connector tanks to 1v8 and ends up being 0v9.
            Welcome your comments.
              • 20990
              Use your bench psu and solder a 290k resistor from ADP_SIGNAL pin 5 to ADPIN and check voltage again. What programmers do you have now.The SVOD 3 is a good programmer ,it even has a battery tester built in.Other programmers that can flash the KBC are the Vertyanov JIG , SAS IO (vertyanov clone... ) RT809H,RT809F and even the CH341A.
              • mon2
                • Dec 2019
                • 14250
                Thanks.
                1) what should the psu value be?
                2) still leave in the 10k pull down on the logic board? Please note that PD3 zener diode is missing.
                3) without the logic board, pin 5 on the hp power cable is 19v. Believe that the KBC gpio pin (adp_id) is internally shorted. Have the kbc9012qf on order.
                4) can we extract the firmware out of this kbc9012qf or from where are the contents available?
                Thanks again. This charging issue is finally making some sense.
                Ok, just watched this:
                https://youtu.be/GQGH6yZuXCc
                Will test to read out with this tool. Which tool is the fastest for R/W of these kbc chips? 1.5 hours is insanely slow.
                If the kbc was dead, we can just apply the firmware from the internet from someone's dump? That is, no special locks or encryption in the firmware?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  ADP_ID is perfectly fine, especially if it turns on with AC adapter only and white LED is lighting up at DC-in connector. ADP_ID is a simple voltage divider.
                  ADP_ID = 19V * PR7 / (Radapter + PR1 + PR7)
                  With a 90W AC adpater, Radapter = 220kΩ (I think for blue tip)
                  ADP_ID = 19 * 10 / (220 + 10 + 10) = 0.79V
                  PD3 is no stuff as indicated in the schematics.
                  No need to waste time troubleshooting a motherboard issue and risking killing it by taking a wrong path if you don't even have a known good battery.
                  • mon2
                    • Dec 2019
                    • 14250
                    Thanks.
                    1) We are not using the original HP adapter but a universal 90W.
                    2) Where is this Radapter located? Inside the small 8 pin module that accepts the adapter voltage ?
                    3) What is the identifier in the schematic to show that PD3 is a no-stuff part?
                    The (rather old) HP battery does charge with the NLAB1 tool in about an hour.
                    So at this time, you are recommending to test with another battery? We should have one soon but the client also tested a new battery from Amazon with the same failed results.
                    We are very comfortable with the TQFP ENE chip replacement but of course do not wish to do this if not required. Running out of ideas fast on this one.
                      • 20990
                      What brand is the "universal" charger,a lot of cheapo chinese ones can be 45W or worse with a 90W label on
                      A 19V 65W charger has a 383Kohm resistor. 90W = 294K - 300K ,120W = 180K ,or thereabouts
                      A well worn battery will charge quicker. Agree with piernov that you need a good battery to start with.
                      • mon2
                        • Dec 2019
                        • 14250
                        The adapter is some generic we picked up from local resellers. The charging icons do appear on Windows and does report to be "charging" along with the battery gauge. However, the battery never "tops" up from the static reading upon power up. So if @ 45% charge, the battery remains at this level while ac adapter is docked (with orange light on).
                        Quite confused but will test with another battery although this old HP battery does indeed charge. We brought in a DOA battery from a local vendor and it has been returned to their factory for a swap. The customer also purchased one from Amazon with similar issue of unable to charge.
                        This universal adapter does indeed output about 19V under load. All these years, thought the barrel jack power supplies were only 2 contacts = Ground & HOT pin (positive). Now after some readings, there are 3 contacts (ie. adapter ID resistor contact). Quite interesting.
                          • 20990
                          Originally posted by mon2
                          Thanks.
                          The resistor is inside the charger tip. PD3 is no stuff as it has an @ before it . @PD3
                            • 20990
                            Thanks.
                            There`s a few EC dumps here on badcaps.There`s no special locks or encryption.There`s a copy of the EC inside the bios.Some boards will automatically flash the EC from the copy to a blank KB90xx at first boot.
                            All the programmers i mentioned are just as quick,they can program in under a minute.The ch341a is ok for those who don`t want to buy an expensive programmer for one time use.
                            • Sametbey
                              • Jan 2021
                              • 229
                              • Turkey
                              my own measurements, voltage and oscilloscope measurements in the diagram are in charge of the battery. ADID completes the circuit over the PU1 circuit. can you check.
                              I'm not happy to be so strong. because it's not humanly
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Lets keep it simple and begin from scratch. Measurements of Charging IC Pins for voltage?? Supporting mosfets for HIDRV/LODRV checked?? DC-in mosfet Gate voltage correct?? Battery is detected,so smbus communication is likely to be good.
                                • Stevedb
                                  Stevedb
                                  • Feb 2018
                                  • 624
                                  • Belgium
                                  Hi SMDFlea
                                  How do you program an KBC with a CH341A Programmer.
                                  Do you have an tutorial for that?
                                  Greetings Steve
                                  • mon2
                                    • Dec 2019
                                    • 14250
                                    @Stevedb, from my earlier post:
                                    https://www.youtube.com/watch?v=GQGH6yZuXCc
                                    • mon2
                                      • Dec 2019
                                      • 14250
                                      Hi. Voltage readings of PU101 (charger IC):
                                      (battery removed from logic board & AC adapter connected - WHITE LED on)
                                      Pin # 1 = 19v3
                                      Pin # 2 = 19v3
                                      Pin # 3 = 19v85
                                      Pin # 4 = 19v83
                                      Pin # 5 = 3v30
                                      Pin # 6 = 2v698
                                      Pin # 7 = 0v
                                      Pin # 8 = 3v31
                                      Pin # 9 = 3v31
                                      Pin # 10 = 0v71
                                      Pin # 11 = 3v06
                                      Pin # 12 = 3v02
                                      Pin # 13 = 3v05
                                      Pin # 14 = 0v
                                      Pin # 15 = 0v
                                      Pin # 16 = 6v0
                                      Pin # 17 = 5v89
                                      Pin # 18 = 0v
                                      Pin # 19 = 2v9
                                      Pin # 20 = 19v5
                                      • Stevedb
                                        Stevedb
                                        • Feb 2018
                                        • 624
                                        • Belgium
                                        thank you Mon2
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • dclass-pro
                                          Latitude 3301 not charge battery
                                          by dclass-pro
                                          Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                                          I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                                          I noticed 2 things:
                                          1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                                          2) if I try to turn it on without the battery...
                                          05-06-2025, 06:19 AM
