Toshiba Satellite - Locks up when plugged in
  • rikogyam
    • Jun 2014
    • Ghana
    #721
    Re: Toshiba Satellite - Locks up when plugged in
    I will surely try this. Would give feedback soon. Thnx
    • tiubxray
      Rookie
      • Jun 2014
      • 20
      • Malaysia
      #722
      Same for me. Right now already removed the NEC/Tokin. Going to search at local electronic shop tomorrow for SMD caps 330uf 2.5v.
      Mine Toshiba Satellite L300
      1.73ghz T2370
      2gb ram
      120gb hdd
      Igp x3100
      Wish me luck.
      From Malaysia.
      • Napalm
        • Mar 2013
        • 20
        • Portugal
        #723
        Hello
        I have accidently removed a litle capacitor numbered C142 when removing a bad nec tokin. (see image)
        i tried to resolder it but its very difficult.
        With 4 tantalum caps it did not boot, with 6 it boots fine but powers down loading windows.
        any way to fix it?
        the problem now is that it disappeared and I dont know where it is. I have scrap boards the problem is know the specs of the tiny smd...
        • tiubxray
          Rookie
          • Jun 2014
          • 20
          • Malaysia
          #724
          Mine was a success!! Quite hard....
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            #725
            Any similar sized SMD ceramic will do in place of the one you lost.
            A working TV? How boring!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #726
              Another one done today. 4x 330uF tantalums as usual. Worked perfectly. All capacitors recovered from scrap hp dv6000 boards.
              • mockingbird
                • Dec 2008
                • 5484
                #727
                Here's my go at this (Toshiba L300-0HH PSLB8C) :
                Caps used were Kemet T520 Series, part# T520V337M004A(1)E009. Cap is 4V 330uF, ESR is 0.009 and Ripple rating is 4600. Picked up aruond 60 of these a while back at a bargain (Make sure you use "V" size case which is low height).
                0E907 is 1.5mOhm or 0.0015 Ohms. The 4 replacement caps give 2.25 mOhms or 0.00225 Ohms. Not as low as Proadlizer, but still very low. There's also a 0.006 Ohm, 2.5V 330uF version of this cap, and the resultant ESR of using them in parallel would be 1.5 mOhm, but they're probably as rare as hens teeth.
                Toughest part was getting the 0E907 off. I used the method I remembered reading about in this thread of peeling away the layers (At this point I wished I had a reflow setup like you Th3_uN1Qu3). This was necessary after the Proadlizer cap came off when I trued to remove it with a hot air gun like a tooth cap. Took flux and wick to clean the area well afterwards, as well as nailpolish remover-grade acetone to remove the residue.
                "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
                -Leonid Brezhnev (On the Yom Kippur War)
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #728
                  Job well done.
                  I have always used mechanical means to remove these caps. Thin-nosed pliers and surgical blade. Heat runs the risk of damaging the solder balls underneath the socket.
                  • Wilman
                    • Sep 2014
                    • Indonesia
                    #729
                    Dear all, I have followed this thread since yesterday. And then i took my toshiba satellite m200. It has been sit down since 2009 (The problem - locks up when plugged in - encountered a month after i bought it! ) ). I didn't have 330uF caps, then i try replace the nec tokin cap with 2 nos 470uF caps. And it works again. Many thanks to admin and all of members of this thread. Sure, very good thread!!!!!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #730
                      We are always happy to hear success stories. Welcome to the Badcaps forums!
                      • Elusive_Cure
                        • Nov 2007
                        • 10
                        #731
                        Originally posted by ablacon64
                        I had the opportunity to solve another one with that same problem, this time I took some pictures. Hope it helps.
                        The notebook is a Toshiba Satellite A305-S6872.
                        The first image shows the capacitor removed, board cleaned.
                        The second, new solder added to the pads.
                        And finally, the finished job.
