820-000165 SMC sensor issue throttling
  • henry1347
    • Jul 2020
    • 17
    • Venezuela
    Hi! I got this 2017 board that needed a long press in the power button to turn on and the CPU throttled extremely hard. if I do a SMC bypass the laptop works perfectly. tried with disconnected keyboard/camera/DC-in Board etc and still throttles. Fan always stays low not high
    I inspected the board and it looked pristine except a little liquid spill around the SMC and had a shorted cap C5125 from U5110 REFOUT
    after removing the Cap the laptop no longer needs the long press to turn on but still throttles and fan low rpm.
    still haven't replaced the cap. ran ASD EFI and passes everything, installed HWmonitor and checked sensors all show normal temps low.
    The only things that look sus are the "PECI SA" sensor jumps from 0 to 42 C don't know if that is normal
    and it shows the "CPU Rail" current as 14.43A. that looks High, and "Mainboard S0 Rail" 118W of consumption.
    I suspect it's a current sensing issue? would love some insight on where to look next as I'm a total Noob.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-000165 SMC sensor issue throttling
    Start with replacing the cap. Don't leave random parts off a board.
    • henry1347
      • Jul 2020
      • 17
      • Venezuela
      Hi, finally took this board again, replaced the capacitor and realized that the trackpad was extremely hot to the touch, and it didn't work anymore so I replaced it with another trackpad and cable and the laptop no longer throttles but the trackpad gets extremely hot I guess something is shorting it and I can't figure where to look for. I haven't turned on the laptop anymore because I feel like its going to burn the trackpad as it gets extremely hot.
      but before I checked HWmonitor and everything looks normal except :
      Memory bank A1 128C
      and battery drawing 254 amps
      the laptop no longer throtles, but the trackpad gets extremely hot.
      Any Advice?
      • henry1347
        • Jul 2020
        • 17
        • Venezuela
        Macbook air Burns Trackpads but works
        I have this 820-000165 liquid spilled. Everything works but the trackpad gets scorching hot! tested with other TP and flex cable and still the same it gets extremely hot to the touch.
        And also SMC reset works but Option/Alt to get to boot or pram Reset or cmd+R dont work. I'm loss in what to look for as everything looks "good" Help please
        • mon2
          • Dec 2019
          • 14325
          1) The logic board is p/n 820-00165
          2) trackpad is using connector J4800. Remove the trackpad so it does not get damaged and confirm the voltages are correct as per schematic.
          Confirm voltage of PP3V42_G3H.
          Confirm the same voltage rail @ pin 19 of J4800.
          sheet 36/76 of the schematic.
          • Askic
            • Sep 2018
            • 187
            • BIH
            I can confirm that this is not an issue. I've seen this on many A1466 MBAs and none of them had any issue because of that.
            So, are you saying that after replacing C5125 capacitor, Memory Bank A1 now shows 128C?
            Please examine closely HW monitor now and compare with the first picture you posted here. Perhaps one or more readings are missing from the list.
            • henry1347
              • Jul 2020
              • 17
              • Venezuela
              thank you. yes confirmed PP3V42_G3H in pin 19: 3.43V and in L7096 same 3.43V
              also PP5V_S4_IPD pin 14 is 5.10V.
              and PP3V3_S4_IPD pin 10 is 3.3V.
              there is no short between the pins,
              I think there might be some kind of short between pp3v3 and pp5v to Ground (via a data line?) as both of those lines seems a little bit more brown than the others.
              but I checked every data line an none is shorted to ground and the trackpad and keyboard works. the only thing that doesnt work is the "Option and cmd+R" combinations at boots so haven't been able to run ASD EFI again
              maybe a short via the usb communication but I'm lost on where to check next
              • henry1347
                • Jul 2020
                • 17
                • Venezuela
                thank you for your reply!
                Yes, the only difference is now Memory Bank A1 shows 128C everything else seems normal. but when I connect the charger it says the battery is drawing 254 Amps. but can't do nothing about that as the trackpad gets scorching hot the second the laptop turns on.
                • henry1347
                  • Jul 2020
                  • 17
                  • Venezuela
                  I checked every capacitor I could find for a short or a difference in the resistors rated Ohms on all the trackpad SPI lines and found nothing. also checked the trackpad usb lines but surely I'm missing something
                  • Stephen
                    A2141 MacBook Pro 16" lid sensor issue.
                    by Stephen
                    Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                    11-01-2024, 03:45 PM
                  • drake441335
                    OLED65G6P-U.BUSWLJR Temperature sensor issue
                    by drake441335
                    I am a very beginner at tv repairs. I am trying to fix my tv before I end up buying a new one. I do not know names of boards, but I will do my best to explain what I have done so far.
                    Tv is an LG OLED65G6P manufactured in april 2016. I had a warranty on it till September of 2021. Warranty is done. The problem I am having is when I turn the tv on after about two or so minutes a popup comes up and says the temperature sensor issue, and then it powers itself off. The tv works as designed, picture, sound, wifi, settings and everything, before it just powers itself down.
                    So i did what any...
                    02-13-2022, 03:34 PM
                  • CapLeaker
                    AcuRite 5 in 1 temperature sensor replacement repair
                    by CapLeaker
                    Got a new victim:
                    AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                    A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                    B: stuck at some temperature and maybe updating once in 12 hrs or so.
                    Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                    04-15-2025, 01:32 PM
                  • chbalnuweit
                    HP Elitebook G5 (COMPUTRO-6050A2945601) Power Throttling Issue
                    by chbalnuweit
                    i am facing a strange problem with an HP Elitebook 840 G5. Unfortunatley no board schematics are to be found on this one (COMPUTRO-6050A2945601)
                    The laptop runs at 0.4 GHz and is always in BD PROCHOT protection. Even in the BIOS it shows 400MHz CPU clock... And same issue when booting a Live Linux. So I am pretty sure I can rule out problems with the OS. It must be lower level.
                    I've been researching this behavior the past 2 days and tried EVERYTHING I could find on that topic.
                    What I noticed playing around is that when I disable...
                    11-08-2023, 01:18 PM
                  • groomit
                    Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
                    by groomit
                    I just replaced the battery on a Google Pixel 5.
                    After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
                    Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
                    The rubber seal is on again (as mentioned in various suggestions in other forums).
                    This smells like a cold or broken solder joint. So I'd like to reflow...
                    06-11-2025, 02:21 AM
