hp 250 g1 missing 5v .
  • mo000
    • Nov 2017
    • 283
    • algeria
    hi
    i have laptop hp 250 g1
    laptop had many shorted component
    i solve short issue
    i replace power ic
    the original ic is tps51123
    i use RT8223 instead of 51123
    DC-in LED lights up
    i have 3.3v but no 5v ON LL2 but i get 2.85 on vo1
    is it possible the ic is defective ?
    i get the following readings on RT8223
    pin1 4.89
    pin2 1.11
    pin3 1.99
    pin4 3.36
    pin5 2
    pin6 0.78
    pin7 3.3
    pin8 3.3
    pin9 8.2
    pin10 4.12
    pin11 3.3
    pin12 4.08
    pin13 2.7
    pin14 2.7
    pin15 0
    pin16 19
    pin17 5
    pin18 0
    pin19 0
    pin20 2.8
    pin21 2.8
    pin22 4.60
    pin23 0
    pin24 2.8
  • mon2
    • Dec 2019
    • 14592
    Re: hp 250 g1 missing 5v .
    Which exact p/n from Richtek did you solder in ?
    L6150 is a coil and should reflect the same voltage on both sides of this coil (magnet wire).
    Check the resistance across the 2 connections for this part - perhaps not soldered down properly or is defective.
    Also, the EN pins should be HIGH to enable the respective power rail. Check the values on Pin 1 & 6 of this IC.
    Are you 100% sure that the Richtek part can replace the original component ?
    • mo000
      • Nov 2017
      • 283
      • algeria
      yes i desolder the coil and messure in both side of coil
      the resistane on coil 6150=150ohm
      pin1=4.89
      pin6=0.8
      but the ic produce 3.3v normally .
      RT8223 is the equivalent of tps51123
      RT8223 EM DK B2M .
        • 21480
        TPS51123=RT8223M .The RT8223M should be marked with EQ or EQ=
        https://cdn.badcaps-static.com/pdfs/...b196680b71.pdf
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I think, If the original IC is marked EM, then replacement should be TPS51125 and not 51123.
          • mo000
            • Nov 2017
            • 283
            • algeria
            no it's 51123 not 51125
            i try to use 51125 but pin 18 is differnet it's EN pin .
            • mo000
              • Nov 2017
              • 283
              • algeria
              yes i think so
              i will search for another replacement
              i believe the problem in compatibility of ic .
              • toni comp
                • May 2012
                • 13
                • indonesia
                Up1585qqag (em ec) = tps51123a = rt8223p( eq=)
                • mo000
                  • Nov 2017
                  • 283
                  • algeria
                  finally TPS51123 arrived from china
                  the laptop now working fine
                  but still have one problem
                  the ic charger BQ becomes very hot when charging the battery i check no any king of short
                  i try 2 other ic but same problem .
                  i think the battery itself is the problem .
                  • fab13
                    Missing voltage on ZOTAC GTX 1050 TI 4gb coil - need schematic
                    by fab13
                    Hello to all,
                    I have a missing voltage on this ZOTAC GTX 1050 TI mini card (circled in blue)
                    I have all my other voltages strangely but the missing one goes up to 0.04 V and measured in Ohm 45 Kohm I find that really high and I expected much less than that.
                    0 SHORT circuit on the rest of the board
                    GPU heating and voltage at the coils 0.80 V which is normal for this type of card logically.
                    Without a schematic it's quite complicated and long to look for.
                    Do you have an idea?
                    I checked all my components seems present and checked...
                    05-31-2022, 02:58 PM
                  • ugamazing
                    820-02020 PPBUS_AON missing
                    by ugamazing
                    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                    02-05-2025, 04:21 PM
                  • jpreza
                    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                    by jpreza
                    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                    Looking at the card, it appears to be missing the following:
                    1x 1.0uH inductor - orange square
                    2x...
                    11-01-2024, 10:54 PM
                  • gurj1979
                    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                    by gurj1979
                    Hey guys.
                    Need help with this one.
                    Fan not spinning due to missing PWN Fan signal.
                    Also 5 seconds from powering up it freezes, unless in BIOS.
                    But as soon as Windows starts to load, it will freeze.
                    CPU is COLD / Room temp when it freezes.
                    I've replaced the CPU, same problem.
                    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                    Replaced fan - same problem.
                    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                    08-19-2024, 05:22 PM
                  • salopian
                    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                    by salopian
                    Hello. I would need some advice please.
                    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                    I have already replaced the logic board with another...
                    02-27-2021, 07:30 AM
