MacBook Air a1466 820-00165-a doesn’t start
  • zmeutz
    • Nov 2016
    • 82
    • Romania
    Re: MacBook Air a1466 820-00165-a doesn't start
    Originally posted by dellxps15
    ok someone already touched smc as it doesnt have glue on its sides.
    try reflow or reball it.
    ps: what is that mark on smc ? burn or some very small damage ?
    at the begining all measurements drive me to the same direction and I start to reball SMC, first of all, because I didn't find water damage / no liquid ... after SMC reball no change, same voltages ...
    I clean SMC now, it was dirty
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      ok for that. measure all coil after inserting psu only ( no battery) check if some s4 s3 s0 volts comes.
      volts on L5001 ?
      • zmeutz
        • Nov 2016
        • 82
        • Romania
        L5001 3,44v
        no voltage on coils ...
        s5 has 0,54v
        • zmeutz
          • Nov 2016
          • 82
          • Romania
          Originally posted by mon2
          PPBUS_G3H is not high enough for this local regulator to function. This is a buck regulator so it takes a higher input voltage and lowers it to the desired voltages.
          Trace PPBUS_G3H back to the source and check that power rail. This rail must be higher with the adapter installed.
          I notice that, do you know from where start
          PPBUS_G3H and PPBUS_G3H_R
          I see also D7005 pin 1 with 1.75v = PPBUS_G3H_R
          pin 2 and 3 15v
          I don't find any short ... u7501 is responsable to make 8v voltage?
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            on the other page u write:
            D7005 pin 2 and 3 15v and pin 1 8v
            R7006 8v both sides
            R7005 15v both sides
            8.5 volts are made by u7100.
            edit: remove f7140 and measure voltage on f7140 pads.
            • mon2
              • Dec 2019
              • 14157
              as per @dellxps15's comments
              PPBUS_G3H is made by U7100 - sheet 50/76 pdf schematics.
              F7140, pin # 1. 8.22v
              But pin 2 of F7140 is not 8v22 ??
              Then F7140 is blown / tripped. If yes, why did this happen ?
              Remove all power, meter in resistance (ohms) mode, black lead on ground & red lead on F7140, pin 2.
              What is the reading in ohms ? If the reading is too low in ohms then you most likely have a bad / shorted cap (assuming there is no soldering or damaged part from liquid) issue.
              • zmeutz
                • Nov 2016
                • 82
                • Romania
                #27
                I replaced C7102 = PP3V42_G3H and U7100 ... now I have right voltage ...
                F 7140 8.6v
                L7130 pin 2 8.6v pin 1 7.4v
                L7560 3.3v both pins
                L7520 still 0v
                PPBUS_G3H 8.6v
                PPBUS_S5_HS_COMPUTING_ISNS 8.6v
                PPBUS_S5_HS_OTHER_ISNS 8.6v
                PPDCIN_G3H_ISOL 15v
                PPDCIN_G3H 15v
                PP3V42_G3H 3.45v
                PPVRTC_G3H 3.34v
                PP5V_S5 5v
                PP3V3_S5 3.34v
                PP3V3_SUS 3.34v
                PP5V_S4RS3 0v
                PP5V_S0 0v
                PP3V3_S4 0v
                PP3V3_S3 0v
                PP3V3_S0 0v
                PP3V3_S4SW_SNS 0v
                PP3V3_S0SW_SSD 0v
                PP3V3_S4_TBTAPWR 0v
                PP1V8_S3 0v
                PPHV_S0SW_LCDBKLT 0v
                L.E.
                found topic same as mine ... from now
                https://www.badcaps.net/forum/showth...t=69953&page=2
                same rails with 0v and the other one have same with his ...
                • zmeutz
                  • Nov 2016
                  • 82
                  • Romania
                  #28
                  found short on U3510 ...
                  removed, and now I have voltage on most rails ...
                  USB3740, it's usb ic or bluetooth?