                        Hey guys, thanx for the helpful repair procedure and photos, i just successfully repaired one A300 with the same NEC capacitor problem. I managed to scavenge six 300mf smd caps from a dead motherboard, desoldered the NEC, and soldered on the pads 4 caps just as shown on your pics.
                        Now the laptop is up and running perfectly, and i can charge my client properly for the job well done.
                        Cheers.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #732
                          Here's another L300:
                          (See attachments for higher res versions).
                          This time I thought I'd opt for the scratching off the silkscreen in the middle method to make it easier to solder them on.
                          Computer works, but the LCD is wonky so I think it needs a new flex cable (because it displays fine when I move the screen).
                          Needs a charger and a new battery and it's as good as new.
                          • BigTroll
                            • Sep 2010
                            • 1317
                            • LAMBDA SOND
                            #733
                            nice repair mockingbird its another one saved!
                            My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                            • johnye_pt
                              • Dec 2013
                              • 11
                              • Portugal
                              #734
                              Hi, has anyone found a solution for those models without a NEC Tokin? I had a Satellite A200 in this situation but luckily I managed to replace the board with a working one from a very damaged laptop, so instead of a failing ISKAE LA-3661P rev2.0 with Intel graphics, I know have a ISKAE LA-3481P with ATi Mobility Radeon HD 2400. I was inclined to try and pry off the sATA connector from a dead board and solder it on the 2nd HDD bay with the missing connector so I could use it as my main computer (no money for a better one for now but working on it) with 1 SSD + 1 HDD + DVD, but the problem might resurface eventually as this board also doesn't have the NEC Tokin. I currently use a HP with SSD as main drive, plus a HDD in a DVD caddy, so no DVD drive for me.
                              On a related matter, I have a L300 with the freeze problem when on AC power, I opened it and it has a NEC Tokin OE907. I picked up a dead motherboard which supposedly came from a Dell laptop (DA0FM1MB6G3 rev. G) and it contains:
                              - 4 black smd caps under the sides of the CPU marked "330 79UB d";
                              - 1 black smd cap right under the CPU marked "220 706P e" plus 2 more in other places;
                              - 7 black smd caps marked "220 7046 e" all over the board;
                              - 3 yellow smd caps marked "KO 227 6K 733".
                              Are these smd caps of good quality? If yes, which ones should I use?
                              • Dalgacı12
                                • Oct 2014
                                • Türkiye
                                #735
                                Thank you. Thus your NEC / TOKI's problems instead I used 4 x 330 uF stood ultra low ESR capacitor. now perfect. Thank you again.
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  #736
                                  The 330 ones are what you want to use.
                                  • johnye_pt
                                    • Dec 2013
                                    • 11
                                    • Portugal
                                    #737
                                    Thanks for the input.
                                    If I manage to ruin a 330 smd when dessoldering, can I use 6x220? Can I combine 2x330 + 3x220? Or it's better not to use the 220 at all?
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      #738
                                      It's pretty hard to damage a tantalum cap, so don't worry.
                                      • jeremykum
                                        • Feb 2012
                                        • 95
                                        • Malaysia
                                        #739
                                        Great to know many are benefiting from extending the service life of their laptops, rather than going into the bin.
                                        Just my experience, Kemet Organic doesn't last. Tried before, and it's very sensitive to heat hence tougher to work on it with Hot Air gun/station, but if IR at below 230 celsius it's fine. My personal preference is Sanyo or Panasonic Tantalums.
                                        Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #740
                                          I have found that these old Satellite A200 laptops are so likable, I have collected about 20 of them.
                                          The sound quality is amazingly good from such tiny speakers in the Harman Kardon fitted models. So long as the diaphragm isn't broken. I either repair them with flowable silicone or get replacement speakers from EMPR. Sadly, the price was increased lately.
                                          Some models also are fitted with screens that have a much better vertical viewing angle.
                                          When playing video, there is less negative effect in the dark areas of the picture. Blacks turning grey and grays turning black.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
