Alienware LA-9331P - LCD work only when inserted HDMI
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    Have this Alienware LA-9331P, that have no video/only BKL/ and 8 beeps/LCD error/. But when insert HDMI, LCD works ok.
    Board is buyed as refurbished from aliexpress and i found bad soldering on ic UV31
    Can anybody point me to signal that can be bad? i think it is some LCD detection
    Link to Schematic https://www.badcaps.net/forum/troubl...331p-schematic
  • Scotchmist
    • Apr 2019
    • 60
    Re: Alienware LA-9331P - LCD work only when inserted HDMI
    Check the LCD cable from the motherboard to the screen, could be loose, bad connection or broken wire
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      Originally posted by ktmmotocross
      Hello.
      most of that notebook that had installed windows 10 + evga precision software got edp lcd bios panel corrupted.
      if internal lcd is working, make a dump of its internal edp and compare to others. with a live linux distro u can restore that firmware
        • 21948
        It could be switching problem rather than the EDID.Check UV27,UV28,UV29,UV27.
        EDIT: just remembered about an old thread where that U27 chip gave some problems with a snowy screen
        https://www.badcaps.net/forum/showth...t=PI3LVD1012BE
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          what to check on it? what signal can be bad when display works ok
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            try to replace UV31 but still the same
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3628
              • slovakia
              Ok so it is maybe my fault. i put in GTX970 which on older bios like this A14 dont work normally. i put in GTX770M and it work normally.
              Try to put in never bios so that 970 can work
              • aliougm
                Marantz SR4003 AVR HDMI board issue, seeking for help
                by aliougm
                I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                Connection as below:
                Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                If I bypassed AVR then HDTV screen color be good.
                I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                I replaced all...
                04-30-2022, 12:21 PM
              • japlytic
                Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                by japlytic
                With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                An examination of the HDMI CEC wiring...
                07-10-2022, 09:48 PM
              • spleenharvester
                Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                by spleenharvester
                I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                03-12-2025, 03:42 PM
              • RossMoodley1967
                LG LCD TV HDMI PORT FAULTY
                by RossMoodley1967
                LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                02-28-2024, 08:38 AM
              • RatherLoopy
                Pioneer VSX-44 receiver HDMI dropouts
                by RatherLoopy
                I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                05-26-2023, 03:54 PM