                  • mon2
                    • Dec 2019
                    • 14157
                    Very nice!
                    https://www.microchip.com/wwwproducts/en/USB3740
                    It is a USB signal switch so that a single port can mate with 2 different USB devices. Like a DPDT switch.
                    • mgjini
                      • Sep 2017
                      • 199
                      • united kingdom
                      #30
                      Originally posted by zmeutz
                      L5001 3,44v
                      s5 has 0,54v
                      hi there i don't know if i am allowed to post on the same thread or not, i have same issue, the reason why i am quoting here is that i have measured all pp3v42_g3h and every where i do get 3.42v but l5001 pin 1 there is 0v
                      i am trying to understand is this smc issue, i have the exact same board
                      regards
                      • mon2
                        • Dec 2019
                        • 14157
                        That is a very good observation !
                        Indeed there should be 3v42 present on pin #1 of L5001.
                        Remove all power / no battery.
                        Meter in resistance mode (2k scale is ok). Use the meter to check for continuity between a known good PP3V42_G3H point and pin # 1 of L5001.
                        You should see ~0 ohms between the 2 test points. If you see OL = over limit then there is most likely a damaged via or trace so the voltage is not reaching L5001.
                        After this confirmation, consider to take a piece of wire from a known good source for the PP3V42_G3H rail and solder it onto the pin #1 of L5001 to make up for the broken connection.
                        Confirm the continuity with the meter and then proceed to test again with your power adapter.
                        Post your results.
                        • mgjini
                          • Sep 2017
                          • 199
                          • united kingdom
                          #32
                          Post your results.
                          so i measured in quit a few places with a good pp3v42 and i am getting red probe pin 1 l5001 3.50 kΩ
                          do i still proceed with the wire?
                          also to add board draws 20v 3 amp
                          • mon2
                            • Dec 2019
                            • 14157
                            Are you using the original power adapter ? 20V ??
                            • mgjini
                              • Sep 2017
                              • 199
                              • united kingdom
                              #34
                              hi yes i am and also i have power supplier
                              • mgjini
                                • Sep 2017
                                • 199
                                • united kingdom
                                #35
                                the only thing on thermal camera which shows is u7100 but i have changed this with a new one, i have about 10 spare new ones
                                i don't understand 2 boards with same thing showing on thermal camera both faulty
                                • mon2
                                  • Dec 2019
                                  • 14157
                                  The use of an original magsafe power supply is recommended as it does a soft start and is safer to use than a power supply with the magsafe head.
                                  If you are confident there no heated parts then it should be fine to consider the missing wire. You do not have a short @ L5100 with such a high resistance to ground. L5001 should have the PP3V42_G3H voltage on pin #1 so suspecting a blown via from one side of the board to the other or damaged trace due to liquid damage.
                                  After applying the missing wire / connection -> check with the meter in resistance mode to confirm the connection is good and is also the same ~0 ohms on L5001, pad # 2. This rail powers the SMC (U5000) which is very critical.
                                  • mgjini
                                    • Sep 2017
                                    • 199
                                    • united kingdom
                                    #37
                                    i connected wire to l5100 and then to pp3v42 and now no light on charger and nothing happening still sorry for delay reply just double checking, i tried both power supply and charger, removing the wire charger light back on
                                    • mon2
                                      • Dec 2019
                                      • 14157
                                      Review these very good articles on the A1466:
                                      https://repair.wiki/w/A1466_2013-201...9D_MacBook_Air
                                      https://www.it-tech.com.au/mac-q-a/m...-up-sequences/
                                      https://logi.wiki/index.php/Power_Rail_List
                                      • mgjini
                                        • Sep 2017
                                        • 199
                                        • united kingdom
                                        #39
                                        hi yes i will have a read thanks
                                        • mon2
                                          • Dec 2019
                                          • 14157
                                          What is the voltage value for your PPBUS_G3H ?
