MacBook Air a1466 820-00165-a doesn’t start
    Re: MacBook Air a1466 820-00165-a doesn't start
    PP3V42_G3H 3.4v
    SMC_BC_ACOK 3.3v
    PM_SLP_S5_L - is pulsing 1.2v
    PM_SLP_S4_L signal is plusing 1.2v cycling
    P3V3S3_EN signal is plusing 0.8v
    PP3V3_S3 signal is plusing
    P1V8S3_EN 0v
    PP1V8_S3 pulsing 0.8v
    P1V8S3_PGOOD is pulsing
    P5VS4RS3_PGOOD is pulsing
    P1V05S0_PGOOD is pulsing
    DDRREG_PGOOD 1.2v pulsing
    PP3V3_S0 pulsing
      https://logi.wiki/index.php/820-00165_Pulsing
        PLT_RESET_L 0v
        : R7121 & R7122 are 10.6 10.4 Ohms. No broken path. No short. R7152 0.4 and R7151 2.9 Ohms
        SMC_PBUS_VSENSE pulsing all pulse is 5 sec
        PPBUS_G3H 8.56v
        PPDCIN_G3H 15.96v stable
        S4_PWR_EN 0v
        SYSPWROK 0v
          PPVCC_S0_CPU resistanec 8.1 ohms
              P5VS4RS3_EN IS 3.3V Check u8020 input PP3V3_S5 is 3.3V, ok. Check u8020 enable signal P3V3SUS_EN is 3.3V, ok.
              Is my u8020 is bad? https://www.it-tech.com.au/mac-q-a/pm-slp-s4-l-timing/ case study 3
                Remove all power. Check and compare the resistance of R1275.
                  0hms pin 1 and pin 2
                  pin1 to gnd 166 ohms
                    Remove all power, meter in resistance mode.
                    Check the resistance to ground of PPBUS_G3H.
                    Is this rail pulsing when power is on?
                    If yes, remove the fuse on this rail. Leave the fuse off the board for now.
                    Then power up again and check the voltage on the fuse pad from the producer side = ISL side.
                    What is the voltage of PPBUS_G3H without the fuse (no load from the consumer side so the rail should not be pulsing). Confirm this.
                      3.3megaohms to gnd.
                      Its not pulsing sir
                      PPVBAT_G3H_CHGR_REG 8.55v STABLE
                      PPBUS_G3H 1.0v
                        PPBUS_G3H 1.0v
                        This is too low.
                        Remove all power -> remove fuse @ F7140.
                        Then power up -> check the voltage on F7140, pad # 1 (or L7130, pin #2).
                        What is the voltage now of PPBUS_G3H ?
                        If this voltage is still not correct, carefully measure the voltage on each pin of U7100. This ISL6259 is used to create the PPBUS_G3H rail. It may be defective but first let us check each pin for the proper voltage.
                        Post your measurements. Again, take your time and use good meter probes so that the ISL6259 is not shorted.
                          This is too low.
                          PPVBAT_G3H_CHGR_REG 8.55v STABLE pIN1
                          PPBUS_G3H 1.0v PIN2
                          this reading is I remve already the F7140 fuse
                            My bad...good!
                            Now if you solder back F7140 - does PPBUS_G3H remain stable or does it pulse or dip to another voltage value ?
                              Do I need to solder back the fuse before testing the U7100 or just remve the fuse?
                                My bad...good!
                                If I solder back the Fuse 8.56 voltage is very stable. Confrim by my UNI-T multi tester also in the oscilloscope
                                  Sorry - we are out of sync. You have removed F7140 fuse and already confirmed that PPBUS_G3H voltage is OK. This is good.
                                  No need to test the voltages of U7100 for now.
                                  Now, solder back fuse F7140. Then measure the voltage of PPBUS_G3H again.
                                  We want to confirm that the voltage remains stable on F7140, pin # 2.
                                    Nope..
                                    Reading without the fuse
                                    PPBUS_G3H 1.0v
                                    reading with the fuse
                                    PPVBAT_G3H_CHGR_REG and PPBUS_G3H are stable 8.55v stable
                                      Post the voltage readings of U6100 SPI flash rom.
                                        U6100
                                        pin1- 0v
                                        pin2- 3.3v
                                        pin3 - 3.3v
                                        pin5- 3.3v pulsing to 2.0v
                                        pin6- 3.3v pulsing to 2.0v
                                        pin7 - 3.3v
                                        pin 8- 3.3v
                                          Hope yiu can help me more sir
